Question about Sony DPP-FP50 Thermal Photo Printer
TROUBLE PRINTING I HAVE AN SONY DPP-FP50 AND ONLY USED A FEW TIMES. THEN IT STATED TO PRINT ONLY HALF OF THE PICTURE. I CLEANED AND IT STILL DOES THE SAME THING. WHAT IS THE PROBLEM?
  • Anonymous Nov 30, 2008
    Did you fix the problem?
    Guru:
  • 1,342 Answers
These are following cases for this symptom.
If the access indicator flashes in green:
The data size of the image is large and it takes longer to process it for printing. Printing will start as soon as the data processing finishes.
If the paper error indicator flashes on the LCD:
The paper is jammed. Turn off the printer and turn it on again, take out the paper tray, and then remove the jammed paper from the paper outlet. If you cannot remove the jammed paper, consult with your Sony dealer or service facility.
If no indicator is lit or flashing:
The thermal head may be overheated. Leave the printer until the head cools down and the printer resumes printing.
Posted on May 11, 2008
Why does printer only print half of the picture
Your paper size may be samller then the size of the image you are printing. Try changing the size of the image or size of paper to match.
Aug 12, 2014 | Sony Picture Station DPP-FP90 4x6 Photo...
Why is the sony dpp-fp90 digital photo printer only printing half the picture?
Are you using a large image size, try smaller size file..Its a data processing problem. clear the memory of the printer.If persists it could be a lose data cable in the printer if the printer has had a knock
It only prints a 6x1"
Sony printers are masterpeices when it comes to digital printing as they produce wonderful quality images.
If you got a new printer and it does the same thing this indicates that the problem iis emanating from the software with which you use in editing the pictures before sending the print command. Somewhere along the line some adjustment must have been made to the software relating to the alignment of the picture on the printer. Once this adjustment is corrected your printer will print fine.
Printers are devices which prints what command was sent to them and do not have any intelligence to act or edit documents on their own accord.
Hope this solution has been helpful?
Happy new year
Jan 03, 2011 | Sony DPP-FP30 Thermal Photo Printer
Need driver update for Windows 7 - 64 bit. Is there one?
The Sony Support site does not list a driver for either Vista or Windows 7 (neither 32 bit nor 64 bit). If you have Win7 Pro or Ultimate, you can install the XP mode and load the driver for this printer on to that virtual machine.
I hope this helps.
Jan 06, 2010 | Sony DPP-FP50 Thermal Photo Printer
Sony Printer DPP-fp90
You may use your memory stick option to print. I means you shall copy your pictures to a memory stick card. Insert in into the printer. And print directly without your MAC. I use Sony DPP-FP70. It works.
Nov 01, 2008 | Sony Picture Station DPP-FP70 4x6 Photo...
The manual that came with my printer is not in English
You can pick out the manual or guide you want here:
http://safemanuals.com/zearch_652.php
Enter your model number in the search window on that page:
DPP-FP50
Oct 14, 2008 | Sony DPP-FP50 Thermal Photo Printer
Printing problem
you may have a faulty Thermal element, sounds like a cold spot in the middle of the print head is messing up your photo. If this is in warranty or is new get them to replace it
Aug 22, 2007 | Sony DPP-FP50 Thermal Photo Printer
Sony DPP-FP50 Thermal Photo Printer Logo
783 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
