JVC AM FM CD DET FACE CAR STEREO Logo
Posted on May 11, 2008
I just want to ask... thanks
My car stereo is experiencing a damaged on its audio output
do it has a sound but has no bass... and its so noisy...
wat should i do?
please help me;;;;
thanks
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on May 11, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
12614
Points
17
May not be an issue with the unit itself. Any blown speakers? Any shorted wires? It would be awesome to see if it worked in another vehicle or on a test bench. Then you would isolate either the vehicle or the radio as the problem.
My 12 pro is paired to my Pioneer AVH2800bs but there's no audio from the phone. Pandora works fine, just no audio out of my phone
If you are experiencing no audio output from your iPhone 12 Pro when paired with your Pioneer AVH2800bs, there are a few troubleshooting steps you can try:
  1. Check the volume levels on both your phone and your car stereo. Ensure that the volume on your phone is turned up and that the volume on your car stereo is not muted or turned down too low.
  2. Check your phone's audio output settings. Go to Settings > Sounds & Haptics and make sure that "Change with Buttons" is turned on. This will allow you to adjust the volume on your phone using the physical buttons on the side.
  3. Try disconnecting and reconnecting your phone to the car stereo. Sometimes a simple disconnect and reconnect can fix the issue.
  4. Check if your car stereo has any firmware updates available. Visit the Pioneer website and search for your specific model to see if any updates are available.
  5. Try using a different audio cable to connect your phone to the car stereo. The cable may be faulty or damaged.
If none of these steps work, you may want to try resetting your phone's network settings or resetting your car stereo to its factory settings.
4answers
Maudio 192 output
You need the plug/cable that inputs to your mixing desk and outputs from your sound card.
I have an 2007 Subaru Outback with the standard Kenwood stereo system. I noticed the boards in the facia are separate but one small connection between the 2 can this be removed?
Question edited for clarity.
Question moved to model category
Stylyn Car Audio - Subaru Outback 2007 Stereo Upgrade and ...
https://m.facebook.com > ... > Stylyn Car Audio > Videos
1:10 ... and Climate Control System. We've just installed a new Kenwood head unit to this. Subaru Outback 2007 model with all new fascia panels
Facebook Ā· Stylyn Car Audio Ā· Jun 11, 2021
2005-2009 Subaru Legacy and Outback - Crutchfield
https://www.crutchfield.ca > ... > Research Garage
We'll tell you all about: The factory stereo system; Removing the factory radio; Removing the factory speakers; Adding more bass; Other options for your Outback ...
How do I adjust time on 2001 magna radio
Unknown.
Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I have a problem with my z-5500! the bass is really bad, on all the effects. my friend has the same pare of speakers han his bass is really good. what should i do???
Always make sure that your computer settings for audio are checked and set accordingly and that all the equlizers and audio programs that are installed and controlling your audio sound output are accounted for and adjusted properly.
How do you install an audio output device?
this depends on what kinda audio output you want to install ..but the general idea is to get the audio signal from the computer from the green out in the back on the sound card (it is a 3.5 jack ) ..and there is the stereo out-put for the computer's sound..It can be amplified in any device that has a stereo input on 3.5 jack ..
if you want something more complicated..the map of the out-put (the scheme) will be shown in the sound manager (of teh driver ) ..when you make the output changes..This is on a color code..and can be 2+1...3+1..4+1..and the surround 5+1..when you choose surround 5+1 from the sound manager ..it is shown all 3 outputs and the role they play ..bass+center ...Front ...and rear ..they are 2by 2 stereo paired on left and right ..
How would I attach my hi-fi Goodmans Speakers to a LSD TV
Your best bet to improve the bass is to attach the audio output of your HDTV to a stereo unit and amplify the audio with the amplifier. Attaching the speakers to the HDTV will not improve the sound much. Sorry.
Bass control stopped working
on rockford amps, the bass control knob needs to be connected to get the maximum output (+18 db gain i believe). If you did this to the power wires, then yes, you may have at least damaged the bass control knob. Try replacing this to see if you get all of your gain back. If not, then you have damaged something inside the amp...maybe a capacitor or power supply inside. If that's the case, you'll need to get the amp looked at by an electronics repair technician or local stereo shop.
2answers
Subwoofer playing in stereo sound
i think uyou have to got to stereo mode and turn ion the subwoofer option. i have a h/k thats wart i had to do in evvery mode is designate the s/w. rating please
Patio speakers
connect them to the front left and right outputs.connecting them to the sub-woofer will give poor sound because it only pick's up bass sounds during playback
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
