Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
My Dyson has suddenly starting making this LOUD, horrible sound when I am using it on the carpet setting. However, when I use it on the floor setting, I do not get this noise. Also, I think the 'sucking' power is not as strong.
  • 439 Answers
You need to check the beater bar on the bottom and the hose from the beater to the canister. You may have something stuck in the beater system.
Posted on Sep 03, 2010
My Dyson DC33 makes a horrible loud sound when I angle the handle to use it. If it stays in an upright position, it's fine, but obviously hard to use. Any idea what the problem might be?
The horrible loud sound is saying "help me I am blocked"
Because it is only blocked when you flip it down to floor mode this tells you only the floor part of the machine is blocked. There is a small hose inside the brush roller that is likely blocked. You should clean your brush roller once a month anyway.
Here is how to get at it.
http://www.youtube.com/watch?v=4Zk6-gkY5XY
Feb 22, 2014 | Dyson DC33 Bagged Upright Vacuum
Dyson dc17 makes loud noise on carpet setting. It's like a high pitch ringing almost but won't make the noise on hard floor, only carpet setting. Ive checked for blockages and cleaned all parts but makes...
It is probably the brush roll motor making the noise. Remove the brush roll & belt and turn both motors on. If you do not hear the noise when both motors are running the noise is likely coming from the brush roll
Nov 02, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Noise
Hi Linda,
Sounds like clutch problems, try to move the lever for carpet/floor back and forth a few times maybe it will free up. If it still makes the grinding noise, the clutch assembly will have to be replaced. Let me know, i can even walk you through the repair if needed.
Apr 08, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson making loud noise
If your brushroller isn't spinning it will make the loud sound. Try removing the brushroll and reinstalling it. If this doesn't work, you may need a new brushroller.You can find one here...
http://cgi.ebay.com/DYSON-VACUUM-DC07-DC14-DC-07-14-BRUSH-ROLL-BEATER-BAR_W0QQitemZ120452265897QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0b83b7a9&_trksid=p4634.c0.m14
Marci
Aug 05, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Loud noise when I start the vacuum in carpet position
It's most likely the Belt Slip Protection Dyson uses to prevent the user from having to replace belts. I recently bought a Dyson and love it other than it literally sits there and makes horrible noises 80% of the time. I completely disassembled the vacuum and found that the spring they used for this belt slip protection is WAY too weak. The weak spring seems to let the belt slip protection pop off way too frequently and unnecessarily. I stretched the spring back out and whammy no more horrible clanking. Of course it'll take you a couple of hours, some good tools and some serious ingenuity to get to where the parts are but problem solved. It'll still ratchet when picking up a sock or dog toy or something, but sitting there ratcheting on short dense carpet is unacceptable. Hope this helps!!!
Feb 14, 2009 | Dyson DC14 All floors Bagless Upright...
Not exactly a solution, but more of an explanation. The noise is caused by a ratchet device that's designed to protect the belt if the brush roller becomes blocked. It's a bit like a clutch that slips when resistance on the brush gets too great. The noise will occur if there's a solid blockage, of course, but it will also occur whenever the machine senses excessive resistance. This may happen on carpets with really thick pile, but can also happen if the carpet is loosely fitted and can be sucked up tight to the roller by the force of the vacuum.
Small consolation, but the problem should lessen as the brush wears. Meanwhile, if all else fails, switch the brush off (hard floors mode) while vacuuming the problem carpet(s).
Feb 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have a Dyson vacuum cleaner ...upright....all of a sudden my vacuum started making this awful sound...like a loud buzz...but only when I have it on carpet....when I have it on "floor" mode it's...
it may just be, that on carbet the brushes make noise that you dont hear on woodfloors.
If there is a hights adjustment, set it higher for shaggy carpet and lower for berber.
Mar 16, 2008 | Vacuums
Suden loud noise when vacuming carpet
Hi.
Check that brush roller (beater bar) is free to turn with no obstruction.
If it is still noisey after doing this try this site for Dyson repair manuals.
http://dysonmanuals.inc.io/
Chris.
Nov 11, 2007 | Dyson DC14 Full Access Bagless Upright...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
271 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
