Question about Canon PowerShot A70 Digital Camera
Canon Powershot A70. I get a 'Memory Card Error' when I turn it on. Did this three different cards. They don no appear to be defective. I just transferred all of the pictures form them to another hard drive. Help! Tom
    Brigadier General:
  • 11,967 Answers
When you transferred the pics from the cards to your computer, did you use the "safely remove hardware" function before removing the cards or cord or whatever method you used? If not, this is why you're getting the error message. If the pics are safely downloaded, format the cards in the camera to get them working again.
Posted on Sep 03, 2010
New camera, Canon PowerShot A2300, I have not used it, yet. Just placed the new battery in after I charged it, and I put in the San Disk 8GB SDHC Card, and the camera says "memory card error". I ca
Normally, you can only insert an SD card one way. Try a different SD card or check to see if the SD card you're using has the "write protect" switch on. If that's not the issue try formatting the card in your PC and then format it in the camera.
Mar 05, 2013 | Canon PowerShot A2300 16 Megapixel Digital...
No Memory Card error
Check to see the largest capacity card that the camera will accept - if you are trying to use cards larger than this, I would expect this error.
Jul 28, 2017 | Canon PowerShot A70 Digital Camera
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
Memory card is defective error message
Format the memory card on the same camera it is not a battery problem &also reset your camera
Sep 06, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Memory card,CANON powershoot A70
You shoould be able to do it with the camera options. If not you can do it withthe camera.
Here's the instructions.
http://www.ehow.com/how_2112408_format-memory-card.html?ref=fuel&utm_source=yahoo&utm_medium=ssp&utm_campaign=yssp_art
May 17, 2009 | Canon PowerShot A70 Digital Camera
Canon powershot A70 digital camera
The memory card may be failing. Recommend trying a different memory card to verify. Do you still have the original low value card that came with the camera? If so, try that one to see if you still have the problem. If that one checks fine, then you know it's time for a new card.
Feb 14, 2008 | Canon PowerShot A70 Digital Camera
Memory card error
Same problem here with Micro Memory MMSD/4GBHI card. What to do?
Feb 02, 2008 | Canon PowerShot A620 Digital Camera
Canon PowerShot A70 Digital Camera Logo
87 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
