Question about Shimano Cycling
Son just gave me his bike it is all stock parts and in good shape. But, the thumb shifters are shimano total integration GS200....both of the thumb shifters on each side move ok but the neither the left or right when depressed move the derailleurs at all (3 gears at peddle and 7 gears back wheel is the configuration). So it just stays on smallest sprocket in back and smallest sproket at the peddles. Cables are all tot?
  • 6 Answers
SOURCE: I have a Shimano Deore XT rear derailleur. At the
The screws on the derailleur set the positional limits for the derailleur; if your description is accurate and it is always one position behind until the middle gears, I would guess it is not these screws causing the problem, but rather the cable tension is a little to low. There is a typically a knurled knob on the back of the derailleur that can adjust cable tension. Unscrewing it a little will tighten the cable. There may be other adjusters if you follow the cable up to the shifter. Try changing it in small increments (eg 1/8 to 1/4 turns) and go through shifts from high to low before determining if it is helping or not.
Posted on Jun 30, 2009
  • 1137 Answers
SOURCE: Adjust Shimano Acera back derailleur
There is a limit screw on the body of the derailleur that you have to back out slightly. You can tell which one of the two it is by watching carefully as you adjust it. It takes a phillips screwdriver.
Posted on Aug 03, 2009
  • 1137 Answers
SOURCE: Shimano total integration shift levers will not
Try this site:http://www.parktool.com/repair/byregion.asp?catid=53 Read the articles on shift levers and derailleurs especially. Good photos.
Posted on Oct 21, 2009
  • 484 Answers
SOURCE: Trek 6500 Shimano deraileur adjustment issues
Derailleur adjustment takes time to master. Try this out:
First, wash your drive train out really thoroughly and use a degreaser (Simple Green works really well) and a chain brush on the derailleur and chain. Rinse it off and let it dry, then relubricate the chain (and ONLY the chain - never lubricate your derailleur). Now flip your bike onto the bars and saddle so you can crank while you shift manually. Use the middle chainring up front to adjust the rear gears. Okay, shift into your highest gear in the back and then release the derailleur cable. Use this opportunity to make certain your "H" setting is good; the derailleur's jockey wheel should be perfectly aligned over the small cog. Now manually push the derailleur to the lowest gear (while pedaling) and set the "L" so the jockey wheel is immediately outside the last cog. crank back to the high gear. Turn the barrel adjuster for the cable tension to its half-way point (figured by unscrewing it all the way and then counting revolutions as you screw it back in). Pull the cable taut and reattach it. Shift into your middle gear (or if it is an even number of gears, pick one of the two middle gears). Use the barrel adjuster to get the jockey wheel exactly over the correct cog. Pedal and shift through the gears. In each gear, back-pedal to make sure the chain is not skipping. You should be able to free-wheel without problem in every gear on a properly adjusted drive train. If the gears are requiring much adjustment on the barrel adjuster, then you may have a bent derailleur hanger. This can be straightened manually without tools if you have a good eye and patience. If it goe that far, come back and repost "bent derailleur hanger".
i hope this helps
-matthew
Posted on Oct 28, 2009
  • 61 Answers
SOURCE: shimano tiagra 9 speed shifters how to change gear
Go to http://techdocs.shimano.com/techdocs/index.jsp
Search in drop down list to go to all tiagra items and identify your particular components. Shimano are good at numbering their parts and you should find the number you seek on the bicycle component. You will usually be able to download an exploded parts diagram and service instructions. The service instructions are prefixed by the letters SI.
Posted on Nov 22, 2009
Shimano front derailleur manual
ContaCT YOUR LOCAL BIKE SHOP FOR ASSISTANCE
Aug 17, 2014 | Shimano Deore Xt Thumb Shifters 7...
My Shimano Deore DX mountain bike up / down shifter is malfunctioning. Any help will be appreciated.
Maybe start here and if you can't figure it out, take it to a Bike Shop. Ther's only so much useful mechanical advice one can remotely lend with no details.
Jul 03, 2010 | Shimano Deore Xt Thumb Shifters 7...
New shifters for deore xt x7 delrailer
Shimano make an "EZ fire" which is an integrated shifter/brake lever combination and cheaper than buying seperate shifters and levers.
e.g.
http://www.tredz.co.uk/.Shimano-Acera-8-Speed-EZ-Fire-ShiftersBrake-Lever_24339.htm
Feb 07, 2010 | Shimano Deore Xt Thumb Shifters 7...
My thumb shifter used to downshift 3 speeds at a time 2'xs now it only does the 3 downshift once and one more down shift will not shift all the way to low.
Try this link:http://www.parktool.com/repair/byregion.asp?catid=53 Please rate me if this helps. It is a good site with pictures.
Nov 24, 2009 | Shimano Deore Xt Thumb Shifters 7...
Shimano tiagra 9 speed shifters how to change gear
Nov 21, 2009 | Cycling
Choosing bike's gearshifter
You must replace your shifter with one that is the same type, that is, if it is a six-speed shifter, you must replace it with a six-speed shifter. Also, if you have a Shimano derailleur, then the shifter you get must be a compatible type. Shimano uses a 2:1 actuation ratio, so you have to use a Shimano shifter or a SRAM 2:1 shifter (Attack, Centera or MRX models).
The only stupid questions are the ones we don't ask, friend. Look on eBay under bicycles for "6-speed shifter" and you will be able to find some really good deals.
When it comes time to work on your bike, go to Park Tool's website (parktool.com) and on the top right corner is a "Repair Help" link. You can select your topic by highlighting the part in question on the bike.
Hope this helps,
matt
Aug 23, 2009 | Cycling
Shimano st 7900 shifter,left lever apart and how to reassemble
You can download an exploded diagram of the 7900 series STI shifters here:
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/ST/EV-ST-7900-2874E_v1_m56577569830670749.pdf
You can reassemble them according to this diagram.
May 11, 2009 | Shimano 2008 Dura-Ace BR7800 Rear Road...
Cycling Logo
97 people viewed this question
Top Shimano Cycling Experts
John Egan
John Egan
Eric Hidle
Level 1 Expert
Mike
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
