Question about Krups Small Appliances Espresso Machine
Lots of disturbing noises, no coffee
When my Krups XP7220 starts brewing there's a horrible noise coming from the coffee grinding department and only light brown hot water is released into the cup.
It sounds as if there's something stuck in the mill (a stone perhaps, mixed in with the coffee beans?)
I've tried turning the thing upside down and poking about through the top where the coffee beans go into the grinder but I think I need to get inside the thing.
How do I remove the cover and get to the heart of the matter?
I've undone as many screws as I can find but I don't like to go prising off plastic panels unless I know for sure they're supposed to be prised off.
  • JokerXL May 13, 2008
    Thanks, I'll give that a go.
    No error codes, it believes it's doing a great job, says "your coffee is ready" and presents you with a cup of hot water.
The coffee grinder gets clogged with coffee powder and coffee oils and no coffee is released into the brewing chamber. Remove the grind adjustment knob and the one screw holding the bean holder in place. You should now have access to the grinder and clean it with a brush. Further disassembly as outlined above may be necessary in order to remove the grinder if a more thorough cleaning is required.
Posted on Jul 01, 2011
It is is easy, if you know how to do it... as always
First take of the wather, trach bin etc,
Start with removing the cup wher the beans is stored, the adjustment knob for the mill is a tricky part. Remove it by bending out the side of the knob. Thereafter remove the screws from cup and those you on see on the top.
The front (silver frame) is removed by lifting it upwards, behind it you have 4 screws that has to be removed.
The last two screws is found under the wather tank.
Now you should had take away 11 screws, at least...
Bend the back of top and it will be off. Finally push the rest of the plastic cover backwards.
Do you know what the error codes says? I have know 6,8and no coffy...
Posted on May 12, 2008
Pump may be broke
Remove the frother nozzle: if its the early type with three hooks, slide the frother body down before trying to remove it. Disassemble the frother and clean the three holes in the end. If the holes are blocked, the steam can't escape. If it's not pushing hot water through the coffee holder, pull out the water reservoir, and remove and clean the grid plate assembly where the coffee holder clips in.
Feb 08, 2014 | Krups XP5220 Espresso Machine & Coffee...
Krups ea 8250
If it doesn't grind , than there is no coffe , it will surely come as water .
Grind it first , and than brew the coffe .
Oct 24, 2013 | Coffee Makers & Espresso Machines
Krups xp7220 technical error 05
It cannot be an FNF2 and also an XP7220, they are entirely different machines.
Apr 15, 2013 | Krups Orchestro Dialog FNF2 Espresso...
I have a Krups XP7220.The waters commes out cold under the appliance. Is the boiler as the guy from service says ? Thanks Ovidiu
When you brew a cup is the coffee cold? Or is just the excess water that come out into the water tray cold?
Sep 20, 2010 | Krups Small Appliances Espresso Machine
Krups grind & brew. It grinds but water
Check to see if your heating plate gets hot when it is on, if it doesn't your water heater/heating pklate has failed.
Nov 20, 2009 | Krups Coffee Makers & Espresso Machines
Krups K2 XP402040 Expresso maker. This makes the
Would you like to try not put too much coffee powder, and not make the coffee powder too firm ( I mean not press them too heavy.)
Or, not grind the coffee powder too thin....
Hope it helps you.
Oct 30, 2009 | Krups Coffee Makers & Espresso Machines
Espresso brews too fast on Krups XP4030
Check/adjust the grind on your coffee.
Jun 21, 2009 | Krups XP4030 Espresso Machine
No coffee is coming out of the machine...
in our machine we wanted a stronger coffee so we adjusted the auto grinder (where the coffee beans are housed) to the finest setting thinking the finer the grind the stronger the coffee...after doing this the machine wouldnot make coffee...we sent it away while still under warranty and the tech said that the grind selection was too low so they just turned the grinder back up a notch and it worked fine ....dont know if this will help but it's worth a try!
Mar 26, 2009 | Krups Orchestro Dialog FNF2 Espresso...
Saeco magic deluxe machine is making crunching noises when makes coffee and when returning to start position. Sometimes does not make the coffee grinds coffee but not letting water through almost seems...
There is a lever inside the door on the right. It is at the top in the center. Pull it back one click and try again. The crunching noise does it sound like a clicking noise?
Aug 31, 2008 | Saeco Magic De Luxe Espresso Machine
Krups Small Appliances Espresso Machine Logo
726 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
