Question about Panasonic Lumix DMC-TS1 / DMC-FT1 Digital Camera
Why is there so much grain in my photos as well as being too dark? Is it a manual setting I need to change? I am getting these issues when running the camera on automatic. Thanks!
    Brigadier General:
  • 3,006 Answers
Unfortunately, it's difficult to answer this without seeing examples and without knowing what kind of photos you're taking.
But the camera shares the same fault which plagues so many other cameras these days which are trying to squeeze far too many megapixels from an undersized sensor: it suffers from horrible image noise at almost all ISO settings and it's dramatically worse above ISO100. Panasonic cameras are excellent but have a long-standing problem of being a bit worse than most other brands in this respect.
All you can do to minimise the effect is to avoid using high ISO's unless absolutely essential and to set the ISO to no higher than 100 instead of leaving it on Auto. Also, set the JPEG recording quality to the finest setting to avoid over-compressing the images. Your camera's design makes the issue worse as the lens zoom internally, so at anything other than wide-angle the modest maximum aperture of f3.3 drops rapidly down to a maximum of f5.9 which severely cuts the amount of light entering the camera and so requires either a slower shutter speed ( = unsharpness due to camera shake) or higher ISO's ( = more image noise).
On some compact digital models, setting the resolution lower to, say, 5MP (still more than enough for almost every purpose) improves matters but it doesn't seem to on the three Panasonic models I own.
Posted on Sep 03, 2010
My Camera has started adding alot of noise to all my photo not matter if its well lighted or not? why? help please...
This is GENERAL INFO for most small sensor CoolPix Cameras. You should use ISO 400 or LOWER. Any ISO over 400 will have Grain in you photos. If it is dark you need a tripod or surface to place the camera on with self timer.
You get ugly GRAIN with HIGH ISO... You get lots of NOISE with long shutter speed. I can take Good Photos at night (when I use a tripod) with ISO at 400. I can take 1 second exposures and they look fine. You cannot take good night photo without a tripod.
Mar 30, 2015 | Nikon D3000 D3100 18-55mm
Sony cybershot DSC-W110 digital camera . Resenty i came across a problem in image quality after taking the photo it has grains in it . Why and how can i fix it
There are 2 main reasons for grainy pictures, and there are pro's and con's to each.
The first is the Image Quality setting. You can increase the image quality in the menus. The down side for doing that in older cameras is it makes them a little slower to record the picturs and you can fit fewer images on the memory card.
The other option is the ISO setting. If the ISO is not on auto, the lower the setting (100 or 200) will have fewer grains, the down side of that is the picture requires more light (daylight, or flash).
Try changing those settings and that should fix your problem. If you don't have the manual, here it is.: https://docs.sony.com/release/DSCW120_EN_ES.pdf
Nov 07, 2014 | Cameras
Hi have a 9650CTS combine. I' m bizy harvisting corn. I've set all the adjustments according to the opperators manual however still get a lott of split corn in the grain tank, I even had the local john...
Contact John Deere customer support at 18005378233
tell them you have had dealer out with no help and ask to
speak to someone with knowledge of your combine. You
will need model number, and possibly serial number along with any changes you might have made. They should give you a starting settings you should make along with increments to increase etc.
Oct 31, 2017 | Garden
Screen and photos turn dark when zoom is used
Take a look at the manual - sounds like you have accidentally changed the white balance setting - you will want to set it back.
Aug 07, 2009 | Canon PowerShot SD870 IS Digital Camera
I want to know that how to adjust exposure level in sharp 1118 or how to make light copy with diganostics mode
l For manual copy density adjustment, press the AUTO/
MANUAL/PHOTO ( / / ) key to select
MANUAL ( ) and adjust with the LIGHT ( ) and
DARK ( ) keys as desired.
l For photographs, select PHOTO ( ) and then adjust with the
LIGHT ( ) and DARK ( ) keys as desired.
l There are 9 exposure steps indicated by 5 indicator lights. (The
indicators light up one or two at a time.)
