Question about HP LaserJet 3600n Printer
I have an hp 3600 printer and one day the cartridges print light and the next they will print dark like they should what could be the problem
    Champion:
  • HP Expert
  • 202 Answers
This problem due to earthiong contact point of toners,pls fully calibrate it your problem will be resolved.
Posted on Sep 03, 2010
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
I have a hp officejet 5510 that prints the first line and the next is light and than dark and than light again
The problem could be caused due to blocked printer nozzles or bad print head. Try cleaning the ink nozzles first.
1 Press Setup.
2 Press 5, then press 1.
This selects Tools and then selects Clean Print Cartridge.
A page of patterns is printed. The print cartridges are cleaned. Recycle or
discard the page.
If copy or print quality still seem poor after you clean the print cartridges,
replace the print cartridge that is affected. For information on replacing
print cartridges, see replace the print cartridges.
The link for the user manual can be found at
http://h10032.www1.hp.com/ctg/Manual/bpu72474.pdf
Thanks for using fixya
Proton
Apr 18, 2010 | HP Computers & Internet
The black is not printing dark enough. It shows it
it is problem your printer black cartridge
you change it or
technicaly you drop your black cartridge in water withen two days after tow days you dry black cartridge and clean head printer maintai nence software then solve your problem
Jul 30, 2009 | HP DeskJet 5550 InkJet Printer
HP 1600 color laser printer--colors are out of sync
Check the following information please.
General print quality issues
Solving issues with color documents This section describes issues that can occur when you print in color. Color document issues Problem Cause Solution Only black is printing when the document should be printing in color.
c00659983.gif Color mode is not selected in your program or printer driver. Select color mode instead of grayscale mode. The correct printer driver might not be selected in the program. Select the correct printer driver. The device might not be correctly configured. Print a Configuration page.
One or more colors are not printing, or are inaccurate.
c00659984.gif Sealing tape might be on the print cartridges. Verify that the sealing tape has been completely removed from the print cartridges. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The device might be operating in excessively humid conditions. Verify that the device environment is within humidity specifications. One or more print cartridges might be low. If you are using non-HP print cartridges, no messages appear on the device control panel or in the HP Toolbox. Replace any low print cartridges. The control panel is set for override. Replace low or empty print cartridges. A color is printing inconsistently after you load a new print cartridge.
c00659985.gif Another print cartridge might be low. If you are using a non-HP print cartridge, it might be low or empty but you will receive no indication. Remove the print cartridge for the color that is printing inconsistently and reinstall it. The control panel is set for override. Replace low or empty print cartridges. The colors on the printed page do not match the colors as they appear on the screen.
c00659986.gif The colors on your computer monitor might differ from the device output. Select Screen Match in the Color tab of the printer driver. If extremely light colors or extremely dark colors on screen are not printing, your software program might interpret extremely light colors as white or extremely dark colors as black. If possible, avoid using extremely light or extremely dark colors. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The finish on the printed color page is inconsistent.
c00659987.gif The media might be too rough. Use a smooth paper or print media, such as a high-quality paper that is made for color laser printers. Generally, smoother media produces better results. Repetitive image defect ruler Use a repetitive image defect ruler to measure occurrences of repetitive image defects to help solve image quality problems. Place the ruler next to the first occurrence of the defect on the page. Find the distance between identical defects and see the Repetitive image defects table to identify the component that is causing the defect. Repetitive image defects Measurement Component 24.7 mm0.97 inch Developer sleeve 26.7 mm1.05 inches Charge roller 32.9 mm1.3 inches RS roller 37.7 mm1.48 inches Transfer roller 54.5 mm2.15 inches ETB rollers 56.6 mm2.22 inches Fuser sleeve 62.8 mm2.47 inches Pressure roller 75.4 mm2.97 inches OPC
Have a good evening
Jun 18, 2009 | HP LaserJet 1600 Printer
Yello led on can't print.
Yellow cartridge needs replacing . printer wont print in any other colors if one cartridge is empty
May 28, 2009 | HP Color LaserJet 2550n printer + HP Color...
Can't switch up my Canon iP3000 printer
Problem solved - I bought a new printer. On a long run it is cheaper.   Thanks    Mila
Apr 10, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
HP Color Lserjet 3600
We found that we had a defective cartridge. We returned it. A replacement cartridge did not cause the printer to callibrate continuously.
Jan 10, 2009 | HP LaserJet 3600n Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
Hp lazerjet 2550n
Your Black cartridge is empty.
From the user guide:
Black, Cyan, Magenta, and Yellow Supplies Status lights
These lights indicate when a print cartridge is low (the light is on), or empty or missing (the
light blinks). The lights also indicate when a non-HP print cartridge is installed (the light
blinks and the Attention light is on).
Here is a link for the User Guide:
2550n User Guide
If this solution has been helpful, please take a moment to rate it. Thanks!
Jun 16, 2008 | HP Color LaserJet 2550n printer + HP Color...
HP LaserJet 3600n Printer Logo
112 people viewed this question
Seeker5211
Seeker5211
