Question about Maytag Atlantis MAV6000 Top Load Washer
Water is gushing out of the bottom of the washer when I turn it on. Water supply hoses from the hose are not the issue. Any suggestions?
  • mathurman Sep 03, 2010
    Where can I find step by step intructions to take the cover off?
  • 10,319 Answers
Check for a crack in the water pump housing. they are molded of plastic which does tend to crack on some washers such as yours here
Posted on Sep 04, 2010
  • Maytag Master
  • 909 Answers
Yes, with the cover off,look carefully into the workings while switching the unit on. You will very possibly see a pipe that has come off or that has a hole in it. Replace it.
Posted on Sep 03, 2010
The city turned off the water to fix a main line and then turned the water back on. The first time I started the washer after this happened, I heard a loud pop noise and the water began gushing into the...
After repairing the pipeline it's inevitable that some debris/stones/cement etc. would find it's way into your machine. Even though there is (or should be) a filter in the water input hose, I'd guess that the water pressure was so high that some debris damaged the electrically operated solenoid valve which controls the water input flow. A mechanical problem then, with possibly some associated electrical fault. If you can get the machine out, I suggest unscrewing the inlet hose and having a look at the valve - they're usually easy to get to. But please DISCONNECT THE ELECTRICAL SUPPLY AND WATER first.
May 25, 2014 | Asko W6661 Front Load Washer
Kenmore washer 600 series model 11027642600
Could be bad hose, valve or seal in the washer (this was listed under dryers). Requires taking the washer out of service and looking for source of the leaks. Hose, valve or connectors is more likely than a seal if water is gushing.
Jan 11, 2014 | Washing Machines
Where is the drain filter on a samsung front loader? I am getting a nd error when I removed the hose from the pump, water came gushing out of the pump. Before I removed the hose, I made sure that the...
Hello & Welcome to FixYa
ND error in your Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump, located inside the bottom front access panel of the unit. Please get back to me if you have any other questions.
Kevin
Oct 04, 2011 | Samsung WF328AA Front Load Washer
All of the water came gushing out onto the floor...all hoses attached and in good shape
Nine tine out of ten the fill valve housing is cracked, try filling washer with bucket if no leaks that will prove it, if leaks with bucket fill the problen is probably the water pump or hose's that go to it
May 15, 2010 | Frigidaire FWSB5700DS Top Load Washer
How do i clean a blocked filter on a wma74
Remove the lower rear panel of washer.
Remove the large black hose fastened to the bottom of the drum.
Remove and clean the plastic filter inside hose, make sure you fit it back on correctly, or it will come off.
Remove the hose onto the pump, and check for obstruction or blockage here and in the pump itself.
Please rate my solution.
Thanks.
Nov 23, 2009 | Hotpoint WMA74 Front Load Washer
Refrigerator gushing water through ice maker filter
Filters themselves don't usually leak. Check full insertion of filter, cracked filter housing or cracked supply line.
Aug 14, 2009 | Whirlpool Refrigerators
Water is filling slowly
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 24, 2009 | Kenmore Washing Machines
I just bought a Frigidaire Affinity washer model #LTF6700fs about a week ago. Starting yesterday the washer stopped draining. We can hear the motor working to pump it but no water is draining. My...
perhaps not in that hose but in the pump housing just below it, quite possible that someting is jamming the imopellar preventing proper draining of water
Mar 18, 2009 | Frigidaire Washing Machines
Water authority turned off water & washer not working now
Disturbing the water supply caused sediment to flow in and block the inlet screen(s) on your washer. Take the supply hoses off and look inside the part they screwed off of to find screens. Remove the screens and clean. Reinstall. Check that there are not filter style hose washers in either end of the supply hoses which may need to be cleaned out.
Jan 06, 2009 | GE Energy Star WCVH6260F Front Load Washer
Hotpoint Aquarius WF100
Firstly, there should be only one hose, always connected to the cold supply.
The unit will heat the water to the setting you choose for the wash (40 - 60 - etc)
Secondly, if the unit is leaking water, try turning down the cold pressure, this will slow the supply pressure to the unit and prevent spray out from the detergent drawer.
Your supply tap should have an isloting tap on it, adjust this until it sullpies water at an acceptable rate.
Do this by feeding the hose into a bucket/basin and tweak it until it pours out - not sprays out.
This should alleviate any leaks around the machine.
Hope this helps.
Oct 08, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
43 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
