Question about Canon LASER SHOT LBP-2900 Printer
I changed the toner and now it shows paper jammed when there wasnt any paper stuck
  • 44 Answers
Check whether there is any paper bit at the feeder head,tray slot.
Posted on Sep 03, 2010
Brother 2170W, toner is stuck after paper jammed. I try to pull out the toner (even with force!) but it stuck, there is a paper at the bottom that i can't pull either. I guess this paper holds the...
If the paper get stuck inside the printer you can also remove it fro the back of it. Open the back cover and try to remove the jammed paper inside of the printer. If still the paper can't be remove try again to removed the drum and toner.
Open the front cover or pull down the cover right above the brother logo infront of the machine then hold the handle of the drum and toner assembly.Pull the drum and toner assembly towards you, just put a little force on it. Then remove the jammed paper.
Just to make sure, remove the toner from the drum by holding down the tab on the side and lift the toner out. Look for any small piece of paper inside of the drum unit. Reinstall the toner back to the drum. reinstall the drum and toner back to the machine, make sure that you here a click sound. After that close the front and back cover.
The blue light should lit up again.
Hope this helps. Thanks
May 06, 2011 | Brother HL-2170W Laser Printer
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
I have taken all the paper but still its showing the paper jam message
Did you check under the toner and drum for paper? Pull the toner and drum out, check for paper stuck in the rollers. Also there id a door on the back of the printer. Check for paper behind it. Then turn the printer off for 5 mins and try again.
I hope this helps Regards GM
Apr 11, 2011 | Canon i-SENSYS MF4120 All-In-One Laser...
My hp photosmart 8250 keep showing paper jam but there's no paper jam anywhere. How can I get it to function properly?
Make sure there is no paper stuck inside in the paper. may be there is small piece of paper stuck inside
Just unplug the power and open the cover and remove the toner or cartridges from the printer and manually try to roll the roller and remove the paper.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 17, 2010 | HP Hewlett Packard Photosmart 8250 InkJet...
Dell 1720 laser printer shows paper jam after clearing jam and turning off and back on.
some paper piece may be left in the printer.
Please check where was the leading edge of the paper when it was jammed. some sensors may have got stuck while removing paper. open the toner door remove the toner cartridge, just see all the sensor flags with fingers, refix toner and power on and try printing
Dec 01, 2009 | Dell 1720dn Laser Printer
I get paper jam message
A paper must have stucked in the printer. Kindly open the printer where you enter the toner. Take the toner out and then look for any piece of paper or something has stucked. After clearing it, Place the toner back and then try to print....
Aug 30, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Paper jams after printing and will not exit top output tray
sounds like the gear drive assy faulty.take it back to where you purchased.Samsung should cover under warranty.
May 25, 2009 | Samsung ML-2510 Laser Printer
I have a paper jam on a HL-5040 where I can see the paper under the toner/drum. The Brother site suggests pulling the paper up and out once the paper tray is removed, but my sheet of paper won't budge at...
I consulted the Brother site again but this time I researched just how to remove the drum. This page has nice drawings that show how to just pull it straight out! They explained the blue button on the right is just for holding the toner in the drum. They also showed, a very important piece of information, where to place the hands as well. I did it slowly because the jammed paper seemed to be 'stuck' to it. It came out easily, with no real force required. I removed the paper and slid the drum back into place. Quite simple once I could see how to do it without risking damage to the printer!
Apr 08, 2009 | Brother HL 5040 Laser Printer
Two error messages persist after replacing toner cartridge.
This kind of error indicates that your toner is not properly set or there is some paper jam. so please follow the instruction and open the panel and remove the toner and check for any kind of paper piece and than refit toner properly and close the panel and than check you will definatly able to resolve the problem ok
Dec 20, 2008 | Canon imageCLASS MF4270 All-In-One Laser...
Xerox 1008: Paper Jam when no paper is stuck
It Is a sensor that you should clean or re-locate. Try searching on sides of the roll or near the place where it shows you or tell you about the paper Jam.
Mar 20, 2007 | Xerox FaxCentre 1008 Plain Paper Laser
Canon LASER SHOT LBP-2900 Printer Logo
80 people viewed this question
old marine
old marine
