Question about Amana Refrigerators
Side by Side refrigerator/freezer Model #SCD22TBW Mfg. #P1303511W W SCD22TBW How do I remove the drip pan? How do I change the filter for the water?
Model #SCD22TBW
Mfg. #P1303511WW
Trying to find replacement gaskets (freezer
Posted on Sep 26, 2010
How do i replace the cracked drip pan in the french door refigerator
  • Unplug the refrigerator from the power source and remove the decorative vent cover at the bottom of the fridge under the door. Some vent covers are screwed on but many just snap onto clip that hold them in place.
  • Pull gently on the exposed front edge of the drip pan and ease it out towards you. The drip pan slides on runners on each side of the bottom of the refrigerator. It may be full of liquid or debris so go slow and steady and then discard it.
  • Line up the new drip pan with the two side guides beneath the refrigerator and slide into place. Use the flashlight if to make sure the drip pan is in the groove on each side.
  • Clean and replace the vent cover by clipping or screwing it into place. Plug the refrigerator back into the power outlet
  • Dec 15, 2013 | Freezers
    How do i remove a drip pan from a kenmore refrigerator
    The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
    Instructions
    Rear Access
    1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
    2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
    3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
    Front Access
    4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
    5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
    6 Pull the drip pan out from under the refrigerator.
    Apr 20, 2012 | Kenmore Refrigerators
    How do I remove the drip pan from under the freezer? It's full and leaking onto the floor?
    There should be a decorative kick panel underneath that will snap out revealing the drip pan which will then slide forward and out to pour the water off.
    Nov 25, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
    My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
    I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
    The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
    To fix requires either plastic welding, or replacement of the solenoid block plastic body.
    To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
    Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Where is the pan where the water drip into
    Hi, well the pan you are referring to is called the "drip pan" pretty clever huh?lol well this is located underneath the unit most commonly under the freezer side towards the back. To find it you can pull the fridge out from the wall and unplug it. Then remove the cover panel for the compressor and sealed system. When you remove this panel you will be able to see the drip pan under the freezer. Im assuming you are needing to find this because it is leaking. That is a very common problem due to the pans being made out of plastic and being exposed to temperature changes will sometime cause it to crack. I hope this helped you in any way. Please give some feedback.
    Jan 07, 2011 | Whirlpool GS5SHAXN Side by Side...
    Model ET18NK drain freezes up and water runs down in the inside of the refrigerator box when the refrigerator sits for long periods of time, unused. it is located at a vacation home and just used...
    All refrigerators with a frost free freezer go into a deforst cycle automaticly 3 - 4 x a day. As the frost melts it drips into a pan located behind the rear panal in the freezer, ending up in a pan out side the refrigerator underneth, were it evaporates. Debris can clog the line causing the melted frost to back up and eventually drip into the refrigerator. The sure way to clear the path is to remove the back panel (inside the freezer) and remove any forign material in the pan, then blow out the line with compressed air. An easy way may be to pull the plastic drip line off were it comes out of the back of the box and clean/ blow it out from there. The problem with doing it the easy way is that your not removing the clog, just moving it in the freezer pan where it may find its way back clogging the drain again. Unplug the box prior to removing any screws.
    Jul 27, 2010 | Whirlpool 18.2 cu. ft. Top Freezer...
    Water leaking into refrigerator
    There are 2 types - the older types where you have a drip cup in your refrigerator extending to the back of your fridge into the wall and down the hose - OR the newer ones where the drain is in the freezer and goes straight down the drip pan. Look at the back of your refrigerator, if you see a tube extending down into a drip pan (on the compressor or next to it) that is your drain tube, if you can locate a drain cup in your refrigerator you can remove it and dislodge anything plugging your drain tube.
    For newer or models without a drain cup, you'll have to remove the freezer panel and look at the bottom you should notice a hole, this is where the melted ice from defrost drips into through the tube and onto the drip pan below. Maybe there is excess freezeup ordebris or something blocking out the drain, so the water will spill over to the other opening where cool air passes onto your refrigerator - usually the culprit is excess ice buildup - if it is the case you can manually blow dry that section, clearing up the hole. once done you might also want to insert a piece of wire or long flexible cable to unplug the drain line.
    Good luck.
    Sep 15, 2009 | Kenmore 60721 Refrigerator
    Freezer coils freezeup fresh food side gets warm
    If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
    Jan 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Water leaking from refrigerator
    Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
    If you just want to clean it you may can access it from the rear behind the cardboard backing. If it's overflowing your water filter may be stopped up or you may have had an excessive amount of frost one time.
    Jul 09, 2008 | Roper RS25AEXLQ Side by Side Refrigerator
    Refrigerators Logo
    128 people viewed this question
    Top Amana Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
