Acer x213W - setting the resolution
I just set up a a new Acer monitor (x213w). The product specs indicate that the resolution is 1680x1050; however my display settings do not give this as an option. As a result, photos, etc seem to be stretched. Is there a way to set a customized resolution setting?
lp
  • 2 more comments
  • lprospero May 11, 2008
    Thanks MYOB; but I don't know where to go to check the graphics card resolution.
    Thanks. I was in the right place then. It does not include the optimal resolution for my monitor and does not appear to allow me to customize it. Oh well.
  • Anonymous Dec 26, 2008
    J'ai le même problème mes photos sont écrasées....Y a t'il une solution pour remédier à ça?...Merci....
  • mrhughes54 Mar 21, 2009
    I get the same result. I just got an Acer X213W monitor and I was able to set my laptop to let use the Acer as the primary when it is plugged in. However, it does not show the entire screen at the bottom or the right side. I've been trying to figure out how to shrink the screen on the monitor a bit to reduce the size but no luck. Any good ideas? Thanks in advance for any help!!!
    Problem Solver:
  • 6 Answers
Sorry about the delay. I also just purchased an Acer x213w and had some trouble setting up my computer in order to achieve the optimum resolution of 1680x1050.
I'm using an HP Pavilion m7170n, so it's a bit old and thus could not support this widescreen resolution. However, my computer comes with an ATI Radeon graphics card and, upon contacting HP Support, was allowed to download ATI's "Catalyst Control Centre". After installation, these drivers added the option of selecting a screen resolution of 1680x1050 from Desktop properties.
So this is my solution to you: simply google your graphics card along with 1680x1050 driver and hopefully you'll be able to download a driver update which does the same for you as it did for me.
Posted on Jul 25, 2008
    Guru:
  • 1,342 Answers
Make sure that your graphic card resolution setting and your monitor setting match.
Posted on May 11, 2008
  • Georgia B
    Georgia B May 11, 2008
    Right click on your desktop and choose properties then go to advanced.
Acer x213w monitor
try to set up different frequncy of monitor....
try monitor with another comuter, or notebook....
let me know...
Jan 13, 2014 | Computers & Internet
I cannot get good resolution in my Hannspree HF229H, what can I do???
The resolution you should be getting is 1680x1050. Under Windows 7, right click on your desktop then open 'Screen Resolution'. If the resolution is set to anything other than 1680x1050, set it to that. If that setting is not available then it is possible that your video card does not support that resolution. This would only effect old computers. If the resolution is set to 1680x1050 but you don't have the proper resolution onscreen, try adjusting the monitor settings using the buttons on the bottom of your monitor. Hope this help and have a nice day!
May 02, 2011 | Hannspree 22" widescreen LCD Flat Panel HD...
Width and height ratio
You need to set your PC video output resolution to the native resolution of this monitor, which is 1680X1050 @60Hz.
Right click on the desk top, the display properties will come up, click on setting tab, then you will see resolution setting choice.
Mar 28, 2010 | Acer AL2016W 20" LCD Monitor
Screen resolution for Acer P221W
1680x1050.
It also depends on the video card how high the resolution can go.
That's the max resolution though.
Here's the complete specs for your monitor.
Have a good day!
Jul 18, 2009 | Acer AL1916W 19" LCD Monitor
Hi There! My Acer x223w monitor is floating a "Input Not Supported" box that will not go away any suggestions?
The documentation for this monitor should list its supported resolutions, and you will need to attach another monitor that supports a greater (possibly lower or higher) range of resolutions and then set it to one of the supported resolutions for the monitor. The native resolution appears to be 1680x1050, although I cannot find online documentation directly from Acer.
May 04, 2009 | Acer X223WB 22" WIDESCREEN LCD Monitor
Native resolution suddenly scrolls.
The native resolution for the Acer AL2216W is 1600X1200. It is acting correctly for the resolution you have set it to.
Apr 05, 2009 | Acer AL2216W LCD Monitor
Trying to connect Acer X213W monitor to Acer 3613 laptop. First Q-My laptop does not support 1680 x 1050 resolution, can I still use the monitor?Second Q- I can't seem to locate where to connect (hardwire)...
1. Yes, the monitor will just display the resolution set by your laptop.
2. There should be a VGA port on your laptop, it's a trapezoid shape with 3 rows of 5 holes and usually blue. Since your monitor only has a DVI cable, you need to get a DVI to VGA adapter to be able to plug your monitor into this spot.
Dec 27, 2008 | Acer Aspire 3613WLMi Notebook
I just bought Acer Monitor X213W 21.6 inches There are three cords, one for Electrical supply, one for computer attachment, the third wire is for a particular purpose goes one end to the monitor and other...
one is power one is standard vga and one is a dvi cable, the only time you would need the dvi is for a higher quality of picture. if you do not need the higher quality (ex. you don't watch hd movies, you don't play games with awesome quality gfx, you don't do professional gfx.) you only need the standard vga (the one your used to). [note: you might need to upgrade your video card to use the dvi cable]
May 10, 2008 | Computers & Internet
Acer Monitor Display of text and image is not sharp
This might seem obvious, but is your video card output set to the native resolution on the monitor? If not, it will look fuzzy. Try 1680x1050, if you don't know the monitors native resolution.
No need to use anything higher than a 60hz refresh rate either.
Mar 29, 2008 | Acer AL2216WBD LCD Monitor
Computers & Internet Logo
3,546 people viewed this question
David Payne
David Payne
