Question about Muratec - MFX-1300 Copier
We replaced new drum and copier says not usable
    Genius:
  • 1,218 Answers
The drum should only be replaced when the display says "REPLACE DRUM" ...NOT when the display says "Replace Drum Soon"
...try the following...... Press PROGRAM,*,*,I(thats capital letter i) then press ENTER.
SHOULD RESET IT
Posted on Sep 05, 2010
Oki b4600 order drum
drum unit must be replaced. it reached the end of its usable life
Jul 01, 2014 | OKI B4600 Printer
DRUM UNIT LIFE
drum unit needs to be replaced. it has reached the end of its usable life
May 19, 2014 | OKI Office Equipment & Supplies
Konica minolta continuous printing
Have you had the developers and drums replaced or does the screen say Replace PC Drums? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the developing units next to the drums. Did you recently replace the drums and the developer if so did you clear the counters for the drums and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developers and a new drums and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the drums unit replace the developer. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. .
Apr 11, 2014 | Konica Minolta Bizhub Press C6000 Copier
Printer timed out
Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN Developer procedures. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Mar 22, 2014 | Konica Minolta Copier Toner 7155 7165...
How To Replace Kyocera Taskalfa 180 Copier Drum
Hopefully this will help.
Source:
http://www.manualowl.com/m/Kyocera/TASKalfa-180/Manual/345566
Dec 30, 2013 | Office Equipment & Supplies
"please wait" error appears on diplay when i turned on the mfp
Sir, Mam, Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer. IF not then the copier thinks the new drum and new developer are old. Copier works on the counters that how it know it got a new drum and developer. Get new develop and new drum and have it installed correctly, Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade the reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything unit the F8 is run. Or you start over again with new developer and new drum
Nov 24, 2013 | Minolta DI2510 Black and White Copier
Minolta bizhab di 3510 please wait problem
mam/sir Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer. IF not then the copier thinks the new drum and new developer are old. Copier works on the counters that how it know it got a new drum and developer. Get new develop and new drum and have it installed correctly, Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE AVACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you start over with new developer and new drum
Jul 10, 2012 | Minolta Office Equipment & Supplies
Printer is dsplaying"drum error" to
According to your problem, may be the drum is not usable now. But first clean the toner drum properly. May be this may occurs for setting of the drum in printer. So resets the drum carefully inside the printer after clean it. Then reboot the printer and the system both. If it doesn't solve your problem then change the toner. It may help you or you have to change the drum or cartridge.
Jun 27, 2011 | Brother DCP-7040 Laser Printer
Drum full of waste toner. Do i have to replace the
I have no idea what ikkenom is smoking.
The Drum Cartridge unit is as user-replaceable as a toner cartridge.
Yes, you will have to replace the drum cart.
http://accessories.us.dell.com/sna/PopupProductDetail.aspx?c=us&l=en&cs=bsdv&sku=310-5732
Dell wants $169 for this part. Here's what it does:
Highlights
* Applies toner to the page
* Provides a usable life of up to 42,000 page impressions (up to 10,500 pages per color)
Overview The Imaging Drum Kit from Dell is specifically designed for use with Dell Color Laser Printer. This kit includes an imaging drum and instructions on how to replace it. It applies toner to the page and offers a usable life of up to 42,000 page impressions (up to 10,500 pages per color).The part number located on this toner cartridge is: P4866
Manufacturer Part# : M5065
Dell Part# : 310-5732
It comes with very detailed instructions on how to remove the old cartridge and install the new one. Very easy, but there's no way around the price tag.
Nov 18, 2009 | Dell 3100cn Laser Printer
Canon C100 copier
Its the drum unit that you need to replace and clean the optics-call service
Aug 29, 2008 | Canon C130F Black and White Copier
176 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Ben
Ben
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
