Question about Canon PIXMA MP160 All-In-One InkJet Printer
Mp navigator code 2,250,0 - Canon PIXMA MP160 All-In-One InkJet Printer
Can not add Window Live Program to NP Navogator program
MP Navigator EX Failed to send e-mail. Check your mail program ...
answers.microsoft.com/.../windowslive/.../livemail.../mp-navigator.../8a2...
Nov 4, 2015 - Unable to send a scanned page by e-mail. ... But adding Windows LiveMail to MP Navigator EX's list of Mail Programs via wlmail.exe (One-click [button]->Attach ... Can not run Canon MP Navigator on Vista Home Premium (32 bit ...
Nov 11, 2015
Windows Live Mail properties won't open.
Oct 17, 2015
MAPI
Oct 17, 2012
More results from answers.microsoft.com
Canoscan MP Navigator EX 2 Windows 7
www.blizzardcomputers.com/canoscan-mp-navigator-ex-2-windows-7/
Mar 21, 2013 - After you install Windows Live Mail from Live Essentials and set it as the default email program in Windows 7 you can't use the scan to email ...
Jan 01, 2016 | Canon MP Navigator for Windows
Cannot start mp navigator
him try to Uninstall and reinstall the mp navigator program . remember to restart your pc after instalation
Apr 29, 2017 | Canon MP270 All-In-One InkJet Printer
Menu does not appear on the panel.
When the MX300 printer driver installed, will automatically be installed Canon MP Navigator. Canon MP Navigator function to activate the scanner. Try to search for Canon MP Navigator icon, on the desktop or START menu.
If Canon MP Navigator is not installed, you can download here Canon Service & Support. Open link, then select the operating system you use, download Canon MP Navigator, then install.
Nov 28, 2011 | Canon MX300 Office All-In-One Printer
How do you get the Canon Pixma mp500 to scan?
Scanning images,
About Scanning images
You can scan images from the machine to a computer without printing them and save them in popular formats. Scanned data saved on your computer can be processed using image processing software. Furthermore, you can use the OCR (Optical Character Recognition) software to convert scanned paper documents to text data.
* Before scanning
Before scanning images, confirm the following :
- Are the necessary software (MP Drivers and MP Navigator) installed ?
If the software is not installed, install it.
- Does the document to be scanned meet the requirements for an original to be set on the Platen Glass ?
- Is the machine connected to a computer correclty.
Confirm that the connection between the machine and the computer is physically secure.
Scanning Methods.
A) Scanning Using the MP Navigator
MP Navigator enables you to scan in documents loaded on the Platen Glass and view images saved on your computer or on a memory card. Scanned documents can be previewed and easily printed and edited according to your needs.
You can use the supplied application softwares to edit or print the document you have scanned.
Windows : Double-click the [MP Navigator 2.0] icon on your desktop to launch MP Navigator.
Mac : Select [Applications] from the [Go] menu, then double-click the [MP Navigator 2.0] icon to launch MP Navigator.
You can launch the following application software from the MP Navigator.
* Easy-PhotoPrint (Photo Printing)
* ArcSoft PhotoStudio (Photo image editing)
* ScanSoft OmniPage SE ( Converting scanned document to text)
- This application software may not be supplied with teis machine in some country.
Note : If you did a [Custom Install] and only installed the MP Driver and MP Navigator, these application software were not installed and thus cannot be launched. To launch any of the above application softwares from MP Navigator, do a [Custom Install] once again to install them.
For detailed operations of the MP Navigator, refer to the Scan Guide.
B) Scanning Using the Operation Panel of the Machine
You can scan documents to your computer by using the Operation Panel.
Important : Do not insert or remove USB cables when scanning images with the machine connected to a computer, or when the computer is at sleep or standby mode.
*If you are using Windows XP
The program selection screen is displyed the first time you press [Color] or [Black] on the machine.. Specify the [MP Navigator 2.0] as the application software to use, check [Always use this program for this action], then click [OK]. From the next time, MP Navigator is automatically started.
*When using Mac OS X
For the machine to start scanning when [Color] or [Black] is pressed, you need to set MP Navigator as the starting application software in Image Capture under [Applications] of Mac OS X.
1) Press [ON/OFF] to turn on the machine.
2) Load the documents on the Platen Glass.
3) Select the scan option.
a) Press [Scan].
The scan operation selection screen is displayed.
b) Use Up or Down arrows to select the scan operation, then press [OK].
Scan standby screen is displayed.
Save to PC : The document is scanned and saved.
