If you can still access the router configuration, best thing to do is to just change the WPA key. If for some reason you are unable to access the configuration, you can try to reset the router's default/factory settings. Usually, it has a hole for the reset switch on the router which can be pushed for about 10 to 15 seconds using a small pin.
