Question about Krups BeerTender B95 Beverage Dispenser
Beer tender purchased in Dec of 09. Replaced the keg with a new one (slightly cold) last night approx. 8PM. It is now 12:15 pm the following day and it shows that the keg is not cold (red temp bar) and it has been running none stop! Thanks in advance Nola
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
Peltier/thermalelectric plate may be bad. you may need to replace. Very common in these thermoelectric units to go bad. It is approx. a $5 dollar part.
Posted on Sep 10, 2010
I have water in the bottom of my Beverage air kegerator
Water in the bottom of Kegerator - Dispense Forum ' Discuss Keg ...
www.micromatic.com/...kegerator.../kegerators-kegerator.../5907-water-i...
Jul 18, 2009 - I have a Beverage Air 2 with front ventilating compressor. When I .....Also I do refrain from opening my kegerator door between kegs. I have ... need some help with BM23 - Dispense Forum ' Discuss Keg Beer ...
Aug 1, 2013
New To Me Bev Air BM23
Jul 16, 2012
Beverage-air condenser / thermo
Dec 31, 2009
Beverage Air BM23 Door Not Sealing
Aug 3, 2009
More results from www.micromatic.com
Kegerator leaking water inside - Home Brew Forums
Dec 28, 2015 | Beverage Air Refrigeration DD58C-1-B - 59...
Beertender b90 level indicator flashing. Cooling indicator is working fine and and the temp is 42 degrees.
42 deg is too warm for beer keg it should be 32 deg possible a warning temp too high
Nov 20, 2013 | Refrigerators
How do you properly tap a keg of beer?
The following site will explain all of the details you need to know about tapping beer kegs.
http://howto.wired.com/wiki/Tap_a_Keg
Feb 03, 2013 | Wine & Spirits
How long does a tapped keg of beer last?
This depends on the type of system you are using to tap your keg. A standard tap given to you with a keg will not last very long, just less than a week. If you are using a proper kegorator CO2 system, your beer will last at least two months, if not longer depending on the temperature of your fridge.
I have a danby kegerator and i just tap the keg and all its doing is spitting air with some foam and i tasted the beer it was completly flat i need help asap!!!
try changing kegs sounds like the tube in the keg is broken the keg has a tube that runs to the bottom of the keg inside and u push air into the keg to push beer thru that tube and into a cool glass and down to ur gulletbut it sounds like u have a defective keg or an empty keg
Feb 24, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
I have an older beer cooler. the fan costantly runs but the refrigeration part of the beer cooler doesn't keep the keg cold? ? ? It's refrigerate is r12 cooled. Do you think I could just re charge the...
You would need to be a certified refrigeration technician to even buy R-12, since it is a CRC refrigerant. The kegerator probably doesn't have service ports so you would either have to braze a low-side port in or use a piercing valve, and fix wherever the refrigerant leaked out from. Basically, by the time you pay a refrigeration tech to do all this, it isn't worth it and you would be better off buying a new one
Jun 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
New danby kegerator - tastes like rubber hose
There is a check valve inside the coupler of the danby kegs that cause this problem. The valve is mainly there to prevent beer from back-flowing when changing the keg. Next time you change your keg check for a little black plastic retainer and also a small white plastic ball inside the coupler. Remove those (or just smell it) and you should notice that this is the taste/smell your beer has. I removed mine after this discovery, and there isn't any issues with the taste/smell since. I've heard this is a common issue with the Danby D coupler systems. Also, you won't have any issues with beer backflow when you change the keg, provided the line going to the tap is empty (which usually is if keg is kicked).
Dec 30, 2007 | Danby DKC646BLS Full Size / Pony Beer Keg...
Danby Beer Keg dispenser fridge.
Draught (or Draft) beer is almost always un-pasteurized and therefore is more fragile. It should be consumed after being "tapped", and is generally truer to the flavors of the ingredients as pasteurization exposes the beer to heat and changes the flavor profile. Always use brewery approved beer line if you want to have foam free fresh tasting beer. Serving it through a plastic tube from the hardware or discount store or the plain vinyl tubing in your beer tap system you will wind up with a foamy, off tasting beer. Real draught beer is not pasteurized. It must be kept refrigerated between 35F. and 44F. A beer will become wild, turn sour and cloudy in a day or two. Below 44F. a keg of draught beer should last 20-30 days before it loses it's fresh brewery taste and aroma. Craft beers (micro brews) tend to have a shorter shelf life and you should contact the brewery for their recommendations. Why does my beer foam up? The 3 most often causes of beer foaming up are: The temperature of the beer keg The balance of the draught beer system pressures The cleanliness of the draught beer system I would suggest that you clean or replace the beer transport tube...
Aug 11, 2007 | Danby DKC645BLS Compact Beverage Cooler
Krups BeerTender B95 Beverage Dispenser Logo
870 people viewed this question
Top Krups Refrigerators Experts
Tom Chichester
Terry Hair
JonSnell Electronic
JonSnell Electronic
Are you a Krups Refrigerator Expert? Answer questions, earn points and help others
