Question about Samsung HCN653W 65" Rear Projection Television
My Samsung HCN653W projection TV will not power up. Pushing the power button, I hear the "start-up" chime and the timer red led starting blinking, but the other larger led does not light up. The start-up chime then repeats about every 20 seconds. I;ve just replaced the power/deflection board and there is no change. Any other suggestions? Ed McFaul
  • 4,889 Answers
Timer light usually starts blinking if there is a problem with the vent. Take of the back cover and empty a can of compressed air on it(the cover) so that it will be un-clogged. Put it back and turn it on.Let me know if problem persists so that we can continue troubleshooting.
Posted on Sep 04, 2010
I have no sound and no pic have talked to people on internet may be bad ic's dont know. I have unpluged ic's board and get a static sound and a tone when i turn it off and on and the timer light...
After the timer light blinks for a while say a few minutes do any other LEDs start blinking along with it? Please provide this info so that I can help you with your problem.
Sai.
Jul 17, 2011 | Samsung HCN653W 65" Rear Projection...
Tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
on Mar 29, 2011 | Samsung HL-R6167W 61" HDTV
Sony wega kdf42we655 power led blinking red
If lamp light is on at tv front then replace lamp as existing lamp sounds dead/ broken.
Lamp replacement procedure would be written in user manual of tv.
And if lamp light is not on but standby light is blinking then let me know how many times it is blinking to find out problem cause as standby light blinking is an error code.
Mar 25, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Samsung projection 42 in. floor model, powers on
tv is in shutdown, drawing to much current. usually focus or high voltage divider (sometimes they are one). not usually the power supply.
Jul 05, 2009 | Samsung Televison & Video
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv will not come on
Hello brexpress,
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Best regards
circuitcity
Jun 13, 2008 | Samsung HCN653W 65" Rear Projection...
No Picture - Sound
I just had this problem fixed. In my case, it was because the insulation on the CRTs was cracked, and when it would warm up, the shielding would separate and would let 5000 volts arc across the main board. This, obviously, damaged the board. The tech didn't catch the arcing right away, so they replaced the main board twice before they used a high-temp RTV to patch the insulation.
The power-cycling was a result of the damaged board.
The point of this story is that the broken part may be a symptom of the real problem.
I hope this helps someone!
May 29, 2008 | Samsung HCN653W 65" Rear Projection...
No picture no sound
Probably, the selftest fails while turning on. If this is the case, press input&menu buttons at the same time for 5 seconds, then the green led will start to blink. Let me know how many times the led blinks.
Regards
Mar 01, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Samsung HCN653W 65" Rear Projection Television Logo
99 people viewed this question
Jerry Greenberg
Jerry Greenberg
