Question about Lomo Diana Mini 586 Film Camera
I have just developed out my film and realise it has a constant blue streak/line across the top of every photo. it is slightly obvious in some of the photos. may i know what might possibly cause that?
    Brigadier General:
  • 3,006 Answers
What you describe is typical of a film which is getting scratched as it is used in the camera, either due to dirt or debris in the camera, a rough finish to a camera part in the film path, or even just a faulty film cassette which had a bit of grit in the light seal when the film was rewound. It's very common in cheaply made plastic toy cameras like Lomos and Holgas.
If it happens all the time, it's a camera fault. If it's intermittent it's either a camera fault or a processing lab fault, but most labs run regular test rolls through to ensure these faults do not occur. If it's a one-off, then it was probably a bit of debris in the film cassette light seal.
If the fault is in the camera, lay the negative across the back of the camera and then look and feel anywhere in the film path that the line appears along to find the problem. Rectification usually means a bit of cleaning, or smoothing down with a sharp knife or fine abrasive and be very careful not to allow the material you remove to fall into the camera and cause more problems.
Posted on Sep 04, 2010
My print outs are having lines across them
You need to have your printer go thru head cleaning cycle. Check to make sure the ink is not leaking from the cartridge. Are you using OEM ink or second hand?
Jun 20, 2014 | HiTi P720L Photo Printer
Got the TV 4 free so lets start at that. Was a very poor picture so checked the guns saw the green/blue was very foggy and changed the CRT Fluid in Green and blue red obviously was fine. Now tv up and...
are the lines slightly curved and go from the botom to top across the screen. If so it sounds like retrace lines from the CRTs being turned up too far. You can add the pic by clicking the camera Icon next to where it says Insert below the text box.
Nov 03, 2011 | Philips 50P8341 50" Rear Projection...
I am using the Epson Perfection V700 photo scanner to scan dental xrays. Sometimes the xrays come out perfect, other times I get streaks across the image. Sometimes the streaks are colored, othertimes...
You have to use the "FILM AREA GUIDE" included with the scanner. This black plastic guide leaves a small area at the top of the glass open so that the scanner can calibrate itself at the start of each scan. Use the guide or leave at least 8mm between the top of your film and the top of the scanner glass.
Jan 24, 2011 | Epson Perfection V700 PHOTO Flatbed...
I have a polaroid film 600 camera where can I get a battery for it, and how do I change it's battery?
The battery comes built in to the photo pack. All photo packs are now past their use by dates though as they have been out of production for more than a year, so any which you do find may have weak or flat batteries.
Photo packs which have been kept refrigerated will have better colour production and more accurate contrast but are far more likely to have flat batteries. Photo packs stored at around a constant twenty degrees Celsius are more likely to have a good battery, but there is a greater chance of poor photo colours & contrast and there is a greater chance that the photo ejection rollers will fail to squeeze the developing chemicals evenly across the photo.
The camera can be modified to take an external film pack, but it's a DIY job using whatever you have to hand; unfortunately I can't recall what the correct voltage is but if you ask another question on FixYa then someone will know.
Oct 29, 2009 | Polaroid 600 Film Camera
35mm film developed with streaks
I take it the streak is a hot streak of light. If you're shooting negative, look at the negative and see if it's one long streak. If so the light leak could be anywhere between the film roll and the take up roll. I would open up the back, go into a closet and shine a bright light on the front of the camera and see if you can find the leak and tape it up. Otherwise, 35mm SLR's are very cheap these days. I'd recommend a Canon A-1 for your daughter, but you can't go wrong with any Canon or Nikon.
Sep 03, 2009 | Photography
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
My developed color film from a Canon EOS has a notable thin line across the top which appears medium to dark-blue in all of my prints, especially those with blue sky tones. Is this a light leak? If so,...
Try to dust off the inside of the body, the mirror and ckeck if it is movin gorectly or if there's something in the way. Also it mai be "something scratching the negative from the front or the back, check your negative."
Jul 07, 2009 | Canon EOS Rebel GII with 35-80 lens 35mm...
White streaks on photos
Light leak, definately a light leak. You need to change or add foam around the chamber to prevent any light from entering.
Jun 15, 2009 | Canon EOS-AE-1 35mm SLR Camera
Black line across top of all my developed pictures
You have light leak somewhere to the film.
Usually from the bad film door seal.
Mar 29, 2009 | Canon EOS Rebel GII with 35-80 lens 35mm...
Streaks
you may have a bad light seal on the film door. Try checking uscamera.com for replacements
Aug 04, 2008 | Photography
Lomo Diana Mini 586 Film Camera Logo
145 people viewed this question
Top Lomo Photography Experts
Hashim Khan
Hashim Khan
Tony Parsons
Tony Parsons
Are you a Lomo Photography Expert? Answer questions, earn points and help others
