Question about Refrigerators
Freezer works fine, there's no airflow into the refrigerator compartment. There's probably a blower or blower switch that's not behaving properly, right? How do I fix this? I've tried a half-dozen "authorized" whirlpool repairmen, but they can't keep their appointments.
  • edick Sep 03, 2010
    Neither of these two recommendations was sufficiently relevant to be of any use. I've spelled out a specific problem and would appreciate a reply directed at that problem and not an entire tome of irrelevant material.
  • 2,272 Answers
There is no blower. There is actually a fan in the inner back panel of the freezer. First the freezer section gets cold. Then when the freezer section gets cold and reaches to the end of its cooling limit. Now the actual procedure starts, this procedure is called defrosting. Because the freezer is cold so the ice is got collected in the inner coils of freezer, now to melt this ice from the coils the defrost cycle takes place. When the defrost cycle takes place, at that time the coils gets heated up and the ice melts. The ice starts melting and water starts passing from the drain line and this melting water gets collected in the compressor pan. Now in the freezer there is a fan, in the inner section. This fan keeps the heating coil bit cool and blows the cold air from the freezer section to the refrigerator section. So the cool air passing from freezer to refrigerator. This air circulates and the refrigerator gets cold. As per the unit this defrosts cycle takes place twice or thrice in a day. It’s an auto defrost procedure. And when ever the defrost cycle takes place the cold air from freezer enters the refrigerators. This air enters from the dampener in between the freezer and refrigerator section. If this dampener is got clogged then air will not enter and the freezer will be cold but the refrigerator will not get cold. But if in your unit the dampener is checked and its cleaned. Then the other possibility to check is the fan in the freezer, if this freezer fan is not running then the cold air from freezer to refrigerator will not get blow to pass through dampener and also the coils in the freezer compartment will get hot. But if the fan is checked ok, but if you see too much frost build up on the coils and the frost build up is causing the fan not to run or run very slow then this frost is the problem. Take a hair dryer and apply it on the frost, but take care you do this with unit unplugged from power outlet. Now when all the ice /frost got melted from hair dryer then reconnect all the parts and reconnect the power to the electric out and then check. If still the same problem is seen, then the possibility is the drain line, from where the ice melted water passes from coils to compressor pan. There is a drain line at the back of the unit. That drain line is internally clogged.
So why this drain line clogged, this drain line gets clogged because the ice cubes get blocked in this drain line. Why this ice cubes blocked in drain line, because the auto defrost system which has to take place in the unit, is not taking place, or if its taking place, then its not taking place, when required. So you try manual defrost procedure first, the evaporator coils never go bad or faulty mostly it only stops working if the over load of ice frost gets collected in between the coil and the evaporator fan due to things the coil actually does not get required hot and this makes freezer bit more cold and refrigerator very low cooling or may be hot. also the other air ventilations gets blocked due to evaporator coils stop working .to resolve this issue the only best option is to empty the fridge/freezer unit and unplug the unit from main power out let keep the door open of the unit and leave it for 24 hours this melts all the collected ice in the coil as well as in the air ventilation area. After that clean the inner area of unit with a dry cloth and then plug in the connection and turn the unit ON keeping the temperature at normal settings. then check out after two hours if the unit works proper the evaporator coil was the fault and that got cleared from the unit by defrosting .but if the problem is same as before after two hours when you check then the defrost system is faulty. The defrost timer, the defrost heater/thermostat needs to be checked and replaced. Now i will explain what is defrost timer .the defrost timer is the part which controls the cooling and defrosting in refrigerator .it actually spins as the coldness in the unit. After the temperature reaches to certain coolness it spins back wards and defrosts .if the defrost timer is faulty it will not spin properly and all cooling and defrosting system of the unit will get misaligned. if the timer gets faulty the cooling will reach till over frost and then the fan the coils in the unit will get blocked due to ice built-up and over current will be exerted by the unit to melt that ice. And in this melting ice procedure without defrost timer the unit stops completely .it can effect any section lower or upper or may be both. so the defrost timer at present needs replacement. It’s like a mini plastic box. Color is mostly black or white or creemish.
