Question about Kenmore 64802 Top Freezer Refrigerator
How old is a kenmore fridge model 363.78282890
I have a kenmore bottom freezer refrigerator model # 795.78304.804 bout 10are11years old just stopped working nothing will come on . checked power at box and it's good
main switch/thermostat control inside of fridge needs replacing...to prove...tap/bump switch a couple of times and you should hear fridge power up...if so replace switch/thermostat...
Oct 16, 2016 | Kenmore Refrigerators
Kenmore fridge model 596 - 79213014 2 yrs old accumulates ice at the bottom freezer. The fridge has built it ice maker but we did not opt for that option. Can anyone pls advise how tofix the problem?
IS THERE A CONTAINER FOR THE ICE TO COLLECT IN UNDER THE ICEMAKER??? IF NOT YOU WILL NEED TO GET OR ORDER ONE..
NEXT THERE IS A WIRE LEVER ON THE RIGHT SIDE OF THE ICE MAKER. WHEN THE ICE PUSHED THAT LEVER UP IT WILL QUIT MAKING ICE. WITH YOUR HAND GENTLY LIFT THE LEVER UP UNTIL IT STAYS LOCKED IN THE UP POSITION... ONCE IT IS IN THE UP POSITION ... IT WILL NOT PRODUCE ANY ICE.
Dec 29, 2014 | Kenmore Refrigerators
Model 978-339 serial no.
What is the complete model number of the unit?
Dec 07, 2012 | Kenmore Refrigerators
Find out how old is my kenmore fridge model #596 62822200
You will need your model number and Serial number handy. The first three numbers will tell you who made your machine. (( Sears kenmore Does not make machines, They just put there name on it. ))
Go to this link and go to Who Made my Kenmore.
Im sending you to this link because it is very infomational about the age of kenmor and many other machines.
Jan 14, 2010 | Refrigerators
Kenmore fridge not cooling
check for your freezer fan running properly
then check to make sure you have air flow into the freezer this model has a habit of freezing ice in the air channels
Oct 07, 2009 | Refrigerators
Fridge not staying cold, periodically
CHECK FAN OPERATION   MOST OF THE TIME IT IS THE THERMOSTAT
Aug 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 64802 Top Freezer Refrigerator Logo
142 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
