Question about Sewing Machines
When attempting to sew the bottom of the material stitches are all bunched up. Could it be the bobbin?
  • 202 Answers
It could be the bobbin if you put it in the bobbincase upside down and its turning the wrong way. When its in the bobbincase and you pull the thread while looking at the bobbin, the bobbin should turn clockwise. If its turning counter clockwise flip the bobbin over.
It could just be the top isn't threaded right also.
Or maybe there is a burr on the hook that grabs the thread as it goes around. The burr would catch the thread and foul everything up.
There are a few reasons for what you described.
Rick
Posted on Sep 05, 2010
I have a problem with sewing, the stitches on the top are tight and the bottom stitches look fine, when I sew the material is bunched up.
The bobbin thread is too tight it's either getting caught on something or tension of bobbin needs adjusted
Mar 05, 2015 | Sewing Machines
I have the brother CE5500PRW sewing machine. I
Are you 100% sure you are using the right size bobbin?
Sep 11, 2017 | Sewing Machines
Thread bunching and bobbin winder quit
This sounds a lot like you've forgotten to lower the presser foot. (this leaves the tension discs open and causes serious issues below the material.) Double check that and if still having issues post again.
Nov 03, 2012 | Brother SE-270D Computerized Sewing...
When attempting to sew the bottom of fabric "thread starts bunching up after about 3 stitches....Help....what is wrong
you might try checking your needle to see if it's bent-roll on flat surface to see if it roll correctly
or blunt or damaged
some sewing machines bunch up like that when the thread come off the thread take up lever
also check the top tension
check for lint or loose thread in the bobbin area
check to make sure the bobbin is wound correctly
Sep 25, 2010 | Necchi 4575 Mechanical Sewing Machine
Thread bunchingup on bottom of material on singer
Here are some solutions to try.
* Re-thread your machine
It may be threaded incorrectly.
* Raise your feed dogs If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Dec 28, 2009 | Sewing Machines
My new sewing machine, just opened to use, is bunching thread on the underneath or bobbin side when I attempt to straight stitch. What is causing this to happen. Thanks.
re thread the top and bobbin threads
after pulling up the bobbin thread pull both threads to the back and hol them when stitching the first few stitches
with out holing the threads the machine will pull the thread into the machine and bunch the thread
Aug 24, 2009 | Kenmore Sewing Machines
Thread bunches up from bobbin feed.
Remove the needle plate and clean the feed dogs there could be fluff gathering.
Check your needle is not damaged.
May 30, 2009 | Singer 1120 Mechanical Sewing Machine
Thread bunching
There is two other potential problems other than the stitch length. I have this model and if the bobbin is not the exat right one, then it will bunch. I have also seen it happen when the tension is too loose.
Feb 09, 2008 | Sewing Machines
Won't sew
you have tread in the bottom of it. and needs a cleaning. check the tension, most set on 3
Dec 15, 2007 | Kenmore 12102
Bobbin not working
Hi steph77....please click on the following URL to view applicable information to correct your issue....good luck my friend. http://www.fixya.com/support/t162553-underthread_going_crazy
Jul 31, 2007 | Janome Jem Silver 662 Mechanical Sewing...
Sewing Machines Logo
59 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
