Question about Acer Aspire 3000 Notebook
Touch pad not working ,thir some switch? - Acer Aspire 3000 Notebook
  • Acer Master
  • 629 Answers
To start, make sure the touchpad driver is installed. you may need to reinstall it as well even if installed already, then you can proceed to adjust the touchpad settings as you prefer. You may have to use an external mouse for this process .
Posted on Sep 03, 2010
Why Acer aspire ES1-511-C6G7 touch pad stop working what could be the problem? the driver is up to date
I have a switch on my laptop that turns the touch pad on and off. Also, in some BIOS and/or OS settings you can enable or disable the on board touch pad.
Oct 05, 2014 | Acer Computers & Internet
My Samsung R580 left touch pad not working, some time on off switch also needs repeated tap for on. How to correct?
The switches may be faulty or out of allignment. Strip you laptop down and check the actuators.
Sep 13, 2014 | Samsung Computers & Internet
How to use touch pad dell latitude D610
The touch pad on a Dell Latitude D610 works much the same as with other laptops. You can move your finger around the pad to simulate the movement of a mouse, and it will cause the pointer to move across the screen. You can also tap on the touch pad (gently) to "click" on a file, folder, or other item. The touch pad on a D610 doesn't have a hardware switch like some other laptops do so that you can turn it on or off -- it's just always on.
Aug 08, 2010 | Dell Latitude D610 Notebook
Laptop Touch Pad will not work
if you plug usb keyboard onto your laptop it will probably turn the touch pad off.
If no other keyboard is attached there is usually a switch to turn off the touch pad.
also if you attach a mouse this may disable the touchpad so you dont move the mouse pointer when you are typing
Jul 10, 2010 | Acer Aspire One PC Notebook
just restart machine in bios setup ckeck that touch pad option is set to enable. and also check some of the laptop has one switch on keypad or on the top of touchpad for on/off utility is set to on
Dec 27, 2009 | Toshiba Satellite A205-S5823 Notebook
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Touchpad no longer works
I had this problem. There is a guy on ebay who sells these for less than 20.00 with shipping. http://stores.ebay.com/Super-Shipping
Not to bad to replace. Take flat blade srewdriver pop top and bottom piece off. Remove the 4 screws from the bottom. Carefully lift lcd and battery. DO NOT disconect these. The new touch pad simply plugs in. Not too bad if you are a little bit familiar with electronics.
Dec 27, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
Synaptics touch pad, double tap not working
look in the sys tray, (lower left of screen) one of the icons will be concerned with the touch pad. you can turn on and of the double tap here. Sounds like yours is switched off.
Nov 04, 2008 | Logitech V220 Mouse
Screen frozen, touch pad not working
there is a switch nearby that orange light or the light may be a switch. press on it then the color of light will change and ur problem will be solve....thats all
Dec 21, 2007 | HP Pavillion ZV6000 Notebook
Computer Frozen, Touch pad not working
Acer Aspire 3000 Notebook Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
