Question about Maytag Washing Machines
Maytag Model A612 listed 745G Series 04 Serial # 031109 TG Screching noise and smell rubber of electric lines burning and the tub won't turn. How do we fix it?
  • 958 Answers
SOURCE: maytag washer sqealing
hi Garrett,
sounds like a frozen gearbox. check the pulley that is being driven by the motor or by the secondary belt that you are saying. it could be the gear box broke and would not spin. another thing to look at once the gearbox is down is the brake mechanism. it could have broke down and would not run because the brake is not yet released.
tnx 4 using fixya,
drcool
Posted on Nov 14, 2008
JR JR
  • 116 Answers
SOURCE: empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Posted on Nov 30, 2008
kachbibi1
  • 979 Answers
SOURCE: LOUD NOISE AND BURNING SMELL
How old is this dryer? If it is older that 15 years get a new one. You don't want to deal with the headaches. The motor may be going bad on it and the wiring could be melting. I assume it is not working now. Have him check the breakers. Make sure the connections are o.k. in the back. Clean out the lint piping and look for lint underneath it as well.
Posted on Jan 14, 2009
  • 54 Answers
SOURCE: burned belt?
Yes, smell like your belt.. if there is water in tub, try to get it out... (wet vac)... slide your washer out and tilt it back so you can see under... there should be 2 belts.. 1 for gear and 1 for water drain pump... and you can check Sears.com for parts.. good luck...
Posted on Jan 23, 2009
  • 22 Answers
SOURCE: burning rubber smell and the dryer will not turn on
sounds like you need a new belt for your dryer, the smell of burning rubber is the belt slipping, thats my guess
Posted on Feb 09, 2009
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Won't Spin Drum
The problem could be a list of things . Let's start checking the belt , it coul be that the belt is broken or something is keeping it from doing its job ( a piece of clothing coul be stuck) due to the burned rubber smell you detected. It coul also be the electrical door switch and After checking the three first steps then comes the motor part lets hope is not . Good luck
Nov 20, 2013 | Maytag Centennial Series MEDC300XW
Maytag oversize capacity washer just finished filling up the tub with water. Then it had a burning rubber smell. I shut it off and on a bunch of times and there isn't even any sound. (like the mot
You need to observe and check after disconnecting the power , touch the motor, the element area or the control panel or the valves/pump.
If you notice any heat on these , it can be the culprit.
You can proceed to remove the suspected part to discover what was the reason for the burning rubber smell.
Click this link: Element
Jan 25, 2013 | Maytag 3.3 cu. ft. Oversize Capacity Plus...
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
Maytag la23cs. As spin cycle starts a screeching noise begins and a burning rubber smell
hi the first thing i would check is the pump if it not the pump may be tub baring witch some special tools to replace jim
Oct 20, 2010 | Maytag MAT12CS Top Load Washer
Maytag Atlantis washer
is the smell rubber or electrical? the pump could be seizing on it and burning the belt. check this out first.
Oct 25, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Burned belt?
Jan 23, 2009 | Maytag SAV5710 Top Load Washer
Maytag Washer Model: > LATLAT9457AAM Problem experienced: > High pitch sqeaky noise during spinning (draining) cycle. > Rubber burning smell(from transmission belt?) > Pulleys move OK with...
Most probably the bearings heating, which in turn heats the rubber seals and causes the belt to slip.
If there is no noise of metal on metal, you may be able to grease the bearings to get some more life out of them.
Taking the drum out is not an easy job though.
Jul 07, 2008 | Maytag Washing Machines
Washing Machines Logo
216 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
