Question about Mitsubishi P-91W Printer
I have a P91W printer as part of a BioRad GelDoc2000 imaging system. The image on the computer monitor looks sharp with good contrast, but the print made by the Mitsubishi P91W is all washed out with little contrast. Is there a problem with heating elements in the printer that abrogates the contrast quality? How to adjust?
MikeNJ1964
  • 398 Answers
SOURCE: Mitsubishi VS 4552A
One of your convergence IC's has either cracked loose or burned out. The IC will have to be resoldered or replaced and then the convergence circuits realigned. If you do not have experience in repairing convergence circuits then have a qualified tech handle it for you. This is by far the most common failure in the projection sets and a good tech can have it fixed in about an hour and a half. I charge $150 for that but shops in your area will vary, so call around.
Posted on Jul 31, 2007
  • 1694 Answers
SOURCE: Green shadows surrounding bright whites
Last point first.....contrast max default is normal.....
Next, I would adjust green screen and green focus = see if they
are working normally,if not then G2 / Focus block may be bad...
after that, I would suspect green CRT.........................T.
Posted on Dec 10, 2007
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi 50 in tv model # VS-5061
First of all check the circuit boards to see if ant CRT coolant has bee leaking on them. A strong flashlight will work best to spot it. It will usually appear on the front half of the boards nearest to the screen,. Mitsubishi has had some issue with CRT leakage. Also check for solder cracks around the Convergence amp ICs. Let me know what you discover, or if you need anything more.
Posted on Jan 31, 2008
  • 927 Answers
SOURCE: vs 4561 weak picture
Good Day, Techwanab;
Look for this to be your problem: CHECK FOR OPEN L2C50 PART #325C146030 ON THE SIGNAL PCB, OR BAD CONNECTIONS AND LEAKY CAPS IN THAT AREA.
Hope this was helpful and not too late.
Good Luck, big IRISH.
Posted on Jul 31, 2008
SOURCE: wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Posted on Jan 28, 2009
Image color adjustment hdp 5000
on the printer property dialog select image color tab then advanced settings, for darker images increase sharpness and contrast and decrease gamma to you satisfaction
Aug 26, 2013 | Fargo HDP5000 Thermal Printer
HP c5280 only prints green photos. All other printing is fine. I have put in new hp ink and photo paper. I have tried printing both from computer and with computer unplugged. A print from a website on...
This Problem is based on the Color Management so , The Perfect Solution for this problem is open the Photo or image etc in Adobe PhotoShop then goto Enhance->Adjust Color->Remove Color Cast , after removing the color cast , create a new layer for adjusting brightness , contrast & etc , then finally goto Image Size and change the DPI from 72 to 300 then save the image as JPEG or PNG etc , after saving the image close the Photoshop and open the image using Windows Photo Viewer and take the printout which will come as it is in the System
May 23, 2011 | Office Equipment & Supplies
How do I get my hp f4280 to scan to my comp.
Hello Lulu !
To use the scan features, the HP All-in-One and computer must be connected and turned
on. The HP Photosmart Software must also be installed and running on your computer
prior to scanning. To verify that the HP Photosmart Software is running on a indowscan
computer, look for the HP Digital Imaging Monitor icon in the system tray at the lower
right side of the screen, near the time.
To scan to a computer
1.
Load your original print side down on the right front corner of the glass.
2. Press Scan.
A preview image of the scan appears on your computer, where you can edit it. Any
edits that you make apply to the current scan session only.
The HP Photosmart Software has many tools that you can use to edit your scanned
image. You can improve the overall image quality by adjusting the brightness,
sharpness, color tone, or saturation. You can also crop, rotate, or resize the image.
3. Make any edits to the preview image, and then click Accept when you are finished.
Heres a link you will find everything you need to know about the f4280 (scan features starts on page 63) :
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Jul 15, 2010 | HP DeskJet F4280 All In One Printer InkJet
I need 96 dpi but I don't know what resolution settings to use to get that
It sounds like you need 96 dpi for some sort of graphics application? This really has nothing to do with viewing on your monitor though. DPI has more to do with how the image, pixel per pixel, is spaced during printing.
For instance... if you have an image that is 960x960.. at 96dpi you could print a 10 inch square image (wouldn't look that great at 10 inches however).
However printers ALSO manipulate the dpi. So for large images, you might need to give the printer an image that has 196dpi.
In summary, it really depends on the application. Thermal printers normally prefer 300dpi, large format printers like 196dpi (or there abouts), and our normal home inkjet will accept any dpi but you will notice if you give it 196dpi, you will get a better image when printing larger images.
Jul 11, 2009 | Acer 20 Widescreen LCD Monitor B203W bdmr
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
Mar 12, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Pictures appear to be darker than original in print outs.
You can make several adjustments to improve your images such as lightening dark areas, changing the exposure, sharpening blurred edges, and changing the brightness and contrast.
  • Exposure adjusts the overall intensity of light in an image.
  • Adaptive Lighting improves only the dark areas in an image without affecting the bright areas.
  • Brightness adjusts the amount of light in colors ranging from light to dark.
  • Contrast adjusts the difference in brightness between light and dark areas of an image.
  • Sharpness helps define edges and the smoothness of texture in an image. Use this tool to make a blurred image appear more focused.
Adjusting the image Follow the steps below to make adjustments:
  1. Click the View tab and select the image you want to edit by either clicking the image, or by clicking the small box at the bottom left corner of the image. Figure 1: Select the image c00603524.gif
  2. Click the Edit tab and then click the Advanced tab.
  3. On the Advanced tools tab, click Adjust Image .
  4. Select an adjustment from the list on the left. Figure 2: Adjusting the brightness c00603525.gif
    • The Exposure adjustment is automatically applied when the Adjust Image tool opens. Eight variations of the image are displayed on the left. The current image is displayed in the center. Each image represents a different level of adjustment. When you move the pointer over any of the images on the left, a large version of the image is displayed. Use Preferences to turn this large image preview on or off and to set the timing for the display.
    • If you want to use a different adjustment tool, select Adaptive Lighting , Brightness , Contrast , or Sharpness from the list.
  5. Select one of the images on the left.
  6. Do one of the following:
    • Click Accept to accept all changes and exit from the Color Toolkit.
    • Click Cancel to discard all changes and exit from the Color Toolkit.
  7. If you have finished modifying the image, do one of the following to save your changes:
    • Click Save to overwrite the original image.
    • Click Save As to save the modified image with a different name.
Aug 25, 2008 | HP Photosmart D7160 InkJet Printer
My pictures display poor image quality on the screen or when you print them out.
PhotoPC 800 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
DSC-S75 - LCD shows better than actual pictures
could be a monitor miscalibration. Sometimes, pictures will be different than what it appears LCD monitor brightness cud be high and PC monitor brightness might be low... Did u try printing some of the dark pictures? if printed photos are different, then its defintely a calibration issue.
Sep 11, 2005 | Sony Cyber-Shot DSC-S75 Digital Camera
Mitsubishi P-91W Printer Logo
266 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
