My hdtv monitor rca wont turn on model#d52w27d the light on the on off switch lights up for 10 seconds then goes out same thing a second time no noises have to un plug and plug back in to try agin.
  • marjan49009 Sep 05, 2010
    thank you, not worth fixing
  • 10,515 Answers
Well unfortunately it is impossible to know exactly what is wrong because this model has more shutdown circuits in it than any other I have ever seen. See all the circuits are monitored in this television and when one malfunctions it shuts down and gives us this symptom. I will give the most common causes and prices, hopefully that will assist you and if you need anything further after that please let me know and I will be happy to help.
The most common cause for this tv to shut down is the high voltage circuit, sometimes there are a few components that need to be replaced to get the set running again. If this circuit is the cause then you could be looking at somewhere between $300-$400 on average to have the set running again.
If the horizontal circuit is not the issue then most likely it is being caused by either the high voltage trippler or one of the picture tubes. If the trippler is the cause then you would be looking again at $300-$400 and if one of the picture tubes was the cause then you would be looking at around $600 (tubes are expensive and very hard to install.)
Lastly you could have a problem with the signal board, I somewhat suspect this for you...we have seen some bad caps that can cause this problem, if they need to be repalced you can expect around $300-$400 for the repair. On your model the signal board could also run around $600 if it needed to be replaced. (also most of the time when a signal board fails it goes intermittently, some days the tv will work and then other days it will not)
I am sorry that I do not have any good new or quick fixes for your set. You definitely have a internal failure in your set. Please let me know if there is anything else I can do for you.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 03, 2010
Mitsubishi hdtv
NOT A GOOD IDEA AT ALL!
You likely now have one of two things happening:
1. Green power light constantly blinks and will not stop(should blink for 70 seconds and go out).
2. Green power light comes on and a few seconds later goes off.
Which do you have?
May 17, 2012 | Mitsubishi Televison & Video
I have a 52" RCA
The deflection board needs replacement. You need the PSB260 deflection board available from www.tvrepairworld.com
May 17, 2011 | RCA R52WM24 52" HDTV Projection Television
POWER LIGHT FLASHES 3-4 TIMES AND SOUNDS LIKE TRYING TO COME ON B
This will need a capacitor replaced on the power/deflection board. (CP150) This is a very common problem on these sets. Service man will probably charge at least $200
Jul 05, 2009 | Televison & Video
Tv's green light comes on then off three times
Check capacitors cp150 ,114, 120 ,if cp150 is puffed up on top it is bad.2200uf 16v and the other 2 are 220uf 35v.
Feb 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Wont turn on
there may be a short in the system. Bad news: You should have a licensed pro help you diagnose it and fix it. Good news: its fixable.
Aug 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power issue
Same thing, comes and goes; there are times that it would not come back on for 10-15 minutes... any ideas
Jul 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Television D52W14
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Jan 08, 2008 | RCA HD50LPW175 50" HDTV
Open Questions:
Mitsubishi WS-65511 Rear Projection Big Box TV resets with a green flashing light every 5 minutes, Then works fine for 5 more minutes (perfect picture). Acts up worse when cold. Warm it up Works hours It's NOT the DM board caps. I've already replaced the DM caps twice. Not the problem. No repairman will look at the set. Too Old. So am I. I could repair it with help. The power supply must have a safety circuit that will shut down & reset if too much draw. I DON'T have a diagram. I'm not sure how to trace it . Which board? If I unplug boards one at a time, Will it damage other boards ? I know it is NOT the 7 DM board caps everyone keeps telling me. I see no burn't parts, No bulging caps. Tapping on components doesn't reset. What kind of component would act up when cold , But not overdraw when warm? This set has the best beautiful picture when it runs. If you can get past the resetting every 5 minutes for the first hour, You can watch it sometimes for 20 hours. I've left it on at night & it is still on the next morning. Change the channel Or raise the volume, And off it goes. Once or 10 times, Keeps resetting. Then on for 4 or more hours, Maybe. I can't afford a new one. It works GREAT ! when it works. I've notice that even when the set is turned off, The green light starts flashing (resetting itself while it's off) , Then stops. Once in a hundred times it will kick off the breaker & you need to push reset with a pin on the front panel next to the green light. It's probably a 10 cent resistor OR a $ 1.00 cap. If I only had someone with more knowledge than me to help. I know how to use a meter & read a schematic. I built a Heathkit 25"TV in the 70's & all my novice ham gear. I'm 64 & not familiar with digital circuits. Can someone help PLEASE ?
Dec 16, 2017 | Mitsubishi Televison & Video
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
