Question about HP LaserJet 4050n Printer
My laserjet 4050 was printing and then it wasn't. Turns on ok but computer is not communicating. Not a technical person, tried a couple of things but...this is my main computer. help
    Champion:
  • HP Expert
  • 202 Answers
Pls explain correctly
Posted on Sep 03, 2010
We have a 4050 laser jet and it was just cleaned. We have our public computers hooked up to the one printer and now we can not print from any of the computers. I noticed a phone line at the back of the...
The LJ 4050 doesn't have a fax, so it doesn't have a phone cord.
Could it be a network cable? If yes, then plugging it into the router should do the trick.
Call the person that 'cleaned' the printer to come back and check it out.
Anytime you do any work on the printer it should be tested to make sure it still works.
Jan 28, 2011 | HP LaserJet 4050 Printer
My printer hp laserjet 5l is printing in number and alphabatic what i do .
This is caused by one of two things. First be sure you have the correct printer driver installed, if you have printed to this printer before on this computer then you should be ok here. The other thing would be that the printer lost communications with the computer and when it reconnected the control codes had been lost. To check this, first power off the computer and the printer. Now check the connections between the two, the computer connection should be screwed tight and the printer connection needs to have both clips fastened. Now power up the computer and printer, try a test print, if it prints then you should be good. If you still get the odd print then replace your printer cable, be sure to get one that is rated IEEE1284. This rating insures proper bidirectional communications between the printer and the computer.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 29, 2010 | HP LaserJet 5L Printer
Our company has a LaserJet 4000 and a LaserJet 4050, and both are printing the margins unevenly, in all applications. For instance, in Word the margins are set to 1 inch each side, but when it prints the...
It could be the rollers, try updating the firmware firstly, Sometimes the firmware will cause alignment and print quality issues. If that doesn't fix the problem, contact hp for a list of ASP's. 1800-334-5144
Al
Apr 20, 2010 | HP LaserJet 4050 Printer
HP Laserjet 4050. Can I connect from my TCP/IP to JetDirect?
To use a printer DIRECTLY into your PC or laptop (without plugging both into a network hib, or switch), you need to use a CROSSOVER patch cable.
Feb 19, 2010 | HP LaserJet 4050 Printer
I have a hp laserjet 4050 that will print my files but will reverse and print same files again. what is the problem?
Check your driver settings. Make sure the number of copies is set at 1 copie.
Gerrit Jan
Nov 01, 2009 | HP LaserJet 4050 Printer
Color rendition is way off on Brother 4050 (4040/4070)
Run a self calibration cycle a couple of times, and also clean the laser scanners.
Nov 22, 2017 | Brother HL-4040CN Laser Printer
MY PRINTER WILL NOT PRINT OUT
check and see if the computer actually recognises the printer. go into printer settings and see if your printer is listed. if not click on install printer.
Jan 12, 2009 | HP LaserJet 4050 Printer
HP Laserjet 4050 hangs on processing job
Unplug printer cable.
turn off
turn back on and wait for READY
turn off
connect printer cable
turn on
Jan 05, 2009 | HP LaserJet 4050 Printer
HP LaserJet 4050n Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
