Question about Kenwood DPX-501 CD Player
DPX-501 Root Menu Help
Like many of you, the display on my Kenwood DPX-501 has gone completely out but I still use it otherwise. My mechanic disconnected the battery last week and therefore reset some of the HU settings. All I really want is to turn the AUX option back on. Can anyone out there help me out with a step-by-step procedure of button strokes to do this (obviously I can't see any on the display). Thanks so much.
  • Marine1775 Jul 14, 2008
    display stopped working about 4 months ago (2 years old). all other functions seem to work. display came on about 3 weeks ago for about half-hour with complete functionality. turned engine off and then back on, it still worked. driving down the road it just suddenly went back out and hasn't come back on since. I recently installed a subwoofer and while I had the HU pulled from the dash, I checked all the connections and everything seems connected properly. still plays great, but VERY annoying with no display.
  • pinkyjones Dec 04, 2008
    I have the same problem. My display stopped working, we sent it in to get it fixed. The receiver was reset and now its in demo mode. When I try to get it out of demo mode it will not work. HELP!!!
I emailed Kenwood USA and they gave me the number to an authorized Kenwood service center on the east coast( New Jersey). I sent them the receiver, and within 2 days they sent it back completely fixed. They even fixed an error code I didn't even know wasn't working. Price on the repair will vary depending on the problem. If it is fairly new and still under warranty then there should not be any cost to repair it.
Posted on Jun 07, 2008
My Car Stereo Kenwood DPX 7021 MPI displays CODE, this happed after I changed the car batterry.
I HAVE INSTALLED THIS CAR STEREO IN MY CAR AND IT IS ASKING FOR A CODE. I DO NOT KNOW WHAT TO DO. CAN YOU GIVE ME THE CODE FOR KENWOOD DPX-7021MPi CAR STEREO PLEASE.
PLEASE HELP ME
Feb 12, 2011 | Car Audio & Video
Working but no display
there are some surface mount resistors inside of the deck that probably have bad solder connections.
Jan 18, 2011 | Kenwood DPX-501 CD Player
Kdc-mp245 is in protect mode, how do i find what speaker is shorting out?
disconnect all the speakers , may still say protect , reset eeprom by holding preset 3 & 6 +reset , display may show dc error , hold preset 1 fpor a couple of secomds then hold preset 2 for a couple of seconds , then display should show dc1 - ok / dc 2 - 0 , then connect speakers one at a time , check wiring ,this may cure fault
Jul 25, 2010 | Kenwood DPX-501 CD Player
I have a Kenwood DPX-501, and when I attach my Ipod Touch, it doesn't seem to work. Does the Ipod touch work on this stereo?
you need to call you local car audio shop and get a cable called a kenwood 301 ipod cable
Mar 20, 2010 | Car Audio & Video
Kenwood DPX501 Display is off.
These units are all made in China and there really is no "fix"...they simply replace them under warranty or swap out for a refurb. Sorry, you're not alone.
Good Luck
Jun 21, 2009 | Kenwood DPX-501 CD Player
DPX-501 LCD Repair
I got the new display part from the Kenwood supplier on LI, NY but there are dozens of pins on lining both sides of the display, each 1/16" from the other. I don't have confidence in my ability to detach the old and solder the new to the main board without further disaster.
Choices for me now are:
- continue "flying blind" - most likely solution for the moment.
- pay someone to do it - includes removal and being without a head unit for an unspecified time, plus cost.
- replace - I'd like to change brands although it means replacing the Kenwood satellite unit too, so more cost.
This hasn't been a good advertisement for Kenwood. People are impressed by the sound in my car, but not so much by the blank screen, guesswork changing stations etc.
I really like the unit, and the display was great while it worked: exactly as long as the warranty. I can't recommend Kenwood.
Aug 19, 2008 | Kenwood DPX-501 CD Player
Kenwood dpx-501
I just solved the problem with my kenwood dpx mp 2090U - (looks similar with 501). FL Display with single CD, USB, 2 Din.
I should share this......... as I received the clue from someone that share the same case to me . Thanks to Mr,Nasirbaek from Indonesia,
The problem is at the main board . Dry (bad) soldering occurred. There are more then 5 resistors in series configuration. The resistor is quiet big (1.5mm x 3.5 mm, surface mount type R) about 2,7Ohms.The position is start from near usb port cable and ended to near big transistor (1 x 1.5 cm power transistor). After resoldering check with multitester to make sure that all R are connected in series configuration.
Just open 3 screws to access the main board. 1 at the top case. 2 at cd assembly, then Carefully take out the CD and the CD ribbon cable.
good luck.
Mar 25, 2008 | Kenwood DPX-501 CD Player
CD player and everything works fine but there is no display .....
Well, my display went out earlier this week. Took it apart and found out that the LCD on the 501dpx was burnt out. I also found out all we have to do is replace the whole faceplate instead of the system
Jan 06, 2008 | Kenwood DPX-501 CD Player
IPod Interface not working
That happened to me and the PFD Manual online said it means it's a communication error between the ipod adapter and the ipod. The ipod in my case was totally froze and I had to reset it using the hold on off then holding in menu and select for 10 seconds and it rebooted.
Sep 24, 2007 | Kenwood DPX-501 CD Player
Kenwood DPX-501 CD Player Logo
384 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
