Question about Frigidaire Refrigerators
My frigidaire fridge/freezer model number f44n21gs is not getting cold. i have replaced the relay which i think was bad and the fan/compressor seems to be working fine. what could be the problem?
22yooper
  • 828 Answers
SOURCE: freezer fine /After power went out twice fridge not cold enough
In back of the refrigerator is a removable panel behind which is the compressor. Listen for a hum and a click. If you hear those sounds the compressor may have failed. Behind that same panel is a condenser where heat is removed from the refrigerating system. Make sure it is clean and check that the fan operates when the compressor runs.
Posted on Jun 09, 2008
Krazytech
  • 725 Answers
SOURCE: FRIGIDAIRE FRT21PRH Not Freezing
if the evaporator has a full frost pattern it is not your compresser... First I could check your fan motor is it running...if the frost blocks the air flow it will stop cooling.. Next it could be a defrost problem or a plugged drain... to get it to work temporary defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help
Posted on Sep 01, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
peyton32034
  • 410 Answers
SOURCE: freezer/ fridge not cooling, compressor not running
this refig has 2 independent temp controls one that operates the freezer side (this one also operates compressor, condenser fan and evporator fan) and one that controls the temp for the fresh food side this one operates a damper and evaporator motor.
I looked up you model number and you need to check the control that is located to the left side of the control panel or the freezer control. if it is 60f in the unit then if this control is good it should read infinity on a ohms meter. if its bad you will get no reading at all. alternatley you may try hitting the control solidly with the **** of a screwdriver sometimes the contact will hange open. message me back if you need further assistance. peyton...
Posted on Jan 28, 2009
  • 113 Answers
SOURCE: Fridge/freezer not working
unplug it for 24 hours plug it and see if the compresor is running if its trying to click on and off your start relay may be bad
Posted on Apr 29, 2009
I have a frigidaire pro FPHS2386L and the freezer is too cold. Any ideas?
George makes a good point but I'd like to add that there is generally a fan that blows the air between the freezer into the fridge area. If there is no obstruction, the fan most likely needs to be replaced. On a few models this can be done with a little patience and a screw driver and the fan part. Check with a Sears Parts distribution store avaiable around the country for the part if the model is carried by Sears. If not, Google the fridge make and model number with Freezer Fan Replacement.
Nov 23, 2014 | Frigidaire FPHS2386L Stainless Steel...
WILL NOT COOL OR MAKE ICE. COMPRESSOR DOES NOT SEEM TO COME ON.
next time send the model number off of the fridge,side by side or bottom freezer model number is in fresh food section,right hand wall up near ceiling or on ceiling,top freezer look on left side wall.if the compressor isn't running most likely you have a bad start device located on the side of compressor,pull out the fridge,unplug it,remove the back outside bottom panel and you'll see the compressor,pop off the metal clip,remove the cover and slide off the start device or overload and relay same thing,then shake the device,if you hear pieces rattling around inside it it's bad,easiest way to check it,if you open the freezer door and you hear the fan blowing around most likely this will be your problem,you might hear the compressor clicking trying to start and it will be hot,also vac out the condenser coil and make sure the condenser fan motor is running good,over heating can take out the start device.good luck.
Jul 05, 2012 | Frigidaire Refrigerators
I have a frigidaire model Frt18P5Aw1. The freezer is cold but the fridge is not. How do I fix?
there is a fan that blows the cold air from the freezer into the fridge. it's on the inside back of the freezer. it's either blocked in the freezer, in the fridge, or the motor is bad. remove any blockages in ther back of the freezer and feel if there is any air blowing into the fridge. if not, replace the fan motor. it's frigidaire manufacturers number 5303918549.
May 13, 2012 | Frigidaire Refrigerators
Hi, freezer took a dump two days ago, fridge was still fine. Then 12 hours later the fridge dumped out too. The compressor is hot and the relay looking thing with part number nsk 85851 clicks on for 20 sec...
most likely the start device is bad,look at the left wall inside the fridge near the cieling,you should see a model number,call your parts store,give them the model number on the machine,there is other letters after the g and tell them you need a start device.unplug the machine,until you get the part so you don't damage the compressor,it's not cooling anyway and thhe freezer feeds cold air to the fridge side,a fan blows cold air from freezer to fridge so next time if the freezer has a problem the fridge side is gonna have a problem too,unclip the metal clip and slide the start device off,read the instructions and it will tell you how to install the new device
Feb 06, 2011 | Maytag PTB2153G Top Freezer Refrigerator
REFRIGERATOR NOT GETTING COLD
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. If the relay is ok there is a compressor problem or low freon it it don't start
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
May 30, 2010 | Refrigerators
Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
May 23, 2010 | Frigidaire PLHS267ZA Side by Side...
Compressor doesn't run
If the fan located next to the compresor works that means that the compresor relay is bad or the compresor burned out.
Jul 18, 2009 | Frigidaire FRS23R4A Side by Side...
Roper Freezer Stopped Freezing
. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
Jul 02, 2009 | Refrigerators
Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Dec 22, 2008 | Frigidaire FRT18FS6C Top Freezer...
Refrigerator is out but freezer still works
Hello dan_2137
Welcome,
You said, overloaded freezer may have caused fan to go out? Is this possible? Cleaned dust from compressor and shut off to let it cool down but it is still not working
Yes It's possible. If the freezer is so packed full where the packages cover the air vents in the rear of the freezer.
The freezer and the fridge share the cold air and this is the first think we look for if the fridge is warm and the freezer cold, And the fan works nonstop rather than cycling off and on!
What is the model number and year of your fridge!
Waiting your response.
Huuum
Please remember to leave a rating!
Oct 20, 2008 | Frigidaire FRT21H8 Top Freezer...
Refrigerators Logo
156 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
