Question about HP Pavilion a1610n PC Desktop
Monitor goes to sleep immediatly and no input signal and recommended setting 1280 x1024 sign comes up
  • 37 Answers
FIRST DONT PANIC. turn the computer of check the connections are secure. Then try it again if no change if possible try another monitor. If the fault still continues you need tools. You need to find out if the video card is part of the system board if so you might try resetting the bios on the board it sometimes resets everything (not the OS). if this does not help then it might need a new video card check *********** board for the type of connector for vieo cards and buy a new one. The better thr video the quicker your pc will run. A on boatd video card can use a lot of the computers resoarses for its needs.
hope it helps
Posted on Sep 03, 2010
Monitor goes to sleep immediately after turning on the computer. How can I fix that?
go to start,then pc settings,then monitor or power options the to power and sleep and change on plug to 4 hours and on battery to 10 minutes
Jun 11, 2015 | Computers & Internet
NO DVI INPUT SIGNAL AND MONITOR GOES TO SLEEP
you can't run 2 different inputs at the same time. VGA takes prescedence.
Apr 06, 2014 | HP L1950 Monitor
No input signal recommended settings hp vs15 monitor 1024x768 60h
old monitor 1280 x 1024
power light on?
OSD work?
if it said on the screen no input sig, then that is 100% true
the PC is not sending output.
check the video cable connections both ends
then if bad, boot PC to safe mode. does that work.
then maybe you set the PC graphic resolution too high for the monitor. use safe mode to set new , legal resolution
1280 x 1024 is max, do not exceed, the horz, vert, reso to the left here. if you do the monitor , will display, out of range. errors.
im confused, you show HP monitor then Sam.
why ?
my guess is HP question posted in SAM section.
so here is my HP answer
1280 x 768 @ 75Hz
if your PC or other device exceeds any of those. this old monitor
will go blank.
HOR, vert and refresh rates max.
to solve this riddle, set the PC to
1280 x 768
then connect monitor and bingo.
but there is a chicken and egg deal here.
if the display car is over this, as most new systems are.
then use safe mode to set the resolution to 1280 x 768
and reboot to normal mode.
boot and it F8 , safemode.
Sep 25, 2013 | Samsung SyncMaster 960BF (White) 19" LCD...
An incompatible video signal has been received check the output device settings connecting a sharp aquos to my ati radeon HD2400
what the problem is your pc is displaying a resolution you monitor cant display most likely its to low do you have a 2nd monitor you can hook up to set resolution Once you have done that set resolution that your new monitor can take and then hook up . when i moved from a 19inch monitor which ran at 1280 x1024 to a 32 inch samsung 1360x768 i had same problem as my screen cant display that res so set to what ya monitor can do .If you dont have a second display keep connected turn pc off with only your sharp cable in and it should turn on once into windows
Oct 07, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Need to change resolution but cannot get onto desktop to do so as the monitor just goes to sleep
plug it into your laptop and change the settings to the monitor to 800 by 600 pixels, then change the refresh rate to 60 hz or you could change it to 1280 by 1024 pixels and 60hz but it should work with 800 by 600 too, then plug it back into your desktop it should work then
Apr 13, 2009 | HP L1706 17" LCD Monitor
My W2207 monitor keeps going to sleep
Hi,First there is no signal from the PC . check if the display card has come out while moving the monitor, or just reinsert the display card in the PC , then boot the pc .
Jan 14, 2009 | HP w2207 Monitor
I have an error message on my screen which ios moving around. It says - 'not optimum mode. Recommended mode : 1280 x1024 60Hz'.
Sounds like you have an LCD monitor. LCD monitors look best in their native resolution. Yours must be 1280x1024. You need to (assuming this is a Windows PC) right click on the desktop and choose Personalize, Display Settings (Vista) or Properties, Settings (XP or older). Set the slider to 1280x1024. It'll confirm the change and then the message should never reappear.
Aug 28, 2008 | Computers & Internet
Error message
Kathryn, In the lower left, under the screen there is a row of buttons... One is labled "AUTO" have you tried pressing auto and if so does anything happen?? If not try pressing "MENU" first and then "AUTO"... What we are attempting to do is to get the monitor to accept the current settings so we can get the screen up and then deal with changing the resolution... In a Windows operating system the resolution is changed by going to "START" - "SETTINGS" - "CONTROL PANEL" - "DISPLAY" and in that window click on the "SETTINGS" tab and reset your resolution. This one might take some better communication that emails - because it would be easier to know in real-time how the monitor is reacting as you input various things... You can give me a call at 360-642-4993 or we can set-up a live chat. I'm assuming since you were able to place this post you have a second computer to work from? Bill
Jun 06, 2007 | Samsung SyncMaster 913N 19" LCD Monitor
HP Pavilion a1610n PC Desktop Logo
101 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
