Question about LG LFC21760 Bottom Freezer French Door Refrigerator
LG model GR B218 JUDA The right hand runner on the freezer has become detached and the door needs to be jammed closed. Is there a picture of the mechanism available so I can order the new parts ? Is it possible it is simply a runner come off or are new parts required. Thanks Bill
  • 489 Answers
SOURCE: LG bottom freezer
Sounds like the refrigerator is sitting lopsided.  Make sure that the front legs are both retracted in the up position.  If it doesn't work, then lower the front leg on the hinge side of the refrigerator.  That will cause the frame to lift the door and it should be able to close properly.
Posted on Jun 08, 2008
SOURCE: Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Posted on Feb 21, 2009
Benimur
  • 6966 Answers
SOURCE: refrigerator not cooling.
Hi and welcome to FixYa,
Almost always, your described problem could be either:
  • evaporator fan/blower is faulty; or
  • air passgaeway blocked or vent is blocked or closed.
The refrigerator section gets its cold air from the freezer. If the freezer is working then the frozen air would have to be drawn to the refrigerator side by the fan. If the fan is not working or the air passage way is blocked, then no frozen air would be moving towards the refrigerator side. result would be as you described.
In some instances, it could be the thermostat of the refrigerator but this would be least likely.
Good luck and thank you for using FixYa.
Posted on Feb 22, 2009
SOURCE: LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Posted on Dec 18, 2009
  • 161 Answers
SOURCE: LG GR-349R bottom mount freezer gets heavy ice
Find the drain tube in the back and check it for a frozen state. If it si,use a hair dryer to thaw it. If it does it again, you have a defrost problem
Posted on Jan 22, 2010
I have an LG Refrigerator. GR-559FSDR 121T0063 Serial No. 102KRXD00130. It is giving an alarm like the door is open every few seconds. Both lights are off, when you open doors.
Check the freezer doors. Pull the tray out of the top drawer and see if there is ice build-up behind it causing it to not close all the way. I had to defrost my freezer to get rid of it. It also helped the ice fan from icing up stopping.
Apr 18, 2017 | LG Refrigerators
Cant find serial # on GR-620RW fridge. it's not on sticker on inside of fridge. It says refer to bar code
Hello there,
There are different places to look out for your serial number. The bar code, it refers you to is the picture that is composed of just lines, it has some numbers written under it. That is the serial number of the refrigerator.
Here are a list of places to look at for the serial number:
  1. On the cabinet door jam,
  2. on the inside left or right wall of either the refrigerator or freezer,
  3. Behind the kick plate
  4. Behind the lower crisper drawer,
It sometimes used to be at the bck of the refrigerator. The part that faces the wall.
Hope this helped. All the best Elect_Comp
Sep 21, 2011 | LG Refrigerators
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
My L.G french door frige GR-B218WV ices up under the freezer drawer causing the drawer to jam or not close fully the seals seemto be in good order what can I do. regards Ern.
This is the common problem to everyone. Due to defrost failure. Check temp setting is not very low. Keep 5 degree.. Check thermostat, defrost timer are working properly. Now, manuyally press defrost switch or turn counter clockwise your thermostat. Then fridge shuts off and wait for sometimes to get complete defrost and then restart again by turning thermostat clockwise. Helpful?
Jan 30, 2011 | Refrigerators
Electrolux dishwasher wont lock but still runs, water sprays out of the door
check that the top basket wheels are not broken a rogue wheel in the runner can stop you pushing the top basket in. this stops you closing the door. also that the retainers on the end of the runners are in the right position and not jamming the door action. failing that you will need a new door lock..
Jul 30, 2010 | Electrolux Dishwashers
Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Mar 09, 2008 | Refrigerators
LG Refrigerator/Freezer Model GR-762DEQF
you will need to replace the fan the reason it stops it the door switch needs to be closed for the fan to operate. with the door open press the switch and see if that is in fact where the noise is coming from if so it sounds like the bearings are going out
Feb 16, 2008 | Refrigerators
LG LFC21760 Bottom Freezer French Door Refrigerator Logo
155 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
