Question about Samsung AW1203B Air Conditioner
Window unit spitting water out of air vent - Samsung AW1203B Air Conditioner
  • Samsung Master
  • 17,130 Answers
Possible thatt due to non cleaning of the filter the cooling coil fins have got choked with dirt. The condensation of water on the coils will make it flow out of the area instead of dripping down to be drained out through the chassis out let..
So open the front grill, remove filter and use agood air /water jet to clean well so that there is air gap in the fins.
This must clear the issue as water will drop down to the back side to the chassis to be drained without any spill.
Posted on Sep 03, 2010
  • 86 Answers
SOURCE: leaking water
water leakage from indoor unit
1.clean cooling coil
2. wash air filter
3. check drain tray.if it block then clean it
4. check drain pipe U band.
5.check indoor unit water tray.if damage change by new one or repair it
Posted on Mar 15, 2008
Krazytech
  • 725 Answers
SOURCE: LG air conditioner spitting out water through vents
Hi Mia
I would worry about coolant .. your problem is that the drain in on the outside is pluged or the AC is not installed correctly and is not draining to the outside as it should...
hope it helps
let me know
Posted on Apr 09, 2008
  • 1073 Answers
SOURCE: air conditioning unit is spitting out water
unit need to be tilted to the rear as it is installed in the window for proper drainage of condensation water off of the interior coil
the fan on the rear will pick up the water and remove it
tilt it back a little
Posted on May 27, 2008
koolbreezes
  • 540 Answers
SOURCE: window unit air conditioner
Sounds like a full cleanning job or the drain line is plugging up. First , check for A 10* lean toward the back of the unit for proper drainnage, 2- check for good air flow thru the front coils--(dirty filter --dirty coil and last ,add some clorox bleach all across the front coil while off>)
Posted on Sep 02, 2008
hvac1
  • 338 Answers
SOURCE: WIndow A/C Unit- Not Draining Water
do not close your vents on the a/c unit because this makes the compressor have higher head pressures in the long run will cause the compressor to fail it will last longer if you set the thermostat to lower setting rather than closing off the vents. You need to clean out your condensate drain I use a small wire brush and water hose clean them out.
Posted on Jun 22, 2010
Brand new GE room size ac unit (1 week old) is spiiting water out of the air vent into the room. Unit 100% level.
If a brand new unit is spitting water, i waould suggest that it is short of refrigerant... Get your installer back or the Manufacturer.. You need to hold An ARC licence to do this ( In Australia)
Jul 16, 2011 | Heating & Cooling
Window air conditioner is spitting water
Hello, usually a window AC will spit water if the unit is not tilted back or if the drain is backed up, if the unit is level try tilting it back it the window somewhat. Also, if the unit does have a drain make sure it is not blocked.
Jun 19, 2011 | Haier Hwr10xc6t Air Conditioner
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Jul 22, 2010 | Kenmore 6000 BTU Single Room Air...
Condensation buildup
Make sure the unit tilts towards the outside. If it's installed level or tilted toward front it will not drain properly.
Jun 25, 2010 | LG Electronic Window Air Conditioner
Sears Plasmaire spits water into room
It's probably just holding water somewhere and getting thrown out. I've seen people drill holes on the bottoms to drain water quicker.
Sep 03, 2009 | Kenmore 75085 Air Conditioner
Droplets of water are coming from the vents and it's making a noise like something is rattling around inside. What could this be?
The problem with this unit is that the evaporator, or the part of the air conditioner that 'creates' the colder air is not draining correctly. Pertaining to a window unit, it needs to be installed correctly with the correct amount of tilt toward outside, to allow the evaporator condensation water to drain. You may also want to check to make sure there aren't any plugged drain holes in the air conditioner housing.
The rattling you hear is most likely the blower fan spinning against the held water inside the unit.
I hope this helps! :)
Sep 01, 2009 | Heating & Cooling
My haier a/c window unit is spitting water through the vent
Thermal transfer-the unit is creating condensation.
Jun 03, 2009 | Haier Heating & Cooling
check the filter located behind the front panel it usually snaps out also make sure the drain holes on the out side bottom of unit are not stopped up and that the unit is leaned back slightly for drainage freezing is a sign of low air flow or low on freon the coil actually gets colder when freon starts to leak out hope this helps with your problem
May 15, 2009 | Haier hwr10xc6 Air Conditioner
Hi Mia
hope it helps
let me know
Apr 07, 2008 | Heating & Cooling
Troubleshooting
first I would check your air conditioner to see if it is tilted backwards it should drain to the back (outside) . also check to see if the evaporator tray is clear of debris. if it is pluged up water may back up.. let me know and if this don't help we can go deeper..Thanks
Aug 23, 2007 | LG LB8000ER Air Conditioner
Samsung AW1203B Air Conditioner Logo
387 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
