Question about Dell Inspiron 1545 Notebook
How to appear battery indicator - Dell Inspiron 1545 Notebook
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 88 Answers
CONTROL PANEL, POWER OPTIONS AND YOU CAN SET IT TO SHOW THE POWER METER
Posted on Sep 03, 2010
Cant remove battery indicator from my tablt home page
That icon on the top of the screen is standard to provide you with a visual indicator of how much battery power is left. It is part of you status menu.
Is there another battery icon appearing somewhere?
Mar 23, 2015 | Computers & Internet
Gateway NV5378u lap top, brand new battery installed and status says 100% charged. When I unplug the computer it shuts off as if there is no battery. Could the new battery be defective?
There are a few things to check. The LED lights can tell you a lot. This will tell you more about the battery:
  1. On the taskbar, double-click the power cord icon or battery icon to open the Power Meter dialog box. Note: If the power cord icon or battery icon does not appear on the taskbar, click the show hidden icons button.
  2. Press Fn+STATUS to view the power status box, which opens in the upper-left corner of the screen. The power status box shows the current power source, the battery charge level, and the power management mode.
  3. Look at the battery charge indicator (if applicable).
    • LED green - Battery is fully charged.
    • LED orange - Battery is charging.
    • LED blinking red - Battery charge is very low.
    • LED solid red - Battery is malfunctioning. Note: This LED only lights up when the notebook is connected to AC power.
  4. Press the battery meter button on the battery. The battery meter lights indicate the percentage of battery charge remaining.
  5. Wait for a Low Battery warning message to appear.
If your battery charge indicator displays what looks like an inaccurate charge, you may need to recalibrate the battery.
To recalibrate the battery as mentioned, try this:
  1. Connect the AC adapter and then turn on the notebook.
  2. As soon as it starts and you see a startup screen, press the F2 key.
  3. In the BIOS Setup utility, use the TAB key to select the Advanced menu.
  4. On the Advanced menu, select Battery Auto Learning, and then press the SPACEBAR to select Enabled.
  5. Use the RIGHT ARROW key to select the Exit menu. On the Exit menu select Exit Saving Changes, and then press ENTER.
  6. At the Setup Confirmation prompt, select Yes, and then press ENTER.
  7. The battery recalibration process begins and a screen opens showing you the progress.
  8. When the recalibration has finished, and the message "Press [Esc] key to exit" appears, press Esc. The battery charge indicator now displays an accurate battery charge.
Hope this helps!!
Oct 20, 2013 | Computers & Internet
I have to reset date time etc everytime i turn camera on
If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
1. Confirm that the camera power is turned off.
2. Slide the memory card slot / battery cover lock and open the cover.
3. Hook your nail onto the date battery holder and lightly pull up.
4. Remove the battery holder in the direction indicated by the arrow. a570isbackupbatremove.gif 5. Remove the battery by pulling it up in the direction indicated by the arrow.
a570isbackupbat.gif 6. Insert a new battery with the (-) side facing up.
7. Replace the battery holder and close the memory card slot / battery cover.
8. When the Date/Time menu appears set the date and time.
Feb 05, 2011 | Canon PowerShot A590 IS Digital Camera
I have the cobra CXT275 they have been on the desktop charger for 5 days. They won't charge over a 1/4 of the way how do I get the maximum charge?
Just went to their site and this is what it said:
This may simply be a matter of misinterpreting the low-battery indicator. We use two different types of battery indicators:
  1. Battery Level Indicator: This battery indicator is always visible, and has several segments. When all the segments are lit, the batteries are full. When only the last segment is lit, the batteries are almost exhausted.
  2. Low Battery Indicator: This type is usually NOT visible. It only appears when the batteries are low, at which time it flashes on the display to warn you of a low battery condition.
Please note that when you turn on your radio it first performs a display test. Everything on the display will light up for a few seconds, including the Low Battery Indicator. This does not mean that the batteries are low. After a few seconds the display test will end, at which time the Low Battery Indicator should go away.
Jan 12, 2011 | Cobra Two Way Radio
Where is the battery indicator on this camera?
The battery level indicator will appear in the upper right corner of the display when the level drops low. If nothing appears there then the level is good.
Oct 02, 2010 | Nikon COOLPIX L18 Digital Camera
My Acer Aspire 5100 just went blank. There is a
Generally, an indication that the battery is critically low. It appears that the AC adapter is not powering the system and not charging the battery.
Jan 09, 2010 | Acer Aspire 5100 Notebook
Where is the battery power level indicator on LCD screen so that I can know when to recharge the battery.
The low-battery indicator will appear near the upper-right corner of the display when the battery level drops. If it's not there then the battery level is fine. When it appears, get ready to replace or recharge the battery.
Oct 31, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Dead appearing ups/inverter
keep on your main switch. off all the lights fan and other electrical items, let that inverter get charge first
Jun 18, 2009 | APC Back-UPS CS 500VA UPS System
Battery indicator light blinks red
if it show fully battery also when u charge your battery it show from the red indicate only tht is not a problem... u need to charge the battery fully ... untill the msg shown as charge complet .. so need not to worry about the Red blinking battery indicator when you plug in charger.
Apr 28, 2007 | Motorola Mobility RAZR V3
Manual settings - shutter speed not indicated
Shut down the camera - remove batteries, leave for an hour- reinsert batteries- Did it recover? If no get onto the Sony Technical Support Team - This indicates a firmware failure which they and only they can sort.
Oct 30, 2006 | Sony Cyber-Shot DSC-W5 Digital Camera
Dell Inspiron 1545 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
