Question about Dell Optiplex GX280 (99301) Motherboard
DELL Optiplex GX280 PC don't boot
Intel(r) Grantsdale-G PCI Accelerated SVGA BIOS
Build Number: 3314 PC Dev 04/12/2004 17:02:24
DECOMPILATION OR DISASSEMBLY PROHIBITED
Copyright (C) 2000-2003 Intel Corp. All Rights Reserved
  • 2 more comments
  • sblakely Oct 06, 2008
    I have the same issue and am not very technical....can someone help??
  • Anonymous Nov 26, 2008
    I have about 40 of the Dell Optiplex gx-280 minitowers and every one of the motherboards have gone bad - blown capacitors!!!!!!!!!!!!!!!!!! Dell would not replace them until they showed signs of leakage - even though everyone new they all would eventually go bad since I bought them all at the same time. Know they are out of warranty and I'm having trouble with the remanufactured ones!!!!!!!!!!!!!!!!!!!!!!
  • prashant1434 Apr 09, 2009
    i have sameproblem
  • dio dcs May 11, 2010
    More details please
This is what I did & it worked to solve this error message on my Dell Optiples GX-280. Intel(r) Grantsdale-G PCI Accelerated SVGA BIOS
Copyright (C) 2000-2003 Intel Corp. All rights reserved. I uninstalled all the ram except for one chip. I rebooted the system to to see if the one chip worked (ready to repeat the process if it didn't & thinking maybe it could also have a bad ram slot). The 1st chip worked & it went right into bios(clapping hands!!!) I then turned off & on the system...each time adding a new ram chip to see if any were bad, but to my surprise...none were...they all worked just fine after that(clapping hands & shaking head!!!)! Just to let you know...I had 4 sticks of DDR-2 4200 in it when I did all this...I know I know...it takes DDR-3200, but it will just clock it down to 3200 & still works just fine...trust me. Computer works fine now with no error messages what so ever...hope that helps~; )
Posted on Nov 19, 2009
  • munnacon2004 Feb 15, 2011
    thanks this worked for me.......... :-)
Please check for leaking or bulging caps on the motherboard on the system since the model is one of the affected optiplex systems. If so, you may have to call dell for replacement if it is still under warranty, if not, then you may have to contact any local computer shops to purchase motherboard (if available) or if you are techy enough some people were able to manage replace the capacitors themselves or ask for recommendation from Dell tech support on where to purchase the motherboard.
if there are no leaking nor bulging capacitors on the motherboard, please reseat components (hard drive, memory except for cpu), try known good components as much as possible and also the power supply coz these seems to be what causing the issue for system not booting.
I hope this one help.....
Posted on May 15, 2008
I didn't have my memory in matching pairs, slots, etc, duh... putting it in correctly fixed it for me. http://support.dell.com/support/edocs/systems/opgx280/en/ug/memory02.htm
Posted on Apr 17, 2012
I had the same issue. System would not boot all LED's on the back were blinking and none would remain on. I grabed another system that was working correctly and started swapping out parts. When I swapped with a good power supply system booted normally. I found some decent OEM replacement P/S here.
http://www.affordablesurplus.com/dell-PS-5251-2DFS-0F0894-power-supply-250.asp
Hope this helps.
Posted on Sep 11, 2008
Check your memory as well! Could be the wrong memory type
Posted on Jul 17, 2009
I have a dell dimenision 4700. when i power on, i get.intel(r) grantsdale -G PCI accelerated SVGA BIO build #3329 pc dev. system want boot up
"Hello, If that is all the computer does then the hard drive is bad or the software on the hard drive is messed up, you will have to repair or reload the software."
Oct 10, 2015 | Dell Dimension Computers & Internet
I have a Dell Optiplex GX 280. When I turn on my computer a black screen appears. What can I do?
check the hard disk to be powered and the plugs to be on ...and try again ...Go to bios settings by pressing del on start ..or the F key suggested on the screen on boot..In here locate the optimal factory defaults and engage them ..confirm and after that save the settings by pressing the F10 key and confim
This will make all devices to be set to the factory defaults..After that if it still does the same it means the windows installed on it ..is corrupted..or the hdd with the operation system is corrupted and the windows files can not be read so the boot can not continue...First try to insert a boot-able cd ..with the operation system on it ..and try to reinstall it ..Format drive C during the installation in ntfs quick mode..This will eliminate all bugs and strange things ..If the installation goes well ..it means the hdd is ok ..and will work ,, remember you will need all drivers for it and need to install them in order to function proper..so , the thing to be done is to get to the manufacturer support site and download them by model and operation system before beginning the operation ..cause once the installing being done ..you can not connect to the net without the LAN driver....
If the installing can not be done ..and during installation you are informed that the hdd is inexistent or ..corrupted...than you will have to change it ..
Cause it seam to stop the boot on the video card information it will be a good start to check the video card too ..specially if it isnt an on board one ..but a pci ..It may be damaged and this to be the reason for not booting right ..
Nov 10, 2011 | Dell OptiPlex GX280 PC Desktop
Cant do anything my computer wont go to the os
What you need to do my friend is remove the CMOS battery, then remove the power cord from the computer. Press the power button on the front of the pc, you might at this point see a temporary flash of the power LED (at this point the cmos /bios is now cleared and reloaded with the defaults.
Next, put the battery back in and then the power and boot to the bios. Just reload all settings as needed and you should be back in business!!!
Sep 19, 2009 | Dell Dimension 2400 PC Desktop
Bios Error Message
With the system off, open the side cover and re-seat the RAM. You may have one module that is bad.
Second, press F2 as soon as you see the Dell screen and see if you can get into the BIOS setup. Post back with the results please.
Mar 20, 2009 | Dell Dimension 3100 PC Desktop
Windows XP won't boot
sorry for my bad english
the problem may be your hardisk data cable.change your hardisk data cable.and also try this, remove ram memory and clean it and restore.
Dec 16, 2008 | Dell Dimension 3100 PC Desktop
Error: Intel(r) Grantsdale-G PCI Accelerated SVGA BIOS Build Number: 3314 PC Dev 04/12/ 2004
-Uninstall the video driver under ADD and REMOVE programs
-Download the latest video driver from support.dell.com, use the service tag of the system andlook for the correct video driver and reinstall video driver
-Reboot system
Oct 06, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
4,425 people viewed this question
Alun Cox
