Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Ice magic pluss stopped making ice there is ice in it but itm will not drop.the water supply is ok
    Brigadier General:
  • 3,917 Answers
Hi
Please check this link regarding your query:-
http://www.repairclinic.com/Refrigerator-Troubleshooting#Theicemakerhasaproblem
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 03, 2010
Refrigerator icemaker repair
The ice maker does its own thang. All it needs is power and a good water valve to supply the water. Also you paid the water bill helps too. Anywho when the temp in the ice maker mold drops below 25f the harvest cycle begins. The mold heater is activated and loosens the ice. When the ice starts moving the heater shuts down and the motor carrys over and drops the ice. The ice maker then asked for and gets water from the water valve. So what goes wrong? Watervalve solenoid burnt out, water valve dripping like a faucet make a stalagmite in the fill tube blocking fresh water to ice mold. If that is ok then something inside the icemaker went haywire, replace it. When replacing the ice maker replace the watervalve. Note: if temp inside icebox freezer does not get to 25f any ice maker new or existing ain't gonna make ice. Be sure to clean the coils down by the compressor and the kickplate so the maximum amount of airflow is running down there and make sure the cardboard panel back there is in place.
Sep 26, 2013 | Dryers
Kenmore WR30X0318 Ice Maker Stopped Making Ice
The ice maker uses a internal thermostat that starts the cycle of dropping the ice and refilling with tap water. If your water control valve works filling the ice maker then the problem is the ice maker itself that will need replaced. Unfortuantly the ice maker you have has no rebuildable parts and will need to be replace with a=> WR30X10093 Ice Maker Assembly
Or here=> WR30X10093 Ice Maker Let me know if you have questions, Thanks Sea Breeze
Nov 14, 2012 | Kenmore Refrigerators
My ice maker stopped working a couple days ago..it had been fine until then?
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Apr 07, 2011 | Magic Chef Refrigerators
The ice machine stopped making ice
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
A strainer before the inlet valve can also get stopped up restricting flow.
Jun 26, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice maker stopped making ice. Water supply is ok.
Your problem could be either the water valve solenoid for the icemaker (usually must replace the entire water valve) or it could be the icemaker itself.
Contact an appliance service company.
Feb 15, 2010 | GALAXY Microsystems 25.4 cu. ft....
GE Profile Refrig model PSC23SGRC ice maker stopped making ice. Water is ok, just stopped? Is this common? Its only 4 yrs old
Your model has an electronic ice maker part number Click Here=> WR30X10093 When the electronic ice maker fails you usually need to replace the complete ice maker. You can test the ice maker by filling the tray with tap water. If the water freezes aand then drops the ice then the water control on the back of your refrigerator is the reason. The water control valve is Click Here=> WR57X10032 Either way let me know your results, Thank You, Sea Breeze
Jan 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water does not dispense and will not make ice
yoiu need to thaw out the rfesevour inside the refrigerator with a haior drier son that the water can flow to the soilinoids and then the ice mAker and dispenser.
Apr 07, 2009 | Refrigerators
The icemaker in my Bauknecht KGN 7010 F/F has stopped making ice
First you need to find out if the lie is blocked. Disconnected water feed and try to run water through it into a bucket or sink. If you get water it is a valving problem. Also make sure the filter is clear.
Dec 29, 2008 | Freezers
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
195 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
