Hi my smeg washer drier shows e04 can you help me to find the problem.thank you.
    President:
  • Washing Mach... Master
  • 1,932 Answers
The E4 error means Water temperature probe in short circuit or interrupted.Check the connection going to the water probe
Thank You
Posted on Sep 03, 2010
I have a smeg washer drier wdi 146 with error code e13. Can you tell me what the problem might be. Thanks
i beleve your door interlock is fautly
or the wiring too it can overheat and cook
so youll need a new one from smeg uk
and check out the connector for any issues
see here for some details
although its a different model i would assume the company uses the same error code setup for all its models
and i would order direct from smeg
http://www.ukwhitegoods.co.uk/forumsphpbb3/washing-machine-forum/error-code-e13-smeg-wdi12c6-washer-dryer-t75513.html
Dec 20, 2014 | Washing Machines
How do I change the outside door latch on a smeg integrated washer/dryer
Go to www.repairclinic.com and enter WDI12. With luck, you will be presented with a list of common repair parts and may be able to view a generic Smeg video showing disassembly
Jun 20, 2017 | Smeg WDI12 Front Load Washer / Dryer
Error 4 on my smeg washer, not doing any programmes only rinse
Smeg Error 4 states 'NTC- water in, short circuit or interrupted'.???
'NTC' stands for 'Negative Temperature Co-efficient' or water temperature thermostat to you and me!
Might be worth trying the following in case the thermostat is just stuck.
One way of hopefully getting around the problem is first to ensure the washer is empty then pour the contents of a boiling kettle into it. That can sometimes kick the device into correct action. It's worth a try anyway before having to call in the repair man ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 08, 2011 | Smeg WM16AAA Front Load Washer
Washing machine is showing Error 14.
The only listing I have for Smeg states for 'E14' 'NTC dryer in short circuit or interrupted'.
One way of hopefully getting around the problem is first to ensure the washer is empty then pour the contents of a boiling kettle into it. That can sometimes kick the device into correct action. It's worth a try anyway before having to call in the repair man- it does say 'dryer' ;-0(
Jul 27, 2011 | Smeg WD16BA Front Load Washer / Dryer
Hi, we just defrost our Smeg Freezer FAB30 and followed the instructions on the website. It seems now that the fridge doesn't restart !!! Help ! What do we do ?
some of these new fridges have a delay timer and can take up to 10 minutes to reset. check to see you have power at the plug.. use a hair drier low heat .. make sure the stat is set.. duh .. hey it happens to the best of us .. jay
Jul 23, 2011 | Smeg FC40RX Bottom Freezer Refrigerator
I would like a manual for an IWDE7145 washer/drier
You can try diplodocs.com. This may have what you need. If not, it has links to other sources to find one.
Hope this helps you.
Oct 28, 2009 | Washing Machines
Smeg WD1 12C, error code 10
I have a smeg wd1 12c washer dryer showing error code e01 any idea how to fix it?
Gilly
Nov 06, 2008 | Smeg WDI12 Front Load Washer / Dryer
Machine error E04-01
error e04-01 means fuser warm up temperature
problems could be
-fuser thermister dirty ir defective
-fuser lamp is disconnected or defective
-fuser thermostat is defective
Oct 17, 2008 | Panasonic Workio DP-4530 Copier
E04 not draining
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Nov 20, 2007 | Bosch Exxcel WFO 2264 Front Load Washer
Smeg Washing machine
This happened to us before and we had to actually reset the unit. I had to call the tech support and they walked me through the process.
Mar 25, 2007 | Smeg WDI12 Front Load Washer / Dryer
Washing Machines Logo
315 people viewed this question
Top Washing Machines Experts
