Question about Yamaha Audio Players & Recorders
How do i hook up my yamaha natureal sound eq-70 to a denon avr 591 receaver
    Problem Solver:
  • 5 Answers
From cd analog output to input at the yamaha, then from output to dvd/cable/ cinch input at the Denon. how do i hook up - faae4fd.jpg
Posted on Sep 03, 2010
  • 52 Answers
An EQ usually plugs between a preamp and an amplifier. You have a receiver. There's no connections that will let you do that. The only thing you can do is between a source(ie: CD) and the receiver. The CD will go in the eq and out of eq to cd input on the receiver
Denon AVR 591
This is where a circuit diagram would come in handy, displays are tricky to trouble shoot, and this a job for a pro.
Apr 02, 2012 | Denon Audio Players & Recorders
I have a denon AVR-591 receiver. its hook up but i can't hear anything. can someone help me out
Crack the manual open and do the speaker setup routine. It's there to establish hardware integrity before you listen to actual programming.
Aug 11, 2011 | Denon Audio Players & Recorders
I recently bought the yamaha rx-v567 and I own a yamaha EQ-70. How do I configure and hook up the EQ to the receiver?
The EQ is connected via one of the Tape loops on the amp (rec out from EQ to play in on amp,rec out on amp to play in on EQ). You then switch "Tape Monitor" on to hear the sound with the EQ settings applied. You can also connect it across Pre out and Main in should you have such sockets. I'm pretty sure it will only affect the main two front channels and not the surround channels.
Dec 19, 2010 | Yamaha EQ-70 Home Equalizer
Eq to receiver
Connect through the tape monitor jacks and if a tape deck is used connect it to the eq! Check your owners manual if you still have it or download one.
Apr 14, 2010 | Yamaha EQ-70 Home Equalizer
How do you hook up an EQ without having a tape 2 function?
Keep in mind the EQ will only be useful on stereo analog material. Activation of any Tape Loop will disable digital source throughput. Use VCR 1 or 2 audio connectors.
Mar 11, 2010 | Denon AVR-2105 Receiver
How to hook up my Yamaha EQ-70 Equalizer
This is official image from Yamaha. If need to know more, go to the below address -
http://www2.yamaha.co.jp/manual/pdf/av/english/am/AV-90PY.pdf
download the amp's manual & you will find on page no. 7
Jul 05, 2009 | Yamaha EQ-70 Home Equalizer
Denon avr 2308 no subwoofer operation
is the sub in speaker set A and sub in set B?
that was my problem on Denon DRA-455 with Eltax Linear 6.5
May 29, 2009 | Denon AVR-2308CI
Audio troubleshooting with an AVR Denon 900
ok i have the same reciver do you use hdmi to go to your tv or componet what ever you use there will be an audio out for rca on the cable box if you dont use a cable box keep reading but use hdmi to tcv then the rca audio out to the denon avr 900 obviously out it in the vdp/tv unput. and if you dont use a cable box your tv shoiuld have an audio output in the back of it for rca connect rca to audio output then other end to the denon avr 900s vdp/tv input
Dec 27, 2008 | Denon AVR-900 Receiver
Is it possible to to have a home theatre with Denon AVR 3600
one option that may yield results, since the bose connection to equalizer is presently not possible is to set the speaker out put on the denon for 'small' on all but the front speakers.
and then set the delay for all speakers based on the distance to the amp.
this should result in better audio that that with the bose eq.
will work on the issue of using the eq. with the denon if you like. but, you will likely not improve on the sound with the denon set up correctly.
good luck
mark
Dec 17, 2007 | Bose 901 VI Main / Stereo Speaker
Hooking it up!
If the amp has PreIn PreOut connections, then thats the best way to go. Home theatre amps however, have 5 InOuts, and this makes it hard. You can use the tape loop. Hook up the rec out on amp to inputs on EQ, and output of EQ to tape in an amp, then engage the tape monitor function whilst ensuring that the rec selector has the source you wish to use the EQ for.
Nov 08, 2007 | AudioSource EQ-200 Home Equalizer
161 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
