Question about Yamata Gravity Professional GSI-8800 Iron
Yamata Steam iron 8800
Hi
I accidentally dropped my steam iron and have broken the plastic part where the wires attach at the back. Is there somewhere I can order parts? Thanks
Evelyn
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Order Part Number 5 from Yamata at 305-418-4421
Yamata.com
Also see the parts diagram I just attached.
Posted on Jul 13, 2009
Water bottle for pro steam iron PSS 2001
Here is the information of Yamata who do this product. If you contact them, they might be able to tell you where to get one, if not try ebay?
Add: 3450 NW 114 Avenue , Miami ,Fl 33178 , USA. Tel: (305)418-4421.
Toll Free: 1-888-2 YAMATA
(292-6282).
fax: (305)418-5036. E-mail: info@yamata.com
Jul 11, 2015 | Irons
Rowenta iron dg3050 iron potion broken and will not hold steam can you replace the iron part
More than likely your steam valve is broken or stuck. I had one of these and they are worth having repaired. Google Rowenta Repair Center.
Jun 15, 2014 | Rowenta DG5030 Iron
Steam button broke?
I've looked up parts for this iron. Sorry to say the steam button is not listed. The button may be able to be repaired at a small apliance repair center, but I do not know what the cost would.
May 07, 2014 | Rowenta DG8430 Pro Precision Steam Station
Steam is coming out of water fill area
Where did you purchase a new cap, mine was accidentally broken and can't find a replacement.
Apr 22, 2013 | Rowenta Pressure Iron and Steamer DG5030
No steam. I pressed the steam button on the underside of iron handle and no staem.
There 's a leaked capacitor in the circuit board. You just have to replace it and it works again.
Please visit the following page for detailed instructions:
http://thechipfreak.blogspot.com
Jan 15, 2010 | Rowenta DG5030 Iron
Sunbeam steam iron 4239 adjustable steam iron won't heat up
POSSIBLE CAUSES:
1. Blown fuse
2. Broken thermostat
3. Broken power cords
4. Broken heating elements
first of all check FUSE.
good luck...
Apr 06, 2009 | Sunbeam Irons
Russell Hobbs Steam Glide 2200 won't produce steam.
I had a problem and tracked it down to the pump. If you take the iron apart, the pump sits towards the front of the iron and has 3 tubes connected to it. Remove the srew-down bracket and free the pump from the plastic clasps on the base. Disconnect tubes and wires (remembering where they go.
Remove the circular securing spring from the front of the pump and drop the metal barrel from the housing. Unscrew the rear plastic assembly and set aside. there is a joint inside where the plastic assembly was - this is has an o-ring and is simply a pull-apart. It deos not need screwing. Pull the metal barrel apart, taking care to note the sequence for reassembly. Inside the barel is a larger rubber washer. Pull on the metal tube that goes through the centre of the washer using a pair of pliers - it will come free.
You will then see the problem - the spring inside the metal barrel will have broken. Take care, because at the other end of the spring is a small plastic washer that must be retained. Find a pen that has a short spring inside and use this as a replacement. If necessary, you can trim the spring to make it the right lenght. Ensure you have removed all broken pieces of spring, and reassemble. Try it out before finally attaching the pump inside the iron. It took me 2-3 attempts to get the spring tension right. If you can find a 'PENAC RB-085B BA1002' pen, the spring is perfect.
Once you have got it right, reassemble.
I have to replace the spring approx every 6 months as the replacement is obviously not meant for the job and wears or rusts or breaks. However, I am getting extended use from my otherwise broken iron.
Take care - things inside get HOT!!
Hope this helps.
Oct 22, 2008 | Irons
No steam comes out of iron
Hi, there is probably a something broken in the moulded plastic trigger assembly (there is a plastic broken finger that actuates a micro-switch under the rubber handle cover). If you are so inclined, use an orange stick and gently pry up the rubber handle cover on either side from the front to the rear cord end to access, inspect and troubleshoot. I am in SoCal and use the California Electric website to obtain parts or go to the Rowenta home website to locate useful manual information, PDF reader and dealer near you.
Jul 09, 2008 | Rowenta Steam Generator DG050 Iron
Yamata Gravity Professional GSI-8800 Iron Logo
213 people viewed this question
Top Yamata Irons Experts
Are you a Yamata Iron Expert? Answer questions, earn points and help others
