Question about Aurora Electronics AS1500CD Shredder
When the OFF/ON button is turned on, the red light begins to blink and a beeping sound starts. It will not shred paper and the Forward/Reverse switch does not work. If you put a piece of paper in the shredder and then turn the switch on it will shred part of the sheet before it stops and the red light begins to blink.
SOURCE: Fellowes P600C-2 Motor runs in reverse, but not forward
On mine a tooth broke from a drive gear. I am trying to find somewhere where I can replace this part.
Posted on Dec 07, 2007
otacon
  • 1944 Answers
SOURCE: Shredder suddenly runs only in reverse
Did you check out this thread?
http://www.fixya.com/support/t135563-shredder_suddenly_runs_only_in_reverse
Posted on Jan 01, 2008
SOURCE: Shredder stops after about 10 minutes
spray the sheddred wheels with wd40 or any lubricant
Posted on Jan 26, 2008
I had the same thing happen to me today - I had just shredded a ton of stuff, emptied the bin 4 times - after emptying the bin the last time, all of a sudden it would only go in reverse. I pulled out my instruction manual and it says the motor might overheat and to let it cool down and try again. I let it cool down for about 1 hour, cleaned out the gears and dusted off the sensor and it started working even better than it did before.
Posted on Jan 30, 2008
SOURCE: Shredder won't shred any more.
You might have broken the actual mechanism enabling it to move forward. To be honest, your easiest solution would be to buy another shredder rather than attempt repair if this is the case, they're so cheap now.
Posted on Mar 27, 2008
Activa MD460 shredder misaligned?
they are not made to shred credit cards .
Jan 10, 2016 | Shredder Office Equipment & Supplies
My Executive Machines EPS 1200X shredder works in reverse, but does not shred.
there should be a forward/ reverse switch that is used to unjam paper being shredded. check that
if it is automatic then check for paper stuck in the shredder causing the reverse action.
May 12, 2015 | Shredder Office Equipment & Supplies
My Black & Decker Shredder #BD-61 all of a sudden does not work. I used it tonight, but the next time I tried it does not work. The lights come on in both positions, but
On some shredders when both the forward and reverse LEDs are on it can indicate either a jam or a full receiver bag/ container (the area that the shredded paper is fed into).
Try the following steps:
  1. ) unplug the power
  2. ) open up the shredder (see 1 on diagram)
  3. ) empty out all the shredded paper (see 2 on diagram)
  4. ) check that the shredding jaws (both the entrance and exit) are clear of any shredded material (see 3 on diagram)
  5. ) put everything back together
  6. ) plug power cord back in
  7. ) force the shredder into reverse (see 4 on diagram)
Hopefully you should hear your shredder motor running. If it is switch it to automatic and try shredding again
Jan 24, 2015 | Shredder Office Equipment & Supplies
Overload light stays on
Most likely the cutters are still stuffed with paper shreds and needs to be dismantled and cleaned
Mar 29, 2014 | Honeywell Seven Sheet Micro Cut Paper...
Fix this shredder
The unit is probably clogged up with a bunch of shredded paper. Unplug it ! Clean out the paper using fingers and a knife to get most of the paper clips and paper out then plug it in and run forward and reverse. That's what i do and it works every time.
Nov 16, 2013 | Achiever CCS-1500 Cross-Cut Shredder
Paper gets jammed. Even shredding just one sheeet of paper. Clicking noise is heard before the red light comes on.
The problem was solved by putting some oil on the top of the shredder and running the motor forward and in reverse to coat the teeth. Thank you.
Oct 16, 2009 | Fellowes DM8C Cross-Cut Shredder
The shredder will run in reverse but will not run foreward.
Inside the shredder there is a motor which is wired to run both forward and backward, the way it does this is to transfer the power from the switch to a couple of wires on the motor
The forward running motor will be linked to the auto start button which will tell it to work with the paper sensor.
When you select the Forward function the Auto Start is taken out of circuit and the Forward switch should supply the motor
After all of that I would say that the switch is open circuit on the Forward contact and needs replacing
Jun 12, 2009 | OfficeMax 0M96431 Shredder
Shredder Beeping
The motor would always turn the cutters.
You likely have a broken chain or a loose gear on a shaft. If you hear the motor running and the cutters are not spinning something in the drive is broken. Likely the chain.
hope this helps.
Mar 20, 2009 | Dahle High Security 20634EC Shredder
I have the Infoguard SX100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, red side switch, the gears and fuse were all ok, I think something on the circuit board was fried.
I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
Mar 27, 2008 | Office Equipment & Supplies
Aurora Electronics AS1500CD Shredder Logo
57 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
skiffy99
skiffy99
Level 1 Expert
Dabu42
Level 1 Expert
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
