I have a kenmore washer model #11049972602 that wont power up when I hit the power button a bell rings I have changed the control board and the touch pad assembly help
3 Suggested Answers
SOURCE: Replace touch pad and control panel
Sorry, there wasa problemwith the link in the previous post. Hope this one will work. https://secured.whirlpool.com/Service/ SrvTechAdm.nsf/ 2cd44500d572193285256a45004fd9d6 /2c1e295a88aaaae885256c5d004632a4 /$FILE/8178010.pdf
Posted on Jun 17, 2007
blueextc3221
  • 15935 Answers
SOURCE: Kenmore top-load washer,"Elite" touch-pad control
PF is power failure. Your home has experienced a power failure since the last use.
Unplug it for 40 minutes to reset.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
F21 error on Kenmore washer
The F21 drain indicates a long drain. There are several reasons for the error. The most common causes are debris in the drain pump filter or excessive suds. If you aren't using HE detergent or if you use too much detergent, the excess suds may be the cause. First, remove the clothes from the washer. Try running the washer without adding more detergent.
To check the filter, you will need to unplug the washer. Next take off the bottom panel. Locate the drain pump and the adjacent filter. Have a bucket handy to catch the water from the pump. Open the filter and remove any foreign objects. Look into the pump and check for any objects that got past the filter. Remove anything that doesn't belong. See the cabinet and pump diagrams here: http://www.searspartsdirect.com/model-number/11049972602/0583/0153200.html to help you take apart the unit and locate the pump filter. Close up the filter and try running the washer (again no clothes and no detergent). If the error does not recur, you've solved the problem.
If the F21 error repeats, then the pump or the water pressure switch could be faulty. If water has been pumped out of the washer, then check/replace the switch. You should also check the wiring between the switch and the main control board.
I hope this helps.
Jul 26, 2016 | Kenmore Washing Machines
I have a Kenmore model 11049962603 that displayed an f-71 error code. I ordered a new cpu computer from sears and installed it. the machine seemed to work for one or two loads. now it displays an f-70...
I provided a complete list of error codes for this type of washer in the image below. The error codes vary by the exact model of HE3t washer that you have. Since you have an HE3t that is displaying the F70 and F71 codes, the list below should apply to your model. These are not listed in the owner's manual because they are intended for technicians. Use extreme caution if you follow any of the troubleshooting described in this information sheet. Unplug the washer and shut off the water supply before accessing internal components.
The F70 and F71 codes indicate that you have a communication error between the CCU (Central Control Unit or main machine control board) and the user interface touch pad assembly. Here are some troubleshooting tips:
Make sure that you have the washer plugged into a properly grounded 3 prong 120 volt AC electrical outlet.
Unplug the washer for 30 seconds to allow the control boards to power down and reset. Plug the washer back in but do not touch the power button (or any other buttons) for 1 full minute. This may reset the control board. Pressing the power button too quickly after reapplying electrical power to the washer can cause the F70 or F71 code since the CCU does not have time to recognize the user interface control.
If the above tip does not help then the most suspect component failure is the MCU (motor control unit -- motor control board at the bottom of the washer beside the drive motor). You can check for this failure by unplugging the washer and then pulling the MI3 connection on the CCU. The wiring diagram below has the MI3 connection highlighted in red. The connection has blue wires. The third image below shows this connection on the control board. The connections are labeled on the control board. Press the tab at the bottom of this plug down and then pull it out. Power up the machine with this connection unplugged and don't touch any buttons for 1 minute. If you then press the power button to turn on the washer and don't get the F70 or F71 code then the MCU at the bottom of the washer will likely need to be replaced to fix this problem. A technician would normally be needed to verify this failure and replace the MCU. The MCU is expensive ($423).
This troubleshooting information is based on a common HE3t model that displays the F70 and F71 codes. If you need more help, submit additional details and the full model number of your HE3t washer.
Mar 27, 2011 | Kenmore Washing Machines
I hit power button then start start light flashes and wont start
If your start button is flashing even when you hit your start button . Your electronic touch control board (ETC) is not working correctly . Either the intergrated curcuit board is not responding or the actuator on touch panel is broken . Push start button in and see if the button makes a clicking noise. If it does replace curcuit board , if it does't replace the part where you touch.
Oct 09, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Got a Kenmore Oasis HE washing machine. Lately, when starting, the "F1" symbol shows up in the digital display and I have to hit the stop and start button, usually 3 times before it takes off on it's
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 05, 2009 | Kenmore Washing Machines
Kenmore Elite H3 control buttons - some work some don't
The diagnostic function will not help you if your user interface board (UIB) is acting up because to put into diagnostic you have to select drain spin, then the no spin option, and hit the prewash button 4 times.
It sounds like your UIB is the problem.
Jan 01, 2009 | Kenmore 42822 Front Load Washer
Can not change Cycle setting
I wonder if it's the control board that needs replacing ??? found a note on www.managemyhome.com saying...(part no 134207700 according to my parts list). Is there anything unique/special in replacing the control board... here are the instructions for it...if you try this, pelase let me know...
Replacing the control board is just a matter of removing wires from the old control board and installing them on the new one. It is an electronic board and can be damaged by static electricity so you have to touch some ground points with you hands before touching the control board.
To access the control board remove the top panel from the washer. There are 2 screws in the rear of the washer holding the top on.
With the top removed you will see three screws going down from the top holding the control panel to the cabinet of the washer; remove them.
Lift the control panel up and it will come loose. The control is mounted to the control panel with some screws.
Oct 07, 2008 | Kenmore 44072 Front Load Washer
I HAVE A BELLING TOUCH TRONIC 4 RING HOBB. THERE IS POWER TO THE UNIT BUT WHEN I PRESS THE ON BUTTON IT WONT COME ON.
I am not too familiar with this unit. However, I would look for any on board fuses or surge protectors. If it still fails to come on then I believe this to be a blown circuit board.
Jun 23, 2008 | Heating & Cooling
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
