Halstead finest gold boiler constantly goes to lockout on dhw & c,h. but ok as soon as the case front is taken off
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Halstead Finest Gold - CH
I have found that if you have a problem and the board is not showing a problem, then the main board is at fault...
I would be replacing the main control board/module...
heatman101
Posted on Mar 02, 2011
Ls80t hot water goes hot cold hot cold heating is ok
http://waterheatertimer.org/How-to-fix-water-heater.html
What kind of water heater do you have? Boiler, indirect?
What brand and model?
Or is this a HVAC unit?
Gene
Aug 17, 2014 | Water Heaters
Halstead 102 combi boiler dhw/ch run for 1second then goes off
You might try cleaning the flame detector. It sits in the combustion chamber and looks like a small bent nail fixed to the burmer [usually at the rear]. Use a medium emery cloth and make sure that the gas holes around it are clean and clear of debris
Apr 18, 2014 | Water Heaters
I have a halstead finest gold combi when I turn the boiler on the boiler goes into its ignition sequence when it comes to ignite the boiler fires but after the igniter stops the boiler cuts out completely...
Difficult to get too specific without knowing if you have gas or oil. Also, I am going under the assumption you mean the burner shuts down, not the whole heating system. That being said, all heating appliances have whats called a safety curcuit. Each control has the ability to shut down if certain critera are not met. There is a sensor that senses light down the blast tube. If no light is sensed in a predetermined time period, then the sensor cuts power to the burner. This stops delivery of fuel so if it does ignite you wont blow up.
(I suspect that the ignitor and burner shut down simultainously.)
It may be the sensor (cad cell eye) is doing its job, however why is the question. Could be a number of things including the fuel delivery, ignition, improper air adjustment, etc.
No qualified professional should diagnose a problem unless they are in front of the appliance. I recommend you find a licensed qualified heating techician. Hope this helps.
Feb 04, 2013 | Water Heaters
I'm trying to get hold of a Halstead CBX boiler 'user guide' and a Halstead RFTH1 room stat 'user guide'. Where can i get these docs?
Here is a site that seems to have everything in that line...
May cost you a few $$ but it will be worth it...
Halstead Boilers Ltd
heatman101
Oct 02, 2010 | Heating & Cooling
Halstead Finest Gold Combi Boiler water input temp
I know of no limitations on the temperature of the inlet water for any boiler. The warmer the water, the less energy it will take to heat it to desired temp and the colder the water, the more energy it will take. Extreme temps over an extended amout of time in either direction can stress a unit and could possibly, only possibly reduce service time.
Mar 31, 2009 | Water Heaters
I have a 6 year old Halstead Ace High boiler which has many recurring problems due to a bad fitting. It was never flushed out causing the heat exchange needing to replaced TWICE through clogging and then...
Firstly your system needs a power flush to get rid of the grot, then it needs a good inhibitor to slow up the reappearance of the sludge.
Changing the boiler won't help. Any boiler will get clogged up but the halstead DHW heat exchanger is particualrly prone to getting gummed up. You can clean this out and refit without having to buy a new one. - but without a power flush it will happen again.
Jul 31, 2008 | Heating & Cooling
Heating & Cooling Logo
148 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
