Question about HP (D7600-60005) Motherboard
I have a D7600-60005 mother board with 512 MB RAM, and want to know the amount of memory supported by this mother board (I want to upgrade this mother board)
3 Suggested Answers
SOURCE: recommended memory for p4i45gv R5.0
Asrock p4i45gv motherboard supports only ddr1 ram (maximum 2GB).
DDR266, DDR333 and DDR400 are working but DDR400 is also treated as DDR333, by the motherboard.
Posted on May 31, 2008
  • 30 Answers
SOURCE: I want to upgrade my HP BA 600 Mother Board`s RAM Capacity
Most likely your MB is too old for this upgrade although there is a chance you could flash your bios (reprogram your computer's brain to accept the new memory providing hp has a flash for it).
here is a link for the latest bios flash for your computer, use at your own risk.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=32895&swItem=vc3903en&prodNameId=20305&swEnvOID=54&swLang=13&taskId=135&mode=4&idx=0
good luck.
Thank you,
agadycom
Posted on Nov 27, 2008
I have intel pendium d d102ggc2 motherboard. am using 512 mb ram ddr2 667mhz. Now i want to upgrade it and use 2 gb ram. please suggest.
Mother board d102ggc2
• Support for DDR2 533 MHz and DDR2 400 MHz DIMMs
• Support for up to 2 GB of system memory
Dec 27, 2012 | Intel D102GGC2 Motherboard
Hello again.I have an old home pc and I want to upgrade the cpu processor without changing motherboard.Wich is my best options?I want to know if I can to upgrade to PENTIUM 4 3.00 GHz.Also I want to put...
If new processor supports your old motherboard then you will upgrade system with your old motherboard.
If its not supported to new mother board then you have to buy new motherboard to upgrade your system.
Thanks.
Happy to help you.
Apr 30, 2010 | Intel CPU
T2742 Desktop eMacine I want to upgrade the RAM from 256 MB to 1 GB. Can I replace the single 256 MB memory board with a single 1 GB memory board? Or, should I use two 512 MB memory boards?
Maximum Total Amount is 1GB.
EACH ram slot's Maximum Amount is 512MB.
Note* If you only install one ram memory module, make sure it goes into Slot 1.
(On the motherboard it may have DIMM 1, printed next to the slot)
Slot one is closest to the Processor. The processor reads ram memory that is in Slot 1, first.
Apr 16, 2010 | E-Machines T2742 PC Desktop
I have compaq presario 5000 series...and iwant upgrade my ram ...i have 128+128 sd ram so how much i upgrade my ram...can i upgrade 512+512 sd ram OR 256+256 sd ram...thank you
the RAM upgrade will depend on ur motherboard capacity and specification.
u need to check ur MB manual
if ur MB can have only SD RAM then only SD RAM upgrade is possible...DDR will not work....
so be careful while buying ur RAM
intelD845GLLy MB...the following details are from the intel website
http://www.intel.com/support/motherboards/desktop/d845glly/sb/CS-012825.htm
System Memory Features
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
Caution Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
hope this helps
Reg....bye
Feb 24, 2010 | Intel D845GLLY Motherboard
I have an asus k8v-mx motherboard running only 512 mb of ram what type of ram would suit this mother board and could i fit a 1 x 2mb ram instead of 2 x 1mb?
Dear Sir,
*********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
good luck
Aug 05, 2009 | ASUS K8V-MX Motherboard
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Need to increase the ram on the VGA Card
My friend you can add RAM on your VGA by purchasing another Higher Video card  RAM. you can buy 512mb (265 - 512 bit) VGA Card to increase your VGA RAM.
Jun 18, 2009 | ASUS P4P800-X Motherboard
I have 256 MB RAM which is slow, can i upgrade it to 512 MB RAM
Depends completely on what motherboard the computer has and what it supports, I could check on it if you have and brand and model of the computer, or from the motherboard.
Sure the prosessor speed doesn't affect the memory amount possible don't worry about that, just need to find out how much is supported and at what speed etc.
Thanks,
Ekse
Jun 03, 2009 | E-Machines -T1840-CELERON-1.8GHz,40GB...
good luck.
Thank you,
agadycom
Nov 27, 2008 | HP Computers & Internet
Recommended memory for p4i45gv R5.0
IF UR RAM IS SDRAM THEN U CANT UPGRADE TO DDR BUT IF ITS ON DDR RAM THE U SHOULD B ABLE 2 UP GRADE 2 1GIG OV DDR RAM RUNING AT 400MHZ
Dec 25, 2007 | Asrock P4I45GV R5 Motherboard
Computers & Internet Logo
179 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
