Question about Solis Master 5000 Espresso Machine
Just bought it... overtemperature keeps coming on. Is it screwed?
  • 4 Answers
Maybe not; this will happen if you press the blue button or press the ent button twice. otherwise, yes.
Posted on Sep 13, 2010
Electric ryobi model RY42110 just quit working wont start
Unfortunately you have to start at the beginning. I have found that there is no common problem when it comes to these. If you have a multimeter and a bit of knowledge, start by tracing the power or continuity and see where it stops. Some have a overtemperature thermistor that is a oneshot device and must be replaced. Unless you can smell that the motor is burnt out I would guess it will an easy fix. The problem is gaining access and finding. Sorry not much help but good luck. Cheers Bob
Nov 08, 2016 | Ryobi Garden
2007 jeep compass 4wd light flashes overtemperature code after changing front wheel bearing
How tight did you make the nut holding the bearings onto the spindle? Did you change the bearing races too? Recheck the torque values to see if they are correct. an old race on a new bearing will cause temperature problems.
Jul 08, 2014 | 2007 Jeep Compass Limited
P1258 code
could be a thermostat, head gasket , not fill properly,
P1258 is: engine overtemperature protection, or low coolant fuel disable
Sep 19, 2013 | 1996 Cadillac Eldorado
It turns on for 2 seconds then the overheat light comes on and it will not do anything
does the main fan come on at the startup time.
The overtemperature sensor may have failed and appears as a high temperature all the time.
Apr 19, 2011 | Epson EX71 Projector
I have a H27A optoma projector, glass inside has broken, globe is not broken projector does not work and fan and globe do not come on
Might as well unplug it from the mains and carefully remove the cover and look inside to see where all the damaged optical bits are. Then you can figure if it's worth fixing it. Sounds like a fuse or overtemperature switch may be stopping the unit from operating anyway.
Apr 10, 2011 | Office Equipment & Supplies
My dvd cd-rom,everytime i turn around i keep having to reinstall
I think you mean it comes out? If so there should be a screw hold under 1 of the covers underneath your laptop where a screw can be placed.
May 20, 2010 | Acer Aspire 5500 5570-2609 Laptop
Overtemperature
Flush the machine with water a few times with cold fresh water, by running the hot water cycle.
Apr 06, 2009 | Saeco Vienna Digital Coffee Maker,...
My xeros 214 copier has gone wrong and the no U4 is coming up, i do not have a manuel thanks terry
A U4 is a fuser overtemperature.
You can hold down the "0" while powering the machine on. That will enter the machine into diagnnostics.
Next enter code 401, and press start, See of that clears the problem.
If it does. Remove the fuser and clean the buildup off the thermistor.
If it doesnt you will most likely have to replace the fuser.
May 15, 2008 | Xerox Office Equipment & Supplies
Kitchenaid superba refrigerator not keeping cold
press reset botton for five times and it will reset kiki
Oct 12, 2007 | Refrigerators
Solis Master 5000 Espresso Machine Logo
176 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
