Question about Bosch SHU5315UC Dishwasher
IT TAKES A LOT OF TIME AND THE TIMER DOESN´T CHANGE
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
**What I`m about to share applies to Almost all Electronic control B/S/H/ dishwashers. That includes Bosch, Thermador, Gaggenau and Siemens.**
Based on your description I know what the problem is, though you may not like it. I would still start by checking your water inlet temperature, the unit must be connected to a "hot" water supply line. Try running the hot water at your sink tap to insure the cold water is out of the lines just before you turn on the dishwasher.
That is just a suggestion out of courtesy however...
If it is what I suspect, the control, this won't make any difference but it's worth a try. If on the other hand the water is good and hot entering the machine, you likely have an issue with the control as I alluded to.
The reason your dishwasher never completes a cycle or takes an extremely long time, is the control has detected a heating error. Here`s the most likely reason why it has detected the error...
Even if your home water supply appears hot, it's not hot enough and must be heated by the dishwasher to insure a proper clean and dry.
The issue with your dishwasher likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
This is why it runs really long/forever unless you "stop" it or by pressing the two buttons for "cancel".
To repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The burnt solder joint will be one of the pins from the heater relay, hence the unit runs on and on ( because it can`t heat to advance or until canceled ) trying to heat the water.
You can also enter a test to check for proper amperage via the use of an ameter as such...
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question's, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries.
Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied.
Good luck.
Macmarkus :)
Posted on Sep 03, 2010
My maytag neptune MDE5500AYW will not stop unless it is unplugged
if you have it on time dry and it counts down but won't shut off you most likely have a bad computer board,part number 33003028 and it's around 180 dollars.on older machines it would be a problem with the timer not going to off but you have a computer board in your machine and it takes the place of the timer and other functions,just about everything runs through the computer board.
Jan 10, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Hobart sr24h; It is doing a double cycle; runs a compleat wash and rince cycle stops then 30 sec later start over so our normal 3 min clean now takes 7 min to fully stop operating. What could be the cause...
Thats easy....Change your timer !! The timer turns 180 degrees for one cycle .Then 180 degrees for another cycle thus completing a 360 degree rotation . One side of the timer appears to be broken.
Sep 17, 2011 | Hobart SR24-H Built-in Dishwasher
Have a 4003-00 Timer for a business park outdoor parking lot lights. I need to change hte tim to come on ~ can't find the book to tell me how to change this? Can you help?
ef74fbb.jpgParagon 4000 series is a mechanical dial timer
Image explains general operation of timer
Attach Black tripper to dial at time you want lights to turn OFF
Attach Silver tripper to dial at time you want lights to turn ON
Minimum on-off period is 1-1/2 hours
Re-set dial after power outage.
The dial rotates with passing time
The timer takes the Paragon X2772 tripper
If tripper does not turn lights off-and-on, then you might need new trippers
If dial does not rotate, you might need new timer
If manual override does not work then check electricity
http://waterheatertimer.org/Paragon-timers-and-manuals.html#Paragon4000
If you need more information, add a comment below and I will respond.
Oct 27, 2010 | Paragon REPLACMENT MECHANISM 110V SPST -...
It wont print but it doesn´t report no errors, it just doesn´t print
data cable connection may be loose
fix it properly or
change the data cable
Aug 12, 2010 | HP DeskJet 710c InkJet Printer
How do I change the time display on Norstar Startalk 180 - can't find anything in manual relating to this?
the startalk takes does not store the time, it takes the time and date from the phone system. to change the time on the phone system try feature **TIME (8463) password CONFIG (266344) from a phone with the 3 soft buttons under the display it does depend on the model and software level as to whether this will work and also presuming nobody has changed the default password
May 19, 2010 | NorStar Startalk Flash 2 Phone
Proxies
Try www.hidemyass.com. It's kinda' laggy, but it works ok sometimes.
Apr 20, 2010 | YouTube Videos
LG V181 DVD player/vcr combo doesn´t read de DVD´s
You need to go inside and clean the lens yourself with Servisol video 40. You might need to wipe it with a cotton bud etc. Allow it to dry before checking. Repeat it several times if it doesn't clear up first time.
PS check the lens for damage with a magnifiying glass! First!!
Jul 13, 2009 | Televison & Video
Doesn´t start
Have you tried "Last known good configuration"?
May 30, 2009 | MSI K9N GM2-FID (7252030K9NGM2FID)...
Bosch SHU5315UC Dishwasher Logo
386 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
