I need the gear that is like a plunger. It comes out of the printer and drives the drum. White gear with LM4225 on it
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 28 Answers
Unfortunately, the toner drive gear (LM4225) gear is not available as a separate item, nor is the entire gearbox available - only the plunger and the motor are available as spare parts
if you're good at plastic welding, you can repair it, otherwise this renders the machine 'throw-away'
Posted on May 21, 2012
White unprinted band on the top end of printed sheet
Look to make sure your developer is flowing evenly on the mag roller. Next I would check the scoretron\grid it is the saw tooth blade that faces the drum.
Aug 18, 2014 | Sharp AR-5320 Black and White Copier
Print out has white strips
Hi, white strips can vary depending on how you place your paper ie can be horizontal or vertical on the printed copy. Please check the following possibilities;
  1. Check that there is enough developer on the developer unit and that it is uniformly distributed on the magnet roller. If less, add a little or replace a new on, if there is some lines on the magnet roller, pour out and sieve the particle.
  2. If the steps above do not work, check the drum drive gear on the drive unit and replace if teeth are worn out.
  3. Replace a new drum and also the side seal which comes with the drum cleaner blade as they are the ones that removes the drum coating.
Please be cautious.
Nov 27, 2010 | Sharp AR-5316 Advanced Digital Imager...
Orange light on drum. drum making a loud hammering sound when printer is put on or attempting to print.
Sounds like a broken drum drive gear. Try another known good drum assembly first. Parts can be googled and found. But, difficult for end user to replace. You have to remove all covers and fuser asm. Then gear housing from the left side to change the drum drive gear.
Dec 30, 2009 | Brother HL 1440 Laser Printer
I can't locate the starter solenoid on my 2000 chevy silverado. Where is it?
(Starter) Solenoid - Removal & Installation
  1. Remove the starter motor.
  2. Reposition the M-terminal stud weather cover.
  3. Clean the epoxy coating from the M-terminal stud.
  4. Loosen the M-terminal stud nut.
  5. Remove the cable from the M-terminal stud.
  6. Remove the solenoid bolts.
  7. Separate the solenoid from the housing and unhook the solenoid plunger from the drive gear lever.
  8. Note that the spring (3) is positioned against the drive gear lever (1) and the drive gear lever is placed inside the solenoid plunger loop (2).
    Fig. Spring (3) is positioned against the drive gear lever (1) and the drive gear lever is placed inside the solenoid plunger loop (2)
  9. Remove the solenoid housing.
  10. If necessary, remove the solenoid plunger and spring.
To install:
  1. If necessary, install the solenoid plunger and spring.
  2. Using Three Bond silicone 1207B, GM P/N 97720043, seal the starter solenoid attachment area.
    WARNING Make sure that the drive gear lever (1) is properly installed into the solenoid plunger (2) loop. Improper installation of the drive gear lever will cause an abnormal or no operation condition of the starter.
    Fig. Make sure that the drive gear lever (1) is properly installed into the solenoid plunger (2) loop
  3. Install the solenoid, making sure to insert the drive gear lever (1) into the solenoid plunger (2) loop, perform the following:
    1. Pull the gear lever (1) out away from the starter housing and pull the plunger (2) out away from the solenoid.
    2. Tip the solenoid and insert the lever into the loop, push the solenoid against the housing.
  4. Install the solenoid bolts and tighten the bolts to 89 inch lbs. (10 Nm).
  5. Wipe the excess silicone pressed out during the solenoid installation from around the base of the solenoid to make a weather proof seal.
  6. Install the cable to the M-terminal stud between the washers and terminal nut.
  7. Tighten the M-terminal stud nut and tighten the nut to 71 inch lbs. (8 Nm).
  8. Using Three Bond silicone 1207B, GM P/N 97720043, seal the M-terminal stud connection.
  9. Reposition the M-terminal stud weather cover.
  10. Bench test the starter in a free-run condition prior to installation.
  11. Install the starter motor.
To install:
Hope helped with this (remember rated this help) Good luck.
Nov 04, 2009 | 2000 Chevrolet Silverado
My printer dont work. On screen appear Error Code # L4-02
L4-02 is a drum motor lock detection.
One cause that we have found on these particular models is the waste toner auger (built in the drum unit) drive gear breaks due to blockage or failure of the auger. You can remove the drum unit by 1st removing the toner then developer tank then a blue screw will loosen the drum unit. Once out look at the back of the drum unit and you will see 3 little white gears. Check for damage or missing gears. If they are you will need a new drum unit. Please contact your local Sharp dealer for OEM replacement.
Oct 13, 2009 | Sharp AR-M355N Copier
Drum reset for Panasonic kx-mb781
There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner mixing assy - and you can rotate it in counterclockwise all the way back. This should reset the drum counter - worked for me - I hope it also does the trick for you ;-)
Apr 19, 2009 | Panasonic KX-MB781 All-In-One Laser...
Not printing on left side of page
The problem is that the revolving drum doesn't contact the OPC drum proberly. You have to open the left side off the machine and replace the little white gear on the shaft that drive revolving drum. The gear has "jumped"one step and the revolving drum isn't parallell to the OPC drum. I fixed my 2840 last night it takes some time but now it works perfect.
Feb 25, 2009 | HP LaserJet 2840 Printer
Hallo
07,009.42 indicates that the printhead was unable to tilt normally on its axis.
You probably have a cracked drum maintenance camshaft. If the drum maintenance pivot plate is white plastic it should be replaced as well with the new style, which is black plastic. This repair requires removing the process drive gears assembly and reinstalling it requires the gears to be timed. This repair should be performed by a qualified technician familiar with these machines.
You probably have a cracked drum maintenance camshaft. The dm camshaft is driven by the process drive motor on the right side of the printer. It raises and lowers the maintenance kit against the drum to oil and clean the drum. The camshaft has 2 lobes on it. These lobes crack over time and cause several different error conditions. The camshaft part # 401100380 is only about $17 from xerox but can be tricky to replace if you're not mechanically inclined. The other thing to look at is the pivot plate assembly. Slide out the drum maintenance kit. If you look inside the cavity the plate that the maintenance kit sits on is called the pivot plate. If it's white it will also need to be replaced with a black one.
Oct 15, 2008 | Xerox Phaser 8400 Laser Printer
Continuous Paper Pick Up
Paper pickup solenoid plunger out of position remove covers locate solenoid on the right hand side of machine as looking from behind( Could be the other side as not got machine in front of me) and check that the plunger is in its correct position. If not refit replace covers and check.
Note sometimes the plunger falls to the bottom of the printer loosing the tension spring. What causes the problem you have is that the plunger does not lock the pickup gear into position and the engine drives that pickup gear all the time causing to pickup paper all the time.
Thanks Jason
Jun 05, 2008 | HP LaserJet 1200 Printer
62 people viewed this question
jasbo
jasbo
