Question about Health & Beauty
Yingdi kwd 808 wiring/circuit board schematics
SOURCE: Schematic and/or wiring diagram - Magnavox TV Mod 20ms233s
the problem in my tv is the sound no have
Posted on Jul 04, 2008
SOURCE: Wires lay out/schematic
I've just started to open mine : the order of the wires, starting from the top of the panel is : brown, pink, black, grey !
Posted on Nov 16, 2008
SOURCE: Wiring to the Meade LX-50
I have never seen a scematic published on the internet for the old Magellen hand controller. However there is a fellow that repairs LX200 and LX90 hand controllers who probably does have a schematic.
Go to the LX90 or LX200 Yahoo Group, sign up and post a message asking for help from Ron Sampson. You can send him the controller and it's VERY likely that he can repair it a nominal cost.
Hope that helps you-- by the way he repaired our Astronomy club's old LX200 Classic hand controller which had burned out circuits, and can even repair the keyboards and the screen.
Posted on Jan 16, 2010
SOURCE: looking for meade etx-125ec schematic.
Here is the ETX Tuneup page:
http://weasner.com/etx/techtips/etxtu.htm
and the Mighty ETX web site tech page:
http://www.weasner.com/etx/techtips.html
Posted on Feb 04, 2010
elix0411
  • 3530 Answers
SOURCE: wiring 3 phase temp supply
Hi. May I know what specific part are we talking about? Is this a motherboard? If it is, can you tell me the make. Thank you.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Oct 20, 2010
Relay clicks then shuts off - no picture/ no osd
No picture
  1. Power cord disconnected.
  2. Power not switched on.
  3. Improperly connected signal cable.
  4. Monitor in power save mode.
  1. Connect power cord.
  2. Turn the power switch on.
  3. Connect the signal properly.
  4. Press any key on computer.
Mar 05, 2008 | Sampo PME-42V3 42 in. Plasma Television
Schematic m12 circuit board
Also looking wiring schematic M12 Milwaukee charger
Sep 27, 2016 | Milwaukee tools Milwaukee Electric Tool -...
Asko t700 dryer schematic diagram
see the schematic attached. and fix it. Merry Christmas
Dec 18, 2013 | Whirlpool Dryers
Wiring diagram for carrier HK42FZ011 circuit board
Wire for wire if you are a novice. The schematic should be on the blower door just in case you get lost. I myself have changed hundreds of them and just undo the wires since I know where they go.
Jul 17, 2012 | Carrier Furnace Control Circuit Board...
I NEED A WIRING SCENATIC FOR AN INVACARE PRONTO m6
I assume you need a wiring schematic for an M61. The circuit board schematics are proprietary and not available. The component schematics and interconnects for switches and wiring harnesses are available, as are the parts diagrams and drawings. Please clarify your specific need and issue.
Oct 10, 2010 | Invacare Health & Beauty
No output from circuit board
Doc,
I'm working on one of these chargers tonight. The white wire from the internal breaker is connected to terminal "PL" and the black wire to terminal "MS".
Hope this helps... Maybe you can fix my circuit board! Several fried components.
Jason
Jan 31, 2009 | RTO Mobil Line Mobility Scooter Chair...
How do you wire a transfomer and relay together on a central air.(bryant)I took the wires of and now witch wire goes were.I going to change the two.HELP ME
This may be somewhat difficult depending on the year make and model. I will try to help without this knowledge.
There are 2 sides to the transformer. Read the label to see which is which. One side is labeled 24 volt and the other side is labeled 115 volt.
The 115v side will probably only have 2 wires. A white wire and a black wire. The white one will connect to the common or neutral system. If there is a circuit board it will plug on to the 120v Common terminal (probably marked L2). If the air handler does not have a circuit board, the white wire will connect to the other white common wires by a wire nut.
The Black (hot) 120v wire will connect to the 120v L1 terminal on the circuit board. If there is not a circuit board, read the schematics to find out where to wire nut the black 120v wire to. It will obviously be connected to a 120v incoming hot center after the blower door switch.
The 24volt wires will connect in a similar fashion to the circuit board. T1 will connect to the 24v hot terminal on the board. The T2 will connect to the 24v common terminal. If there is not a circuit board you will need to read the schematics very carefully before proceeding. It may be a good idea to add a 2amp fuseable link on the 24v T1 wire just in the case we are wrong.
The 24v hot wire may be wired in multiple ways without a circuit board. One way is to be wired to the Limit side of the Fan/Limit switch (located on back wall of the burner compartment just above the gas valve. Another way is wired to the gas valve. Please read the schematics located on the blower door. I hope this helps at least a little. Let me know please. Thanks.
Aug 14, 2008 | Heating & Cooling
Health & Beauty Logo
228 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
