Need wiring help for replacing trane model baystat 239 with a honeywell th8321u thermostat
  • mastabiatch1 Apr 27, 2009
    I have a blue - red - green and yellow wire to hook into a ritetemp digital thermostat... C - B - O - W2 - W - Y - Y2 - RH - RC - G - A... to put those wires in... I am only hooking up an A/C to this with a two speed motor/or fan along with pump etc. I don't know which wire to put where... I have a MasterCool & prior to this had a MasterCool Plus thermostat... HELP !!! Hot as hell in the Mojave desert..
  • 770 Answers
I am not sure of what help you need on it but here are the most common wiring on a stat
W= heat
C=Common (24V)
R=Hot (24V)
G= Fan
RC=Hot (24v for Cooling)
RH= Hot (24v for Heat)
O= Reversing Valve (Heat Pumps Only)
Hope this helps
Posted on May 11, 2008
Heat/Cool does not respond after replacing Trane Weathertron BAYSTAT239 with Honeywell RTHL3550
Sounds like you didn't turn the power off and blew the low voltage fuse. Typically a 5 amp blade style (like a car) inside furnace. TURN THE POWER OFF!!
Jul 13, 2017 | Heating & Cooling
I have a Trane 3AAT80B1A1 thermostat that I'm replacing with a Honeywell RTHL 3550D. Is it possible to do this myself or will I need to have an electrician come out?
The easiest way to be certain the wires get connected is to cut the wires close to the screw without loosening the screw. That way the color of the wire can be seen on the correct terminal without mixing them up.
Feb 24, 2013 | Heating & Cooling
Honeywell RTH6300B to replace Trane Baystat 239
Sad to say but you have bought an non compatible thermostat, what you need is a thermostat that has "Heat Pump" somewhere on the package, Honeywell makes those also in the same models, sometimes they can be tricky if your not looking. It should also say 2heat, 1cool too. Hope this helps and good luck!
May 23, 2010 | Honeywell Focus 6300B 5-2 Days...
Upgrade Baystat 239 to a Honeywell RTH7600D controller
For Trane sytems, B is your "Common" wire. O is your reversing valve relay, G is your fan, Y is your compressor contactor, R is Hot, Brown will not be used on your electronic tstat. X2 is your backup electric heaters. Without knowing what terminals are on your new tstat, I cannot offer more information than this. The installation manual may indicate what each terminal is controlling. I strongly suggest to write down ALL of the terminals and colors from your old t-stat and be sure to turn off the power to your air handler. Put the fan switch on your tstat to ON before turning off the power. Make sure the fan is running. Then turn the power off to your Air Handler. If your fan stops running, you have turned the power off to your tstat and are ready to start replacing it with your new tstat. I hope you find this helpful. Good Luck!!!
Feb 06, 2010 | Heating & Cooling
Need wiring for honeywell pro 3000 in trane xe1200
the pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
May 16, 2009 | Heating & Cooling
Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Sep 30, 2008 | Heating & Cooling
Heating & Cooling Logo
471 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
