Question about Telex Airman ANR 500 Headset
The anr doesn't work on my telex anr 500 headset. what trouble shooting steps should be taken to pin point the problem.
2 Suggested Answers
gopakumarg43
  • 74459 Answers
SOURCE: I have a Telex Headset
Hello
You can't use it. The wiring scheme is different to each other. OK.
Posted on Mar 14, 2011
Sound became muffled(only lower frequencies) in both ears
An equalizer circuit or filter? No idea where this would as you only give the result not total environment.
Apr 01, 2014 | Telex Airman 850 Aviation Pilot Anr...
Does not work with telex 850
Don't know if you are using the PA-97 adapter, it should work without any problems. I would check the potentiometer "gain" adjust on the microphone assembly. Hope this helps ;)
Jan 30, 2014 | Pilot USA Fixed Wing Headset to Airbus...
I have a 2003 Ford Windstar. Replaced brakes and bled them. Brakes still mushy. What next?
change brake fluid completely and bleed out starting at the furthest point to the nearest point to master cyl.Let sit overnight and bleed nearest point to master cyl as air rises to highest point.
Oct 19, 2013 | Telex TR300-7127-XXXXX Single-channel VHF...
I have a telex airmen 850. I tried calling to see if it was still under warranty- with no help. It's $200 flat rate fee to ship it there... Is there somewhere else I can send it to be fixed? It was working...
Don't know why answers for different type of headsets shown up on a question about the Telex 850. Probably there is an issue with the cord. The cord has two shielded "double" wires on each pair. The ones for the mic are "white" and "light blue". May be one is cut preventing the mic to work. Look around for a local avionics shop, they should be able to fix it. Hope this helps ;)
Apr 19, 2011 | Telex Radio Communications
Hi, I am Kush Agarwal and I have been using the telex airman 850 for a while now. Just a couple of days back I noticed that the right side speaker of my headset is not working properly. The sound and the...
Old question, but may be somebody else is experiencing the same issue. The earcup without the boom has a noise cancelling board, so it could be one of the wires that goes from one board to the other one. Gently take the earcup off and look at the 4 wires that are soldered on top (red, black, shield and white). If one of these is cut, the speaker/anr won't work. You will need a very small soldering iron to repair it (no more than 15 - 20 watts). Good luck, hope this helps ;)
Aug 02, 2010 | Telex Radio Communications
Telex 56 to cobra 4 pin
Hi there!!
the yellw wire is not used on the microphone conector most of them are just cut and left in there loose as long as its not shorting out on anything!! The wiring for the telex 56 for your radio Cobra 29 LTD is as follows: PIN #1 Shield & Red, PIN #2 White, PIN #3 Blue, PIN #4 Black, Yellow wire not connected!!
If you notice when you have the connector apart on the back of the pins where the wires get soldered to the pins are numbered so you will know which pins they are or on the front side of the connector the pins are also marked wich numbers they are!! If you have any other questions please feel free to e-mail us at: bigdscbshop@hughes.net
Apr 18, 2009 | Telex M-560 Consumer Microphone
Screeching
These trouble shooting suggestions where taken from here. There are more things they suggest trying but this cutout pertains to your problem more so than other suggestions. If these do not work I would recommend reading through that guide.
Noise or Feedback:
  • A screeching noise when you talk you are experiencing feedback. Turning your TV down should help.
  • Loweringthe headset volume can also help. Go to Accessory Settings/ AudioDevice Settings (where you test your headset) and you can set the micvolume there. Level 3 is a good start. If people have trouble hearingyou then you should raise to Level 4 or Level 5.
  • Ifyou hear an echo when you talk try turning the earpiece volume down onthe headset. Many BT headsets have their own volume control.
Also, while the PS3 is compatible with almost any Blue tooth 2.0 headset, I have heard of of problems like this occurring where the headset had to be replaced by a different model to solve the problem. As far as I know this is the only headset guaranteed to work by Sony.
Jan 03, 2009 | Motorola Mobility H700 Wireless Headset
Telex BTR-500 Instruction Manual
I have a manual I can fax to you if you are interested. Email me your fax number, or e-mail address and I'll scan it. Send to: diann_sells_slah@yahoo.com.
Jul 26, 2008 | Telex Btr-500 set (71208000sp) Wireless...
Telex H-551 Digital USB Headset and Audio/Microphone
Call 1-800-898-6723 x 1 (if outsidethe USA call using SKYPE. It is free to call USA toll free numbers using SKYPE.
The driver is the same for P-500. It is about 14KB in size.
I got mine today from TELEX. It is 01:11 July 29, 2008, Indian Standard Time.
Best regards,
Randy.
Dec 23, 2007 | Telex H-551 Consumer Headset
Telex Airman ANR 500 Headset Logo
32 people viewed this question
Top Telex Radio Communications Experts
Mike Charette
Andrew Taylor
Andrew Taylor
Are you a Telex Radio Communication Expert? Answer questions, earn points and help others
