Question about NorStar T7316E Corded Phone
Where in the world can you find the plastic cover for the keys on a 7316 phone? The long see thru plastic label covers. I have about 6 phones that cannot be used because they are lost
    President:
  • NorStar Master
  • 860 Answers
I usually go to desi.com to get both the plastic windows and the paper inserts.
Posted on Sep 03, 2010
Keypad 5130c
i expect that some of the digit in that particular cellphone is not working. if you want to clean your key pad then you need to open it. removed the battery cover, the battery, back cover, untill you see the 6 screws that holds the front cover. Removing the screw will automatically remove the front cover and will show you the key pad. if you want to check the digit which is not working then you fix the battery and holding it firmly press the power On button. assuming that you already know what digit is not working then you can proceed by removing the plastic cover of the keypad and by using pencil eraser you can clean it.. from 0 - 9....
Sep 22, 2013 | Nokia 5130 Cellular Phone
Tip
Samsung SGH-X150 disassembly, take apart.
How to take apart Samsung SGH-X150 Black Cell phone:
Time Required: 10 to 15 minutes.
Tools needed: Precision tools, Small philips screwdriver, Case opening tool or a plastic stick, or your fingernails.
Difficulty: Easy
Step 1. Remove the back cover, battery and sim card.
Step 2. Are you replacing the screen? Or are you looking into the keys or the mainboard?
If you wish to get to the display Go to step 3.
If you wish to get to the keys and the mainboard Go to step 4.
Getting to the display.
Step 3.
To replace the display, unscrew two Philips screws from the bottom of the display, they are under two soft tabs that you have to remove from on top of them.
Step 3.1. Use your fingernails or case opening tool to open the display cover.
Begin from the back and work towards the top, open the back and the sides, do not force open the front its held in place from there and you need to pull the plastic cover off looking at the picture below to the left
Step 3.2. After the cover is off, you get to the back of the display, on the top you have a few speakers etc.
Step 3.3. From the bottom release the connector by carefully pulling the board upwards.
Step 3.4. From the top, use a flat screwdriver to get the speakers out of their slots so the circuit board with the display comes off.
Step 3.5. The display is now free from the cover, you can remove it from the case.
Getting to the mainboard and keys.
Step 4. With the back cover, battery and sim card out. On the back of the phone, there 4 Philips screws. Marked with red dots.
Step 4.1. With the 4 small screws out, start using the case opener tool or your fingernails to release the plastic casing from the back of the phone. It is held in place similarly as the top of the phone in step 3. Begin from the sides and the bottom of the phone, the top is held in place and won't open until the sides and the bottom are lose, then you can disconnect the top part.
Step 4.2. As you release the back cover, on the side the up and down plastic key drops out remember to replace it properly when you assemble the phone.
Step 4.3. Disconnect the display cable, the mainboard is held in place by plastic clips on the top, carefully release the mainboard, you may break off a clip or two from the case, if that happens, no worries. The screws will still hold the casing together. the area is again marked in red.
By now you should have the phone completely disassembled / taken apart.
We are done.
Assemble in reverse order. Total 6 screws in this phone, 2 on display 4 on case. Held in place mostly by plastic clips.
Thank you for reading, I hope this has helped you.
-Ekse
on Mar 14, 2010 | Samsung SGH-X150 Cellular Phone
Iwant to change screen on phone
    • 1 Power off your cell phone completely by holding down the power button for four or five seconds. Turn the phone over and remove the back plate. Slide your fingernail underneath the battery and pop the battery out of the phone.
    • 2 Locate the SIM card if your mobile phone is a GSM style phone. Pull back the metal covering over the SIM card and then remove the card. Set it aside.
    • 3 pixel.gif Removing the RF grommet Find the plastic RF grommet at the bottom of the phone near where the battery was located. Grab the grommet with a pair of tweezers and remove it from the phone.
    • 4 pixel.gif Removing the bottom cover Insert the tweezers into the hole on the side of the phone opposite from where the RF grommet was located. Use the tweezers to pull up on the latch inside the hole to unlock the bottom plastic antenna cover. Lift the cover off of the phone and set it aside.
    • 5 pixel.gif Metal plate Pull out the screws along the edges of the phone using the Torx screwdriver. Take the metal plate off of the phone.
    • 6 Flip the phone over so that you can see the LCD screen. Slide the edge of a flat head screwdriver in between the seam of the plastic cover on the bottom of the phone. Wiggle the screwdriver up and down gently to unlock the catch underneath the plastic cover. Lift the entire plastic cover up and then off the phone.
    • 7 Find the latch on the side of the LCD screen and unlock it with the tweezers. Pull the screen slightly off of the phone and then disconnect the cable running from the screen to the phone. Lay the replacement screen back into the phone and attach the cable.
    • 8 Set the plastic cover back onto the phone and then flip it back over. Re-attach the metal plate and put the screws back in. Push the RF grommet back into place and then place the SIM card and battery back in the phone. Put the plastic cover on the back off the phone and then power it on to ensure the screen is working correctly.
