Ac puts out hot air only , but everythings else is full and in good working order!
Is it a split system? Is your outside unit running?
Posted on Sep 03, 2010
Where is the expansion valve located? The air conditioner is blowing hot air in front and rear units. I did put two cans of fr-ion.
Is the system full of freon ?
The rear ac uses an expansion valve, and the front ac uses an orifice tube. One system can work independently of the other.
Sep 04, 2013 | 2002 Ford Excursion
Will no freon prevent me from adding freon if the compressor wont engage without it
Sort of.
If the system is empty, you would need to jumper the low pressure switch to power the ac clutch to put the first can or two of freon in.
Keep in mind the system is supposed to be vacuumed out before adding freon, so if it is full of air you won't be able to put the full amount of gas in.
Sep 28, 2012 | 1999 GMC Suburban
Kia air conditioner doesnt work
I have a 2007 kia rondo.Ac was working,parked it for a year,ac wasnt working,recharged,the ac,it worked for a month,an started again,blowing hot ai.If you let it set for hour would start working...then after a few days it would only work early morning,if you dont turn ac of,then it stop working,I see the clutch isnt kicking in,ir you try an put freeon in it soon as you start putting it in it would kick on.An its full of freeon.
Mar 11, 2012 | 2007 Kia Rondo LX V6
My AC doesn't work, hot or cold no air comes out. Everything turns on as if it was working, but no air comes out.
Could be your fuses, blower motor, or blower motor resistor. Jags are fickle cars and are best dealt with by experienced mechanics that specialize in European vehicles.
Jan 04, 2012 | Jaguar X-Type Cars & Trucks
Hi, i have a 2002 alero that is having engine hesitation ever since i got my ac fixed last week. was only slightly hesitant at first, but now it will barely go over 40-45 mph.thanks!
AIR CONDITIONER PUT LOAD ON ENGINE.IN ORDER FOR ENGINE TO CARRY AC LOAD YOUR ENGINE HAS TO BE TOP KNOTCH SHAPE.SPARK PLUGS + WIRES HAS TO BE GOOD.FUEL FILTER AND AIR FILTER HAS TO BE GOOD SHAPE.INJECTORS BEEN CLEANED.SEE YOUR ENGINE HAS TO HAVE FULL POWER TO CARRY AC LOAD.IF ENGINE POORLY TUNED THE AC WILL PULL DOWN ENGINE POWER THATS WHY YOU GET HESITATION.
Jul 31, 2010 | 1999 Oldsmobile Alero
No cool air comes out only hot air, What could be
one of your vents are not working right.
May 15, 2010 | 2004 Ford F150
Bryant 557A fan blower not working. tech shows up and says need new fan motor. goes back to shop and owner of ac business calls and says he wants to recheck. comes back and puts test set on ...says new...
Is it burning up the motor or the control module?
If its the module the motor is probably running at full speed all the time. They need to check the wiring, duct static, filters, coil, any restrictions to airflow.
It might be a good idea to have them check with the Bryant customer service technicians or hot line. They deal with these problems all the time.
Dec 13, 2009 | Heating & Cooling
With AC on cold, Drivers air full hot & passenger side full Cold
that is a good possibilty, but before I pulled the trigger I would try this first. unhook the battery for 5 minutes, rehook it, now turn the key on, wait for 2 minutes, now start the truck and see if the doors now work. sometimes this works, its worth a try.
Sep 26, 2009 | 2005 GMC Sierra
Ac fan was working, turned off car and 2 hours later went to leave, car starts but ac fan not working no cold air hot air ..nothing all fuses look good. auto zone said it is probally the resistor
It is (in order of likeliness) either a fuse, the resistor (located in the airbox near the fan for cooling purposes, that resistor gets HOT!), the fan motor itself, the control switch, or, less than likely, wiring issues.
It can be quite a job to get in the airbox for the resistor and the motor as you probably have to take half the dash and trim out in order to get to the airbox...
Sep 17, 2009 | 2004 Honda Accord
Heater does not blow hot air on full heat setting
the problem is caused by the motor that operates the air temp blend door motor in the heating ducts, it blends air between AC and heater core tro give desired outlet temp.
Dec 12, 2008 | 2000 Chevrolet Silverado 1500
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
