Question about Xerox WorkCentre XE60 Laser Printer
Hi, I have a Work Centre XE60 that displays an E7 error code. I have reinserted the shipping screw and removed it, but that didn't clear the code. I have also tried the fix #14 from Serox's online support site, also no luck. Any suggestions? This unit was working fine until i moved it without the shipping screw in place.
In reading your question I thought I wrote it! I am having the same problem with my printer and it, too, happened after I moved it without the shipping screw. Have you been able to fix yours? Thanks, CC
Posted on Nov 30, 2010
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems Posted on Aug 16, 2016 -2017
Jul 29, 2016 | Sharp Ar 5316
What does error code e7 on a Dyson am 05 mean?
Hi there, it's Jack at Dyson.
If your Dyson Hot + Cool heater is displaying an E7 error code, we will need to take some further details via our Helpline to resolve this for you.
When you have your machine to hand, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) so we can provide assistance.
We'll look forward to speaking with you.
Oct 09, 2014 | Dyson Inc Am05 Hot Cool Fan Heater -...
I have E7 and machine won't work????
E7 sounds like an error code. First step is to look it up in your owner's manual.
Aug 26, 2014 | Singer Sewing Machines
Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 28, 2012 | Kettler treadmill Pacer
Error Code E7 on Singer 6180
E7 means the machine has 'had enough' and that error flashes to let you know it needs a break. I found that out by trial and error and after phoning Singer as well.
Nov 04, 2012 | Singer 7258 Sewing Machine
Hi my copier displays E7
Check this out :
E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the **** glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Oct 31, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp MX-6201n get e7-06 error when scanning to thumb drive
Hi
Error E7-06 means Image data decode error. This appears due to Image expansion error. It has been caused due to MCU PWB abnormality or USB cable trouble
Try using a different USB cable. If this doesn't help then try the reset procedure---
Sharp ram clear -- Press function 9 * 8 # 7 then # or * until display reads memory clear, then press start. Note the other maintenance mode options displayed on the screen when pressing # or *.
Hope this helps...
Daniel
Oct 08, 2010 | Sharp Office Equipment & Supplies
C62 error code - NASHUA 8112RE
Is this right out of the box?? If it is, make sure that you have removed all the SHIPPING SCREWS. Check for the one that holds the optical scanner. If this screw is left in the scanner will not move and cause error. ---should be on left side or under left side of optical pan. If all shipping screws are removed, do a once over and check to make sure that all shipping tape and paper are removed. Some companies use tape to hold parts in place.
Jan 03, 2009 | Office Equipment & Supplies
Xerox WorkCentre XE60 Laser Printer Logo
117 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