Tips & Warnings
  • If your cell phone is a CDMA style phone, such as those provided by Verizon, it will not have a SIM card for you to remove.
  • Replacing the LCD screen on your mobile phone voids your warranty provided by the phone's manufacturer.
Feb 22, 2012 | Sony Ericsson Cell Phones
How to remove the housing of N77 phone
  • ower off your cell phone completely by holding down the power button for four or five seconds. Turn the phone over and remove the back plate. Slide your fingernail underneath the battery and pop the battery out of the phone
  • Locate the SIM card if your mobile phone is a GSM style phone. Pull back the metal covering over the SIM card and then remove the card. Set it aside
  • Removing the RF grommet,Find the plastic RF grommet at the bottom of the phone near where the battery was located. Grab the grommet with a pair of tweezers and remove it from the phone
  • Removing the bottom cover, Insert the tweezers into the hole on the side of the phone opposite from where the RF grommet was located. Use the tweezers to pull up on the latch inside the hole to unlock the bottom plastic antenna cover. Lift the cover off of the phone and set it aside
  • Metal plate, Pull out the screws along the edges of the phone using the Torx screwdriver. Take the metal plate off of the phone
  • Flip the phone over so that you can see the LCD screen. Slide the edge of a flat head screwdriver in between the seam of the plastic cover on the bottom of the phone. Wiggle the screwdriver up and down gently to unlock the catch underneath the plastic cover. Lift the entire plastic cover up and then off the phone
  • Find the latch on the side of the LCD screen and unlock it with the tweezers. Pull the screen slightly off of the phone and then disconnect the cable running from the screen to the phone. Lay the replacement screen back into the phone and attach the cable
  • Set the plastic cover back onto the phone and then flip it back over. Re-attach the metal plate and put the screws back in. Push the RF grommet back into place and then place the SIM card and battery back in the phone. Put the plastic cover on the back off the phone and then power it on to ensure the screen is working correctly
Nov 20, 2011 | Nokia N77 Cellular Phone
I have no electronic key for my car and the alarm goes off everytime i try and unlock or start my car how do i bypass the alarm without having to order an electronic key from the dealer ship?
1. Open the Fuse box and find out the relay called "ST".
Fuse Box
The Fuse Reference
2. Then you will see the relay label with 1, 2, 3 and 6.
The Start Relay Label With 1236
3. Unplug the relay and then turn the car key to on, ready a wire which both end plastic cover has been cut.
4. Connect both end of the wire to the relay slot 3 and 6. Once the car started then disconnects the wire from the relay. khaled_h_7.jpg
Unplug The ST Relay And Connect By Using A Wire
Jun 04, 2011 | 2001 Dodge Durango
My l6 fell and now the screen is blank what should I do
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
What you have to do is simple.
1. Remove the battery cover, battery and SIM
2. Use the screwdriver or tweezers to gently pry off the RF grommet located on the antenna cap (below)
  • Removing the antenna cover:
    3. Carefully use the flat end of the tweezers to release two latches on the top end of the antenna cover, then carefully lift the antenna cover away from the phone.
  • Removing the transceiver PC board shield:
    4.Using the T5 screwdriver, remove the 6 housing screws from the phone. Set the screws aside for re-use (see Figure 10).
    5.Lift the metal shield away from the phone.
  • Removing the housing:
    6. Insert the plastic shim between the front housing and the chassis assembly. Slide the plastic shim around the phone between the front housing and the phone to release the housing catches along the sides of the front housing
    7. Carefully lift the bottom end of the front housing over the phone. The earpiece will still be connecting the front cover to the rest of the phone at the top of the phone so be careful
  • Removing the earpiece speaker from the front housing:
    8. Use the plastic shim or tweezers to separate the earpiece speaker from the front housing
  • Removing the LCD screen:
    9. Use the tweezers to release the display module assembly latch located at the side of the display module
    10. Lift up the top edge of the display module
    11. Carefully thread the display flex cable through the slot in the chassis assembly and lift the display module away from the chassis
Replace the old screen with new an
d reverse the whole procedure for reassembly
Take care
Jun 18, 2010 | Motorola Mobility L6 Cellular Phone
How do I change a name on an internal extension?
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key. (or the clear key to erase)
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Nov 09, 2009 | NorStar M7208 Corded Phone
GE 2-9451
You need to have the phone join the network that you are in by assigning a station address to the phone. If this the only phone that you have like this, simply remove the plastic cover where the station addresses are to be printed. Beneath this cover there is a small button labled "PROGRAM BUTTON". Use a pen, press this button, then press "INTERCOM" and then label your station (01-16) followed by pressing the # key. This will make the intercom button flash on and off red and then it will stop flashing.
I hope this helps!
Aug 27, 2008 | GE RCA 4-Line Speakerphone
NorStar T7316E Corded Phone Logo
74 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