Save as PDF file : The document is scanned and stored as a PDF file.
Attach to E-Mail : The document is scanned, and the image is attached to an e-mai using the e-mail application software.
OPen with application : The document is scanned and displayed on the registered application software.
4) Press [Color] or [Black].
The document is scanned. The settings configured from MP Navigator apply when scanning.
Important : If with some types of original the position and size of the image is not scanned in correctly, please refer to the "Selecting the Behaviour of the Operation Panel with Mp Navigator " in the Scan Guide (on-screen manual). and change the MP Navigator [Document Type] and [Document Size]] to match those of the original being scanned.
Note : The operation to be performed after scanning the document depends on the scan operation setting you have selected in step 3. For details on how to modify the operation settings, refer tp the Scan Guide on-screen menual.
C) Scanning from an Application Software
You can scan an image from TWAIN-or- WIA (Windows XP only) complaint application software and handle the scanned image in the application software. For detailed operations, refer to the Scan Guide (on-screen manual).
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
When i scan the images are black and white not color
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Selecting a Response to Commands from the Operation Panel
You can specify a response resulting from pressing the <Color Start> or <Black Start> button on the machine. Setting the response with MP Navigator allows you to scan documents easily.
Important:
With network connection, only MP Navigator can be launched. Configure the settings accordingly.
With USB connection, with Windows XP, the program selection dialog box will be displayed the first time you press the <Color Start> or <Black Start> button on the machine, as shown below. Select 'MP Navigator', select the 'Always use this program for this action' checkbox, and then click 'OK'. By specifying this setting, selecting any scan mode launches MP Navigator, and the selected action will be performed.
1. Click the Windows 'Start' button, then click 'Control Panel' (Non-Windows XP: click the 'Start' button, then click 'Settings' -> 'Control Panel').
2. In the resulting window, click 'Printers and Other Hardware', then click (or double-click) 'Scanners and Cameras'.
3. Right-click the scanner icon for the machine, then click 'Properties'.
4. On the 'Events' tab, in 'Actions', specify the setting to launch MP Navigator. Specify 'MP Navigator Ver2.1' for 'Select an event' and for all events. (Windows 98/Windows 2000: Select an event in 'Scanner events' and specify 'MP Navigator Ver2.1' for 'Send to this application'.) If the settings are already configured to launch MP Navigator, click 'Cancel' to exit.
Important:
If MP Navigator is not set as the program to launch, you will need to select an application to launch each time you press the <Color Start>/<Black Start> button.
5. Click 'OK'. Windows 2000 only: Restart your computer.
Setting actions for the <Color Start> and <Black Start> buttons with MP Navigator
MP Navigator enables you to specify the response resulting from pressing the <Color Start> or <Black Start> button on the machine. You can specify the response individually for each event.
1. On the Windows desktop, double-click 'MP Navigator 2.1'. Alternatively, click '(All) Programs' from the <Start> button on the Windows taskbar, point to 'Canon Utilities', then 'MP Navigator 2.1'. Then click 'MP Navigator 2.1'.
MP Navigator opens
2. Click 'Preferences', and specify settings in the Color Button and Black Button tabs to determine the response resulting from pressing the <Color Start> or <Black Start> button on the machine.
3. Select 'Event', and configure the settings in 'Actions'.
4. Click 'OK'. The operation will be performed according to the scan mode settings when you press the <Color Start> or <Black Start> button on the machine
Color Button/Black Button Tabs
The Color Button and Black Button tabs allow you to configure the following settings. Click 'Color Button' or 'Black Button' to open the corresponding tab. Setting items are identical in both tabs.
The following scan modes are available from the operation panel on the machine:
Save to PC Save the captured image data on your computer. Save as PDF file Save the captured image data as PDF files on your computer. Attach to E-mail Attach the captured image data to e-mail. Open with application Open the captured image data with the selected application
Action:
The setting items vary by event.
I hope it helps!!!
Nov 27, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Mp navigator 2.2
The sticker on the box was added on (the MP830 came out a year before Windows Vista came out) and indicates that the hardware is Windows Vista certified. You can download Vista compatible drivers and MP Navigator here. (MP Navigator is under the Software heading, once you select the OS.)
Jun 19, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Can't scan on my Canon MP600
What you need to do is go to the Canon driver downloads page and download the MP Navigator. I had the same problem becuse the disc that came with the printer doesn't work with Vista. You have to know which programs to download! You only need the MP Driver and the MP Navigator and all should work!
Apr 19, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
353 people viewed this question
old marine
old marine