The cost of timer is near to $40.you can get it from
www.repairclinic.com .In some models there is automatic defrost board instead of defrost timer. The function is same for board the parts. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 04, 2010
    Brigadier General:
  • 3,917 Answers
Posted on Sep 03, 2010
Door wasnt closed properly over the weekend fridge starting to cool, no ice, freezer works display reads Er-1F
The door being open probably caused ice to build up on the evaporator, not allowing air to flow properly between freezer compartment and refrigerator, unplug the unit for a few hours and place a fan aimed at the freezer compartment to help it defrost then plug unit back in should be fine.
Sep 28, 2015 | Kenmore Refrigerators
Where is damper door in a kenmore refrigerator model #9510681 side by side
If you can't see the damper door, it is most probably shut, possibly frozen or not working. Top of middle section, allows airflow from freezer to fridge part. Switch thermostat off, wait 20 mins, switch back on. If damper doesn't open, check stat and damper motor.
May 30, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint hsm25gfta sa
Check for a device called a damper in the refrigerator compartment. It controls how much cold air from the freezer is sent to the refrigerator. In my recent experience with a bad damper in a GE side by side, the damper door broke and the refrigerator got too cold. The damper door could be broken or the motor failed and left the door closed. If this happens, the refrigerator compartment will not get enough cold air from the freezer and run warmer than normal. Check the appliance parts web sites for a breakdown of you model. You may find it's a major disassembly to get to the control. What I did was remove the bad part and control the airflow from the freezer with a partial blockage until I got a new part and the time to repair it.
Apr 17, 2014 | Refrigerators
My kitchen aid frig is not working. the freezer side does work is it worth fixing model kitchenaid ksrp25fnss00. i bought ot 4 years ago
I would suggest you may have an airflow problem. As the frig compartment receives the cold air from the freezer compartment and you say the freezer is working,then you must have an airflow problem .Check the airflow dail next to the thermostat that has numbers. Normal setting is the middle setting on both airflow dail and therm.Allow temp to stabilize and recheck.hope this helps.
Sep 26, 2009 | Kenmore 72912 / 72914 / 72919 Bottom...
Amana DRB2201CW refrigerator does not get cold
You may have an obstruction in the air vent from the freezer compartment to the frig .there should be an airflow adjustment next to the thermostat. Middle setting is recommended. Since you say the freezer is working properly, I cannot see any other possibility. hope this helps.
Jul 28, 2009 | Amana ARB2257CSL Bottom Freezer...
GE GSS25LSMFBS IS FINE IN THE FREEZER SIDE BUT FREEZES IN THE REFRIGERATOR SIDE.
Sounds like you need to adjust your airflow into the frig compartment. There are two adjustments for air flow on a side/side one at top next to thermostat and one at bottom next to crisper. If your freezer is working properly like you say then you just simply need to balance the airflow to get the proper temp of just above freezing to 40 degrees
Jul 27, 2009 | GE Profile Arctica Stainless Steel Top...
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Freezer is working but fridge is not
My friend your Ref need a new blower motor.
Okay, your refrigerator is devided into compartment.
Freezer is your primary compartment where cooling core is located, no need fan to make be cold.
Your refrigerator side is the secondary compartment depandan on a little circlulation fan motor to deliver the cooling through it.
If your fan not woring then your refrigerator won't get cold.
Feel free to email me if you need to know how to replace the fan motor. nguyen@ite.net
Jun 09, 2009 | Refrigerators
Freezeris -1 fridge 47 degreeze F
I'd check all the venting make sure there is no plastic bags blocking the vents in the freezer and or fridge compartments. for some reason there doesnt seem to be proper airflow.find the fride door switch and hold it in the closed position with the door open and feel for airflow around the fridge vents. If theres none or very lttle you might have a defrost problem. Check for frost on the back wall inside the freezer.
May 20, 2009 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