Successive pushes of the LIGHT ( ) key will change the
indicator lights in the order (3) / (3•2) /(2) / (2•1) / (1).
Successive pushes of the DARK ( ) key will change the
indicator lights in the order (3) / (3•4) / (4) / (4•5)/ (5)
The automatic exposure level can be adjusted to suit your copying
needs.
1 Press the AUTO/MANUAL/PHOTO ( / / ) key
to select the PHOTO ( ) mode.
2 Press and hold the AUTO/MANUAL/PHOTO ( / /
) key for approximately 5 seconds.
l The PHOTO ( ) indicator will go out and the AUTO indicator
will begin to blink.
l One or two exposure indicators corresponding to the automatic
exposure level which has been selected will light up. The factory
default setting is level “3”.
3 Press the LIGHT ( ) or DARK ( ) key to lighten
or darken the automatic exposure level as desired.
4 Press the AUTO/MANUAL/PHOTO ( / / ) key.
l The AUTO indicator will stop blinking and will light up steadily.
l This automatic exposure level will remain in effect until you
change it again by this procedure.
Automatic exposure adjustment
AUTO
Jul 27, 2009 | Sharp Office Equipment & Supplies
Missing shot.
Any auto camera like this is going to have trouble in dark light...
Photography is all about light, and in dark situations, compromise as well.
You best chance is to set the ISO up to the highest setting available, use flash, and a faster shutter speed, however, faster shutter speeds means less light can enter the lens, and hence give a darker image. Higher ISO makes the camera more sensitive to light, but produces grainier images as a result. Flash creates artificial light...
The only real way to get good images at a concert in the dark is with a high end camera, a lens costing many thousands of dollars, a tripod or monopod to steady yourself, and a longer open shutter time.
In the meantime however, experiment with higher ISO setting, flash and try to keep your hand steady at all times because the shutter speed needs to be slightly slower for the lens to capture more light.
Apr 06, 2009 | Fuji FinePix S8000fd Digital Camera
Macro in sony W170 digital camera
The resolution of the photo you take determines how grain shows up as you zoom into the Photo, So taking a 10 megapixel photo on optical zoom or no zoom will give you a sharper picture than when you use both the optical and digital zoom to grab your picture. The digital zoom uses the centre of your CCD picture imager rather than the whole CCD so with less elements to your picture when you take it gives you blockiness sooner when you zoom in on the image. I am guessing your friend has digital Zoom turned off in settings to prevent the Graining showing upon magnification. Good light and a steady camera will give you the best results.
Dec 05, 2017 | Sony Cyber-shot DSC-W170 Digital Camera
Photos print too redish; blues are purplish
Photo Prints Slowly on HP Advanced Photo Paper
... 8250, 8250xi and 8250v Printers - Photo Prints Slowly on HP Advanced ... Prints Slowly on HP Advanced Photo Paper - c00564372 ... 8250, 8250xi, and 8250v printers print a photo on HP Advanced Photo Paper slower than expected. The ... s.gif » Choose the Best Ink Cartridges for Your Printing Task
Choose the optimum combination of ink cartridges to enhance photo quality. s.gif » Printing Photos from a Memory Card
... to view, select, enhance, and print photos. You can also print camera-selected photos, photos you ... in the Main tray or Photo tray. Check the Photo tray light to verify that ... Load photo paper. Check the Photo tray light to verify that ... s.gif » Problems Printing from the Photo Tray
Instructions and troubleshooting on photo tray printing issues.
Aug 27, 2008 | HP Photosmart 8250 InkJet Printer
Canon eos 3000 wouldnt take photo
Set to ISO 800
Set camera to manual mode
Set Shutter to 125
Set Aperture to 5.6 or under
You're ready to go.
Too much grains, then lower the ISO.
atdlee@netzero.com
Dec 22, 2007 | Canon EOS 3000 Kit 35mm SLR Camera
Panasonic Lumix DMC-TS1 / DMC-FT1 Digital Camera Logo
82 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
